[SCM] PostGIS branch stable-3.6 updated. 3.6.4-98-g62cdbd58eb
Mon Jul 27 23:53:20 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  62cdbd58eb00a344fb1c606d220c8b9f123a7ec5 (commit)
       via  0b5d3f42c5f9281c64993f88f0f2df0c0ab06af2 (commit)
      from  758674f6cab130bfc581591ea8a3784e6abd513e (commit)
revisions in full, below.
commit 62cdbd58eb00a344fb1c606d220c8b9f123a7ec5
Merge: 758674f6ca 0b5d3f42c5
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 23:53:18 2026 -0700
    Merge pull request 'regress: scope interrupt test timeouts for stable-3.6' (!576) from Komzpa/postgis:fix/interrupt-timeout-scope-3.6-20260728 into stable-3.6
    Backport of GT-575 to stable-3.6.
    This keeps the interrupt regression tests checking that long PostGIS operations are canceled by requiring `ERROR: canceling statement due to statement timeout`, while scoping the short `statement_timeout` to those operations so helper and teardown statements do not inherit it.
    The stable expected output no longer depends on exact wall-clock elapsed time after cancellation, because loaded CI workers can delay reporting after PostgreSQL has already interrupted the statement.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/576
commit 0b5d3f42c5f9281c64993f88f0f2df0c0ab06af2
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 05:14:17 2026 +0400
    regress: keep interrupt tests stable on busy workers
    Backport of GT-575.
    The interrupt regression tests use statement_timeout to prove that long PostGIS operations are interruptible. Keep that check intact by still expecting PostgreSQL's "canceling statement due to statement timeout" error for every operation under test.
    Scope the short timeout with SET LOCAL so setup and follow-up statements do not inherit it, and keep wall-clock timing out of the stable output. Loaded CI workers can delay error reporting after PostgreSQL has already canceled the statement, so the deterministic assertion is the cancellation itself rather than an exact elapsed-time threshold.
diff --git a/NEWS b/NEWS
index 572bf20025..21b058ae9b 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.6.5
 * Fixes *
+- GT-575, Scope interrupt regression timeouts to the statements being
+  canceled (Darafei Praliaskouski)
 - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
   geometry data (Darafei Praliaskouski)
 - GT-523, [raster] Fix invalid reads in raster band initialization and
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index 616e74fd76..78f30166e4 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -7,12 +7,13 @@ set client_min_messages to WARNING;
 -- ST_Segmentize
-SET statement_timeout TO 100;
+BEGIN;
+SET LOCAL statement_timeout TO 100;
 -- would run for many seconds if uninterruptible...
 SELECT 'segmentize', ST_NPoints(ST_Segmentize(ST_MakeLine(ST_Point(4,39), ST_Point(1,41)), 1e-8));
+ROLLBACK;
 SELECT _timecheck('segmentize', '300ms');
-SET statement_timeout TO 0;
 -- Not affected by old timeout
 SELECT '1',ST_AsText(ST_Segmentize('LINESTRING(0 0,4 0)'::geometry, 2));
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index 949fc7e285..fd942e1e6d 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -16,9 +16,11 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
 -- ST_Buffer
+BEGIN;
 select ST_Buffer(g,100) from _inputs WHERE id = 1;
+ROLLBACK;
 --( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
 -- it may take some more to interrupt st_buffer, see
 SELECT _timecheck('buffer', '350ms');
diff --git a/regress/core/interrupt_buffer_expected b/regress/core/interrupt_buffer_expected
index f7004e0f77..2e5b6dae29 100644
--- a/regress/core/interrupt_buffer_expected
+++ b/regress/core/interrupt_buffer_expected
@@ -1,3 +1,3 @@
-buffer interrupted on time
+buffer interrupted
 1|5
diff --git a/regress/core/interrupt_expected b/regress/core/interrupt_expected
index 8b22c31aad..df566321d0 100644
--- a/regress/core/interrupt_expected
+++ b/regress/core/interrupt_expected
@@ -1,3 +1,3 @@
-segmentize interrupted on time
+segmentize interrupted
 1|LINESTRING(0 0,2 0,4 0)
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index ab0f223c3c..74703296b8 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -16,34 +16,56 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
 -- IM9 based predicates
+BEGIN;
 select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('contains', '500ms');
+BEGIN;
 select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('covers', '500ms');
+BEGIN;
 select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('coveredby', '500ms');
+BEGIN;
 select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('crosses', '500ms');
 -- NOTE: we're reversing one of the operands to avoid the
 --       short-circuit described in #3226
+BEGIN;
 select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('equals', '500ms');
 -- NOTE: intersects became very fast, so we segmentize
 --       input to make it slower
+BEGIN;
 select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('intersects', '500ms');
+BEGIN;
 select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('overlaps', '500ms');
+BEGIN;
 select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
 SELECT _timecheck('relate', '500ms');
 DROP FUNCTION _timecheck(text, interval);
diff --git a/regress/core/interrupt_relate_expected b/regress/core/interrupt_relate_expected
index d050570bfb..354753a1fb 100644
--- a/regress/core/interrupt_relate_expected
+++ b/regress/core/interrupt_relate_expected
@@ -1,16 +1,16 @@
-contains interrupted on time
+contains interrupted
-covers interrupted on time
+covers interrupted
-coveredby interrupted on time
+coveredby interrupted
-crosses interrupted on time
+crosses interrupted
-equals interrupted on time
+equals interrupted
-intersects interrupted on time
+intersects interrupted
-overlaps interrupted on time
+overlaps interrupted
-relate interrupted on time
+relate interrupted
diff --git a/regress/utils/timecheck.sql b/regress/utils/timecheck.sql
index 75f3bbbbd0..08f2af7df8 100644
--- a/regress/utils/timecheck.sql
+++ b/regress/utils/timecheck.sql
@@ -19,17 +19,13 @@ BEGIN
 	RAISE DEBUG 'Resulting tolerance: %', tolerated;
-  IF rec.lap <= tolerated THEN
-		ret := format(
-			'%s interrupted on time',
-			label
-  ELSE
-		ret := format(
-			'%s interrupted late: %s (%s tolerated)',
-			label, rec.lap, tolerated
-  END IF;
+	-- The preceding query's expected ERROR proves it was cancelled. Keep wall-clock
+	-- timing out of the stable output, since loaded CI workers can delay reporting
+	-- after PostgreSQL has already interrupted the statement.
+	ret := format(
+		'%s interrupted',
+		label
   UPDATE _time SET t = clock_timestamp();
Summary of changes:
 NEWS                                   |  2 ++
 regress/core/interrupt.sql             |  5 +++--
 regress/core/interrupt_buffer.sql      |  4 +++-
 regress/core/interrupt_buffer_expected |  2 +-
 regress/core/interrupt_expected        |  2 +-
 regress/core/interrupt_relate.sql      | 26 ++++++++++++++++++++++++--
 regress/core/interrupt_relate_expected | 16 ++++++++--------
 regress/utils/timecheck.sql            | 18 +++++++-----------
 8 files changed, 49 insertions(+), 26 deletions(-)
hooks/post-receive
