[SCM] PostGIS branch master updated. 3.7.0beta1-105-ga25c022091
Mon Jul 27 16:44:02 PDT 2026
the project "PostGIS".
       via  a25c0220917fa7eb483fece0a94f93b5caf333a0 (commit)
       via  ee19468c2a1cdc3f0c93453601fe85e9f7cbba65 (commit)
      from  5e47d8c16f78442f9a2c7fbb8953a3c89da6a4a2 (commit)
revisions in full, below.
commit a25c0220917fa7eb483fece0a94f93b5caf333a0
Merge: 5e47d8c16f ee19468c2a
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 16:44:01 2026 -0700
    Merge pull request 'ci: rename Woodpecker helper directory' (!573) from Komzpa/postgis:codex/woodie-ci-dir-rename into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/573
commit ee19468c2a1cdc3f0c93453601fe85e9f7cbba65
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 03:43:13 2026 +0400
diff --git a/.woodpecker/codeql.yml b/.woodpecker/codeql.yml
index 8775546ee8..51d19347cc 100644
--- a/.woodpecker/codeql.yml
+++ b/.woodpecker/codeql.yml
@@ -15,7 +15,7 @@ steps:
     image: repo.osgeo.org/postgis/build-test:debian13
     pull: true
     commands:
-      - gate_status=0; python3 ci/dronie/codeql_should_run.py || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+      - gate_status=0; python3 ci/woodie/codeql_should_run.py || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
       - export CODEQL_TMP="$${CI_WORKSPACE}/.tmp/codeql"
       - export CODEQL_HOME="$${CODEQL_TMP}/codeql"
       - export CODEQL_DB="$${CODEQL_TMP}/db"
@@ -31,7 +31,7 @@ steps:
         "$${CODEQL_HOME}/codeql" database create "$${CODEQL_DB}"
         --language=cpp
         --source-root="$${CI_WORKSPACE}"
-        --command=ci/dronie/codeql_build.sh
+        --command=ci/woodie/codeql_build.sh
         "$${CODEQL_HOME}/codeql" database analyze "$${CODEQL_DB}"
         cpp-security-and-quality.qls
diff --git a/.woodpecker/tools.yml b/.woodpecker/tools.yml
index 90e989e439..b3155346df 100644
--- a/.woodpecker/tools.yml
+++ b/.woodpecker/tools.yml
@@ -7,4 +7,4 @@ steps:
     pull: true
     commands:
-      - sh ci/dronie/postgis_tools.sh
+      - sh ci/woodie/postgis_tools.sh
diff --git a/ci/dronie/codeql_build.sh b/ci/woodie/codeql_build.sh
similarity index 100%
rename from ci/dronie/codeql_build.sh
rename to ci/woodie/codeql_build.sh
diff --git a/ci/dronie/codeql_should_run.py b/ci/woodie/codeql_should_run.py
similarity index 97%
rename from ci/dronie/codeql_should_run.py
rename to ci/woodie/codeql_should_run.py
index 109d145fb1..fcb2fe132d 100755
--- a/ci/dronie/codeql_should_run.py
+++ b/ci/woodie/codeql_should_run.py
@@ -16,8 +16,8 @@ import sys
 CODEQL_GLOBS = (
     ".woodpecker/codeql.yml",
     ".github/workflows/codeql.yml",
-    "ci/dronie/codeql_build.sh",
-    "ci/dronie/codeql_should_run.py",
+    "ci/woodie/codeql_build.sh",
+    "ci/woodie/codeql_should_run.py",
     "configure.ac",
     "configure.in",
     "autogen.sh",
diff --git a/ci/dronie/postgis_regress.sh b/ci/woodie/postgis_regress.sh
rename from ci/dronie/postgis_regress.sh
rename to ci/woodie/postgis_regress.sh
diff --git a/ci/dronie/postgis_regress_alpine.sh b/ci/woodie/postgis_regress_alpine.sh
rename from ci/dronie/postgis_regress_alpine.sh
rename to ci/woodie/postgis_regress_alpine.sh
diff --git a/ci/dronie/postgis_tools.sh b/ci/woodie/postgis_tools.sh
rename from ci/dronie/postgis_tools.sh
rename to ci/woodie/postgis_tools.sh
Summary of changes:
 .woodpecker/codeql.yml                          | 4 ++--
 .woodpecker/tools.yml                           | 2 +-
 ci/{dronie => woodie}/codeql_build.sh           | 0
 ci/{dronie => woodie}/codeql_should_run.py      | 4 ++--
 ci/{dronie => woodie}/postgis_regress.sh        | 0
 ci/{dronie => woodie}/postgis_regress_alpine.sh | 0
 ci/{dronie => woodie}/postgis_tools.sh          | 0
 7 files changed, 5 insertions(+), 5 deletions(-)
 rename ci/{dronie => woodie}/codeql_build.sh (100%)
 rename ci/{dronie => woodie}/codeql_should_run.py (97%)
 rename ci/{dronie => woodie}/postgis_regress.sh (100%)
 rename ci/{dronie => woodie}/postgis_regress_alpine.sh (100%)
 rename ci/{dronie => woodie}/postgis_tools.sh (100%)
hooks/post-receive
