[SCM] PostGIS branch master updated. 3.7.0beta1-107-g60581a9b31
git at osgeo.org
git at osgeo.org
Mon Jul 27 23:07:02 PDT 2026
the project "PostGIS".
via 60581a9b317dc64aad80b701755d271658f41f02 (commit)
via 23be1accf8d11bd88034b82ba0688801ad3e9328 (commit)
from a25c0220917fa7eb483fece0a94f93b5caf333a0 (commit)
revisions in full, below.
commit 60581a9b317dc64aad80b701755d271658f41f02
Merge: a25c022091 23be1accf8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 23:07:00 2026 -0700
Merge pull request 'ci: tolerate missing TMPDIR in upgrade check' (!581) from Komzpa/postgis:codex/trac-6099-tmpdir-fallback into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/581
commit 23be1accf8d11bd88034b82ba0688801ad3e9328
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 05:54:15 2026 +0400
diff --git a/utils/check_create_upgrade_replaced_function_errors.sh b/utils/check_create_upgrade_replaced_function_errors.sh
index 321c7f917e..4764f06334 100644
--- a/utils/check_create_upgrade_replaced_function_errors.sh
+++ b/utils/check_create_upgrade_replaced_function_errors.sh
@@ -2,7 +2,11 @@
set -e
-TMPDIR="$(mktemp -d "${TMPDIR:-/tmp}/check_create_upgrade_replaced_function_errors.XXXXXX")"
+tmp_parent="${TMPDIR:-/tmp}"
+if ! test -d "${tmp_parent}"; then
+ tmp_parent="/tmp"
+fi
+TMPDIR="$(mktemp -d "${tmp_parent}/check_create_upgrade_replaced_function_errors.XXXXXX")"
trap 'rm -rf "${TMPDIR}"' EXIT
cat > "${TMPDIR}/postgis.sql" <<'SQL'
diff --git a/utils/test_check_create_upgrade_replaced_function_errors.py b/utils/test_check_create_upgrade_replaced_function_errors.py
new file mode 100644
index 0000000000..1f1e262258
--- /dev/null
+++ b/utils/test_check_create_upgrade_replaced_function_errors.py
@@ -0,0 +1,38 @@
+#!/usr/bin/env python3
+import os
+import shutil
+import subprocess
+import tempfile
+import unittest
+from pathlib import Path
+SCRIPT = Path(__file__).with_name("check_create_upgrade_replaced_function_errors.sh")
+class CreateUpgradeReplacedFunctionErrorsTest(unittest.TestCase):
+ def test_missing_tmpdir_parent_falls_back_to_system_temp(self):
+ shell = shutil.which("sh")
+ if shell is None:
+ self.skipTest("test requires a POSIX sh on PATH")
+ with tempfile.TemporaryDirectory() as temporary_directory:
+ missing_tmpdir = Path(temporary_directory) / "missing" / "tmp"
+ environment = os.environ.copy()
+ environment["TMPDIR"] = str(missing_tmpdir)
+ environment["srcdir"] = str(SCRIPT.parent)
+ result = subprocess.run(
+ [shell, str(SCRIPT)],
+ cwd=SCRIPT.parent,
+ env=environment,
+ text=True,
+ capture_output=True,
+ self.assertEqual(0, result.returncode, result.stdout + result.stderr)
+if __name__ == "__main__":
+ unittest.main()
Summary of changes:
...heck_create_upgrade_replaced_function_errors.sh | 6 +++-
...heck_create_upgrade_replaced_function_errors.py | 38 ++++++++++++++++++++++
2 files changed, 43 insertions(+), 1 deletion(-)
create mode 100644 utils/test_check_create_upgrade_replaced_function_errors.py
hooks/post-receive
