[SCM] PostGIS branch master updated. 3.7.0beta1-111-gf7ee000308
Mon Jul 27 23:49:34 PDT 2026
the project "PostGIS".
       via  f7ee000308768c13e9d5089ecff820adad2a8181 (commit)
       via  11fd50a4e56c73a587402ccc7f408b4c425e0be8 (commit)
      from  dfe37406b35cac730494ff933ff603172f9bb51c (commit)
revisions in full, below.
commit f7ee000308768c13e9d5089ecff820adad2a8181
Merge: dfe37406b3 11fd50a4e5
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 23:49:33 2026 -0700
    Merge pull request '[raster] Preserve integer values in ST_DumpAsPolygons' (!586) from Komzpa/postgis:codex/trac-3776-20260728 into master
    `ST_DumpAsPolygons` merges distinct adjacent `32BUI` values once they cross the reported threshold because all raster bands are currently polygonized through GDAL's floating-point path. Values `1048576` and `1048577`, although stored distinctly, therefore produce one polygon.
    Use `GDALPolygonize` for integer pixel types so their values remain exact, while retaining `GDALFPolygonize` for floating-point bands. Add regression coverage on both sides of the threshold and record the fix in `NEWS`.
    Closes https://trac.osgeo.org/postgis/ticket/3776
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/586
commit 11fd50a4e56c73a587402ccc7f408b4c425e0be8
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 08:09:45 2026 +0400
diff --git a/NEWS b/NEWS
index 43aa95bd86..c38a587886 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,8 @@ These are only changes since 3.7.0beta1.
           big-endian platforms (Darafei Praliaskouski)
  - [raster] Fix invalid reads in raster band initialization and
           geotransform property access (Darafei Praliaskouski)
+ - #3776, [raster] Keep distinct 32-bit integer pixel values separate in
+          ST_DumpAsPolygons (Darafei Praliaskouski)
  - GT-504, Report extension script/library version mismatches before loading
           functions unavailable in an older library (Darafei Praliaskouski)
  - GT-515, Reject invalid ST_LargestEmptyCircle boundaries before GEOS can
diff --git a/raster/rt_core/rt_geometry.c b/raster/rt_core/rt_geometry.c
index 70d815c69b..1eb2b87f67 100644
--- a/raster/rt_core/rt_geometry.c
+++ b/raster/rt_core/rt_geometry.c
@@ -1000,6 +1000,7 @@ rt_raster_gdal_polygonize(
 	double dValue = 0.0;
 	int iBandHasNodataValue = FALSE;
 	double dBandNoData = 0.0;
+	rt_pixtype pixtype = PT_END;
 	uint32_t bandNums[1] = {nband};
 	int excludeNodataValues[1] = {exclude_nodata_value};
@@ -1020,6 +1021,7 @@ rt_raster_gdal_polygonize(
 		rterror("rt_raster_gdal_polygonize: Error getting band %d from raster", nband);
 		return NULL;
+	pixtype = rt_band_get_pixtype(band);
 	if (exclude_nodata_value) {
@@ -1141,12 +1143,22 @@ rt_raster_gdal_polygonize(
 	 * unwind promptly when PostgreSQL requests cancellation (#4222).
 	 * Use the band's nodata mask so large/infinite nodata values are excluded
 	 * before polygonizing, bypassing the broken %f string-format filter (#6010).
+	 * Polygonize integer bands through GDAL's integer buffer so nearby large
+	 * values do not coalesce in GDALFPolygonize's Float32 buffer (#3776).
 	GDALRasterBandH mask_band = iBandHasNodataValue
 	    ? GDALGetMaskBand(gdal_band)
 	    : NULL;
-	cplerr = GDALFPolygonize(
-	    gdal_band, mask_band, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALFPolygonize");
+	if (pixtype == PT_16BF || pixtype == PT_32BF || pixtype == PT_64BF)
+		cplerr = GDALFPolygonize(
+		    gdal_band, mask_band, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALFPolygonize");
+	else
+		cplerr = GDALPolygonize(
+		    gdal_band, mask_band, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALPolygonize");
 	if (cplerr != CE_None) {
 		rterror("rt_raster_gdal_polygonize: Could not polygonize GDAL band");
@@ -1276,4 +1288,3 @@ rt_raster_gdal_polygonize(
 	return pols;
diff --git a/raster/test/regress/rt_polygon.sql b/raster/test/regress/rt_polygon.sql
index ea1e3461d1..ea3bc37a07 100644
--- a/raster/test/regress/rt_polygon.sql
+++ b/raster/test/regress/rt_polygon.sql
@@ -165,3 +165,22 @@ SELECT count(*) = 1 FROM ST_DumpAsPolygons(
 		ST_AddBand(ST_MakeEmptyRaster(3, 3, 0, 0, 1, -1, 0, 0, 0),
 		           1, '64BF'::text, -9.0, 1.7976931348623157e+308),
 		1, 2, 2, 1.7976931348623157e+308));
+-- #3776: integer values on either side of 2^20 must not be grouped together
+WITH r AS (
+	SELECT ST_SetValue(
+		ST_AddBand(ST_MakeEmptyRaster(1, 2, 0, 0, 1), '32BUI'::text, 1048575),
+		1, 1, 1, 1048576) AS rast
+SELECT '#3776.before', count(*), count(DISTINCT val), array_agg(val ORDER BY val)
+FROM r
+CROSS JOIN LATERAL ST_DumpAsPolygons(r.rast) AS gv;
+WITH r AS (
+		ST_AddBand(ST_MakeEmptyRaster(1, 2, 0, 0, 1), '32BUI'::text, 1048576),
+		1, 1, 1, 1048577) AS rast
+SELECT '#3776.after', count(*), count(DISTINCT val), array_agg(val ORDER BY val)
+FROM r
diff --git a/raster/test/regress/rt_polygon_expected b/raster/test/regress/rt_polygon_expected
index 22ec3b7199..9c67e7530d 100644
--- a/raster/test/regress/rt_polygon_expected
+++ b/raster/test/regress/rt_polygon_expected
@@ -7,3 +7,5 @@ t
 t
 t
 t
+#3776.before|2|2|{1048575,1048576}
+#3776.after|2|2|{1048576,1048577}
Summary of changes:
 NEWS                                    |  2 ++
 raster/rt_core/rt_geometry.c            | 17 ++++++++++++++---
 raster/test/regress/rt_polygon.sql      | 19 +++++++++++++++++++
 raster/test/regress/rt_polygon_expected |  2 ++
 4 files changed, 37 insertions(+), 3 deletions(-)
hooks/post-receive
