[SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. ee158bbd6434d4f14b0b5435cf32a9801c70ea15
Tue Jul 28 19:12:45 PDT 2026
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  ee158bbd6434d4f14b0b5435cf32a9801c70ea15 (commit)
      from  c960912a7a628aafacec039863d0b0377d6edd05 (commit)
revisions in full, below.
commit ee158bbd6434d4f14b0b5435cf32a9801c70ea15
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jul 28 22:12:12 2026 -0400
    bessie vm setup on osgeo10
diff --git a/freebsd/osgeo8-bessie_setup.md b/freebsd/bessie_setup.md
similarity index 65%
rename from freebsd/osgeo8-bessie_setup.md
rename to freebsd/bessie_setup.md
index 1d2867b..206bf9d 100644
--- a/freebsd/osgeo8-bessie_setup.md
+++ b/freebsd/bessie_setup.md
@@ -1,14 +1,30 @@
-Bessie currently setup on osgeo8
+Bessie currently setup on osgeo10
 Built from wget https://download.freebsd.org/ftp/releases/VM-IMAGES/14.1-RELEASE/amd64/Latest/FreeBSD-14.1-RELEASE-amd64-zfs.qcow2.xz dated (Oct 2024)
-See https://git.osgeo.org/gitea/sac/osgeo8/wiki/bessie for details
+See https://gitea.osgeo.org/sac/osgeo10/wiki/bessie for details
 vi /etc/rc.conf
 add to file
+zfs_enable="YES"
+zpool_reguid="zroot"
+zpool_upgrade="zroot"
-hostname="bessie"
+#ifconfig_vtnet0="DHCP inet6 accept_rtadv"
+ifconfig_vtnet0="SYNCDHCP -txcsum -rxcsum"
+defaultrouter="10.117.178.1"
+growfs_enable="YES"
 sshd_enable="YES"
+hostname="bessie"
+postgresql_enable="yes"
+service netif restart vtnet0
 #then edit the sshd_config
 vi /etc/ssh/sshd_config
@@ -155,15 +171,24 @@ rm -rf [a-h]*
 # install agent jar
 su jenkins
+cd ~/
 mkdir bin
 cd bin
 #can't use ssh for launching agent because we need bastion
 # and when using the launch command, doesnt' automatically deploy agent
 curl -sO https://debbie.postgis.net/jnlpJars/agent.jar
-#then on jenkins config use  Launch agent via execution of comman on the controller
+#then on jenkins config use  Launch agent via execution of command on the controller
+su jenkins
+cat <<EOF >> ~/.ssh/config
-launch command:ssh jenkins at osgeo8-bessie " java -jar /home/jenkins/bin/agent.jar"
+Host bessie
+    ProxyCommand ssh debbie at hop.osgeo10.osgeo.org -W bessie:%p
+EOF
+# on https://debbie.postgis.net, create new node debbie and have launch command be
+ssh jenkins at bessie " java -jar /home/jenkins/bin/agent.jar"
 # upgrade to freebsd 14.2
@@ -182,4 +207,93 @@ freebsd-update upgrade -r 14.2-RELEASE
  freebsd-version -u #client apps userland read 14.1-RELEASE even after patch update
  pkg update
  pkg upgrade
\ No newline at end of file
+# downgrade to jdk17
+# this is needed until debbie is upgraded to newer jdk17
+pkg install -y openjdk17
+ ls -d /usr/local/openjdk* # if multiple
+java -version  #should show current
+# can switch with
+JAVA_VERSION=17 javac -version
+# upgrade to freebsd 14.3
+#upgrade to 14.3 from 14.2
+#check version running
+sudo -i
+freebsd-version -k #kernel version # read 14.2-RELEASE
+freebsd-version -u #client apps userland read 14.2-RELEASE
+freebsd-update upgrade -r 14.3-RELEASE
+#after all downloaded
+ /usr/sbin/freebsd-update install
+ reboot
+ # after coming back
+ freebsd-version -k #kernel version 114.3-RELEASE-p5
+ freebsd-version -u #client apps userland 14.3-RELEASE-p6
+ pkg update
+ pkg upgrade
+ reboot
+freebsd-update fetch
+#in future to update ports
+portsnap fetch
+# upgrade to freebsd 15
+#upgrade to 15 from 14.3
+sudo -i
+freebsd-version -k #kernel version # read 14.3-RELEASE
+freebsd-version -u #client apps userland read 14.3-RELEASE
+freebsd-update upgrade -r 15.0-RELEASE
+ reboot
+ freebsd-version -k #kernel version 15.0-RELEASE
+ freebsd-version -u #client apps userland 15.0-RELEASE-p1
+ pkg bootstrap -f
+ pkg update
+ pkg upgrade
+ reboot
+pkg install portsnap
+cp  /usr/local/etc/portsnap.conf.sample /usr/local/etc/portsnap.conf
+mkdir -p /var/db/portsnap
+portsnap fetch
+portsnap extract
+# upgrade to jdk25
+cd /usr/ports/java/openjdk25
+make install clean
+ls -d /usr/local/openjdk* # if multiple
+# can switch with
+JAVA_VERSION=25 javac -version
+pkg remove openjdk17
+# reinstall postgresql
+pkg install postgresql17-server postgresql17-contrib
+sysrc postgresql_enable=yes
+service postgresql initdb
+service postgresql start
Summary of changes:
 .../{osgeo8-bessie_setup.md => bessie_setup.md}    | 126 ++++++++++++++++++++-
 1 file changed, 120 insertions(+), 6 deletions(-)
 rename freebsd/{osgeo8-bessie_setup.md => bessie_setup.md} (65%)
hooks/post-receive
