[SCM] PostGIS branch master updated. 3.7.0beta1-136-g77265b958d
Fri Jul 31 08:21:22 PDT 2026
the project "PostGIS".
       via  77265b958d6465ced2c97afac8da79b6af40a649 (commit)
       via  2e4a585aa0abc7ec2d8d0b88bffe436069b3f30c (commit)
      from  d9fd33a2778f2a23ea7ef4b330f6c393bcba9c2f (commit)
revisions in full, below.
commit 77265b958d6465ced2c97afac8da79b6af40a649
Merge: d9fd33a277 2e4a585aa0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Jul 31 08:21:16 2026 -0700
    Merge pull request 'Document WKB hex and topology face workflows' (!636) from Komzpa/postgis:ai/trac-wiki-recipes-doc-20260731 into master
    Move two durable cookbook fragments from Trac into the maintained PostGIS
    manual.
    * document a deterministic hexadecimal WKB round trip using PostgreSQL
      `encode`/`decode` with `ST_AsBinary` and `ST_GeomFromWKB`
    * replace the old topology shell-script recipe with a current SQL walkthrough
      that builds faces from linework, validates the topology, locates point
      attributes, detects outside or duplicate labels, and cleans up
    Source pages:
    * https://trac.osgeo.org/postgis/wiki/FAQ
    * https://trac.osgeo.org/postgis/wiki/UsersWikiTopologyExample
    The broader non-Notes Trac pass found the other cookbook SQL either already
    covered by current functions and examples or too application-specific to move
    into the canonical manual.
    Validation:
    * `make -C doc check`
    * `make -C doc exampletest-report` (923 of 923 selected examples parseable)
    * executed both WKB queries and the complete topology workflow against
      PostgreSQL 18.4 with PostGIS 3.7.0dev; `ValidateTopology` returned zero errors
    * verified the disposable test database was removed
    * `git diff --check`
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/636
commit 2e4a585aa0abc7ec2d8d0b88bffe436069b3f30c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jul 31 19:13:45 2026 +0400
    doc: add WKB hex and topology face examples
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 79884547a0..e95000b5eb 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -19,6 +19,91 @@ how is it used, and various FOSS4G tools that support it in <link xlink:href="ht
 	<para>Functions that are defined in SQL/MM standard are prefixed with ST_ and functions specific to PostGIS are not prefixed.</para>
         <para>Topology support is built by default and can be disabled by specifying the --without-topology configure option at build time as described in <xref linkend="postgis_installation"/></para>
+        <section xml:id="Topology_Linework_Faces_Example">
+            <title>Building Faces from Linework</title>
+            <para>This example builds topology faces from noded linework and
+            associates point attributes with the resulting faces. It uses
+            <xref linkend="ST_CreateTopoGeo"/> to populate an empty topology,
+            <xref linkend="ValidateTopology"/> to check the result,
+            <xref linkend="GetFaceByPoint"/> to locate each attribute point,
+            and <xref linkend="ST_GetFaceGeometry"/> to materialize ordinary
+            polygon geometries.</para>
+            <para>Create an empty topology and populate it with linework that
+            encloses two faces:</para>
+<programlisting language="sql" role="requires-external-state">CREATE EXTENSION IF NOT EXISTS postgis_topology;
+SELECT topology.CreateTopology('topo_example', 3857);
+WITH lines(geom) AS (VALUES
+    ('SRID=3857;LINESTRING(0 0, 2 0)'::geometry),
+    ('SRID=3857;LINESTRING(0 1, 2 1)'::geometry),
+    ('SRID=3857;LINESTRING(0 0, 0 1)'::geometry),
+    ('SRID=3857;LINESTRING(1 0, 1 1)'::geometry),
+    ('SRID=3857;LINESTRING(2 0, 2 1)'::geometry)
+SELECT topology.ST_CreateTopoGeo(
+    'topo_example',
+    ST_Collect(geom)
+FROM lines;
+SELECT * FROM topology.ValidateTopology('topo_example');</programlisting>
+            <para>An empty result from <function>ValidateTopology</function>
+            means that no topology errors were found. Attribute points can now
+            be matched to faces. A face identifier of <literal>0</literal>
+            denotes the universal face, so the point is outside every bounded
+            face.</para>
+<programlisting language="sql" role="requires-external-state">WITH labels(name, geom) AS (VALUES
+    ('west', 'SRID=3857;POINT(0.5 0.5)'::geometry),
+    ('east', 'SRID=3857;POINT(1.5 0.5)'::geometry),
+    ('outside', 'SRID=3857;POINT(3 0.5)'::geometry)
+located AS (
+    SELECT name,
+           topology.GetFaceByPoint('topo_example', geom, 0) AS face_id
+    FROM labels
+SELECT name,
+       face_id,
+       CASE WHEN face_id = 0 THEN NULL
+            ELSE topology.ST_GetFaceGeometry('topo_example', face_id)
+       END AS geom
+FROM located
+ORDER BY name;</programlisting>
+            <para>Before copying attributes into a face table, check both for
+            points outside bounded faces and for multiple source points assigned
+            to the same face:</para>
+located AS (
+    SELECT name,
+    FROM labels
+SELECT 'outside face' AS problem,
+       array_agg(name ORDER BY name) AS labels
+FROM located
+WHERE face_id = 0
+HAVING count(*) > 0
+UNION ALL
+SELECT 'duplicate face ' || face_id,
+FROM located
+WHERE face_id != 0
+GROUP BY face_id
+HAVING count(*) > 1;</programlisting>
+            <para>Use <xref linkend="DropTopology"/> to remove the example
+            topology when it is no longer needed:</para>
+<programlisting language="sql" role="requires-external-state">SELECT topology.DropTopology('topo_example');</programlisting>
+        </section>
         <section xml:id="Topology_PrimitiveTables">
             <title>Topology Primitive Tables</title>
             <para>The core primitives of any topology are stored in the <varname>edge_data</varname>, <varname>node</varname>, and <varname>face</varname> tables that live in the schema created by <xref linkend="CreateTopology"/>.  Each row of <varname>edge_data</varname> represents an oriented edge: it records a directed curve from <varname>start_node</varname> to <varname>end_node</varname> together with the identifier of the face encountered on the left of that direction (<varname>left_face</varname>) and the face encountered on the right (<varname>right_face</varname>).  The same geometric segment may therefore appear twice—once for each orientation—when it belongs to two faces.</para>
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index fd5f20113a..f47010156d 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -1189,13 +1189,22 @@ SELECT ST_MPointFromText('MULTIPOINT((-70.9590 42.1180),(-70.9611 42.1223))', 43
 <programlisting language="sql">SELECT ST_GeomFromWKB(ST_AsEWKB('POINT(2 5)'::geometry)
   );</programlisting>
 <screen role="visual-primary text-primary">POINT(2 5)</screen>
+		<para>The PostgreSQL <link xlink:href="https://www.postgresql.org/docs/current/functions-binarystring.html"><function>decode</function></link>
+		function converts a hexadecimal WKB string to the <type>bytea</type> value
+		accepted by <function>ST_GeomFromWKB</function>.</para>
+		<programlisting language="sql">SELECT ST_AsEWKT(ST_GeomFromWKB(
+    decode('0101000000e5d022dbf93e2e40dbf97e6abc743540', 'hex'),
+    4326
+)) AS geom;</programlisting>
+<screen role="text-primary">SRID=4326;POINT(15.123 21.456)</screen>
 	  </refsection>
 	  <!-- Optionally add a "See Also" section -->
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="ST_WKBToSQL"/>, <xref linkend="ST_AsBinary"/>, <xref linkend="ST_GeomFromEWKB"/></para>
+		<para><xref linkend="ST_WKBToSQL"/>, <xref linkend="ST_AsBinary"/>, <xref linkend="ST_AsEWKT"/>, <xref linkend="ST_GeomFromEWKB"/></para>
 	  </refsection>
 	</refentry>
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 0cf95ff22e..bdb9b938c3 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -269,6 +269,16 @@
 <screen role="text-primary">\x000000000300000001000000050000000000000000000000000000000000000000000000003ff000
 00000000003ff00000000000003ff00000000000003ff00000000000000000000000000000000000
 00000000000000000000000000</screen>
+      <para>Use the PostgreSQL <link xlink:href="https://www.postgresql.org/docs/current/functions-binarystring.html"><function>encode</function></link>
+      function to produce a hexadecimal WKB string without the <literal>\x</literal>
+      prefix used for <type>bytea</type> display. Specifying <literal>NDR</literal>
+      makes the byte order deterministic.</para>
+      <programlisting language="sql">SELECT encode(
+    ST_AsBinary('POINT(15.123 21.456)'::geometry, 'NDR'),
+    'hex'
+) AS wkb_hex;</programlisting>
+<screen role="text-primary">0101000000e5d022dbf93e2e40dbf97e6abc743540</screen>
       </refsection>
Summary of changes:
 doc/extras_topology.xml  | 85 ++++++++++++++++++++++++++++++++++++++++++++++++
 doc/reference_input.xml  | 11 ++++++-
 doc/reference_output.xml | 10 ++++++
 3 files changed, 105 insertions(+), 1 deletion(-)
hooks/post-receive
