[PostGIS] #6109: Out-of-bounds heap read in BOX2D_out and BOX2D_expand on 65-byte box2d under ASAN
trac at osgeo.org
Wed Jul 29 15:04:37 PDT 2026
under ASAN
Reporter: dtighe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: postgis | Version: 3.6.x
Keywords: |
The box2d type is defined with internallength=65 (65 bytes stored
payload). However, in C source code (postgis/lwgeom_box.c), functions
operating on box2d (BOX2D_out and BOX2D_expand) cast the input pointer
(GBOX *)PG_GETARG_POINTER(0) and copy sizeof(GBOX) bytes (72 bytes) using
memcpy. Because a materialized box2d is only 65 bytes long, copying
sizeof(GBOX) (72 bytes) reads 7 bytes out-of-bounds past the end of the
heap allocation.
This shows up under ASAN, but operates normally under non-ASAN builds.
Repro:
SELECT ('LINESTRING(0 0,1 1)'::geometry::box2d)::text;
Root cause:
In `postgis/lwgeom_box.c`:
BOX2D_out:
GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
GBOX box_aligned;
memcpy(&box_aligned, box, sizeof(GBOX)); /* sizeof(GBOX) == 72 */
BOX2D_expand:
GBOX *result = (GBOX *)palloc(sizeof(GBOX));
memcpy(result, box, sizeof(GBOX)); /* sizeof(GBOX) == 72 */
The fix should be to update the memcpy's to:
`memcpy(&box_aligned, box, offsetof(GBOX, zmin));` which covers the
required fields.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6109>
