[PostGIS] #6108: Reconcile PostGIS Docker build environment repositories under Gitea/Woodie
PostGIS trac at osgeo.org
Tue Jul 28 09:35:33 PDT 2026
 Reporter:  komzpa                            |      Owner:  robe
     Type:  task                              |     Status:  new
 Priority:  medium                            |  Milestone:
Component:  QA/buildbots                      |    Version:  master
 Keywords:  docker woodie gitea ci build-env  |
 PostGIS currently has several Docker-related repositories with overlapping
 but different roles:
 * https://gitea.osgeo.org/postgis/postgis-docker
 * https://github.com/postgis/postgis-build-env
 * https://github.com/postgis/docker-postgis
 The third one, `postgis/docker-postgis`, should stay separate. It is the
 community/user-facing Docker image project for running PostGIS, and the
 PostGIS website already points users there for Docker installation.
 The first two are both development/CI build-environment surfaces:
 * `postgis-docker` builds OSGeo-hosted `postgis/build-test` images used by
 Dronie/Woodie-style development and regression testing.
 * `postgis-build-env` builds `postgis/postgis-build-env` images for
 PostGIS regression testing against PostgreSQL, GEOS, GDAL, PROJ, and
 SFCGAL combinations.
 These feel like two generations of the same maintainer-owned CI/build-
 image infrastructure. The split makes it harder to know which repository
 owns build images, which CI should run, and where contributors should send
 patches.
 Proposed direction:
 * Make Gitea the canonical repository location for PostGIS CI/build-
 environment Docker images.
 * Use the canonical repository name `postgis-build-env`; `postgis-docker`
 is too easily confused with `postgis/docker-postgis`, the user-facing
 Docker image repository.
 * Reconcile the current `postgis-docker` and `postgis-build-env` contents
 without losing history. This is feasible with an unrelated-history merge
 or subtree-style import, placing the imported tree under a clear prefix if
 needed.
 * Move CI/build automation to OSGeo-managed CI, preferably Woodie, with
 Jenkins/Debbie kept only where it remains the actual scheduler or
 compatibility surface.
 * Preserve published image names/tags during migration:
   * `repo.osgeo.org/postgis/build-test:*` / OSGeo registry build-test
 images
   * `postgis/postgis-build-env:*` on Docker Hub, at least during a
 transition
   * `repo.osgeo.org/postgis/build-env:*` if this is the preferred OSGeo
 registry target
 * Update the Trac Docker testing wiki and repository READMEs so
 contributors can tell:
   * development/build-env images live in Gitea `postgis-build-env`
   * production/user Docker images live in GitHub `postgis/docker-postgis`
 Suggested implementation plan:
 1. Check whether Gitea can safely rename `postgis/postgis-docker` to
 `postgis/postgis-build-env` with redirects. If yes, rename it. If not,
 create `postgis/postgis-build-env` and leave `postgis-docker` as a read-
 only pointer.
 2. Import the GitHub `postgis/postgis-build-env` history into the Gitea
 repository using a history-preserving merge/subtree import.
 3. Add Woodie CI for image build/test matrix generation and non-push PR
 validation.
 4. Add protected branch publish jobs, keeping existing Docker Hub tags and
 adding/keeping OSGeo registry tags as agreed.
 5. Archive or demote the GitHub `postgis/postgis-build-env` repository
 after Gitea CI and image publishing are proven.
 6. Update documentation links:
    * https://trac.osgeo.org/postgis/wiki/DevWikiDockerTesting
    * relevant repository READMEs
    * any PostGIS CI docs that reference the old GitHub location
 Acceptance criteria:
 * One canonical Gitea repository owns PostGIS development/CI build-
 * Existing image consumers keep working during migration.
 * The old repository locations clearly point to the new owner.
 * Woodie/Jenkins build status is visible from the canonical repository.
 * Both original Git histories remain reachable from the new repository
 history.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6108>
