[PostGIS] #6078: Improve "raster_overviews" definition
PostGIS trac at osgeo.org
Mon Jun 1 03:25:23 PDT 2026
 Reporter:  Laurenz Albe  |      Owner:  pramsey
     Type:  enhancement   |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.6.3
Component:  postgis       |    Version:  3.6.x
 Keywords:                |
 A customer is having problems with the query
 #!sql
 SELECT o_table_name, overview_factor, o_raster_column, o_table_schema
 FROM raster_overviews
 WHERE r_table_schema = 'some_schema'
   AND r_table_name = 'some_table'
   AND r_raster_column = 'some_column'
 ORDER BY overview_factor;
 The execution plan is as follows:
  Sort  (cost=17083.32..17083.33 rows=1 width=196) (actual
 time=9455.757..9455.762 rows=9 loops=1)
    Sort Key: ((TRIM(BOTH FROM
 split_part(pg_get_constraintdef(pg_constraint.oid), ','::text,
 2)))::integer)
    Sort Method: quicksort  Memory: 27kB
    Buffers: shared hit=1476736
    ->  Nested Loop  (cost=9.28..17083.31 rows=1 width=196) (actual
 time=45.400..9455.729 rows=9 loops=1)
          Join Filter: (c.relnamespace = pg_constraint.connamespace)
          Buffers: shared hit=1476733
          ->  Nested Loop  (cost=8.86..17081.96 rows=1 width=208) (actual
 time=1.561..314.613 rows=15113 loops=1)
                Join Filter: (c.relnamespace = n.oid)
                Rows Removed by Join Filter: 120840
                Buffers: shared hit=146994
                ->  Nested Loop  (cost=8.86..17080.62 rows=1 width=140)
 (actual time=1.554..268.991 rows=15113 loops=1)
                      Buffers: shared hit=131881
                      ->  Hash Join  (cost=8.44..17072.13 rows=16 width=68)
 (actual time=0.317..160.670 rows=15115 loops=1)
                            Hash Cond: (a.atttypid = t.oid)
                            Buffers: shared hit=10941
                            ->  Seq Scan on pg_attribute a
 (cost=0.00..15789.68 rows=485268 width=72) (actual time=0.007..125.174
 rows=488960 loops=1)
                                  Filter: (NOT attisdropped)
                                  Buffers: shared hit=10937
                            ->  Hash  (cost=8.43..8.43 rows=1 width=4)
 (actual time=0.020..0.021 rows=1 loops=1)
                                  Buckets: 1024  Batches: 1  Memory Usage:
 9kB
                                  Buffers: shared hit=4
                                  ->  Index Scan using
 pg_type_typname_nsp_index on pg_type t  (cost=0.41..8.43 rows=1 width=4)
 (actual time=0.017..0.018 rows=1 loops=1)
                                        Index Cond: (typname =
 'raster'::name)
                      ->  Index Scan using pg_class_oid_index on pg_class c
 (cost=0.42..0.53 rows=1 width=72) (actual time=0.007..0.007 rows=1
 loops=15115)
                            Index Cond: (oid = a.attrelid)
                            Filter: ((NOT
 pg_is_other_temp_schema(relnamespace)) AND has_table_privilege(oid,
 'SELECT'::text) AND ((relkind)::text = ANY ('{r,v,m,f}'::text[])))
                            Rows Removed by Filter: 0
                            Buffers: shared hit=120940
                ->  Seq Scan on pg_namespace n  (cost=0.00..1.15 rows=15
 width=68) (actual time=0.001..0.001 rows=9 loops=15113)
                      Buffers: shared hit=15113
          ->  Index Scan using
 pg_constraint_conrelid_contypid_conname_index on pg_constraint
 (cost=0.42..1.33 rows=1 width=12) (actual time=0.604..0.605 rows=0
 loops=15113)
                Index Cond: (conrelid = a.attrelid)
                Filter: ((pg_get_constraintdef(oid) ~~
 '%_overview_constraint(%'::text) AND
 ((split_part(split_part(pg_get_constraintdef(oid), '''::name'::text, 1),
 ''''::text, 2))::name = 'some_schema'::name) AND
 ((split_part(split_part(pg_get_constraintdef(oid), '''::name'::text, 2),
 ((split_part(split_part(pg_get_constraintdef(oid), '''::name'::text, 3),
 ''''::text, 2))::name = 'some_column'::name))
                Rows Removed by Filter: 12
                Buffers: shared hit=1329703
  Planning:
    Buffers: shared hit=387
  Planning Time: 1.658 ms
  Execution Time: 9455.844 ms
 The problematic part is
 ->  Hash Join  (... rows=16 ...) (actual ... rows=15115 ...)
       ->  Seq Scan on pg_attribute a  (... rows=485268 ...) (actual ...
 rows=488960 ...)
       ->  Hash  (... rows=1 ...) (actual ... rows=1 ...)
             Buckets: 1024  Batches: 1  Memory Usage: 9kB
             ->  Index Scan using pg_type_typname_nsp_index on pg_type t
                   Index Cond: (typname = 'raster'::name)
 The estimates on both {{{pg_attribute}}} and {{{pg_type}}} are correct,
 but the row count estimate on the join is horribly off. This causes
 PostgreSQL to choose a nested loop join, which is the cause of the bad
 performance.
 The underlying reason for the bad estimate is that PostgreSQL cannot tell
 at query planning time what the OID of the {{{raster}}} type is going to
 be, so it cannot use the statistics on {{{pg_attribute}}} that would tell
 it how many {{{raster}}} columns there are.
 I looked at the definition of {{{raster_overviews}}}, and the join with
 {{{pg_type}}} is unnecessary. Instead, you can use the {{{regtype}}}
 pseudo-type (that has been around since 2002) to directly query
 {{{pg_attribute}}}.
 So the following patch would simplify the view definition and would
 additionally give better estimates:
 #!diff
 diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
 index 566a23b86..b02018c4b 100644
 --- a/raster/rt_pg/rtpostgis.sql.in
 +++ b/raster/rt_pg/rtpostgis.sql.in
 @@ -8448,13 +8448,11 @@ CREATE OR REPLACE VIEW raster_overviews AS
         FROM
                 pg_class c,
                 pg_attribute a,
 -               pg_type t,
                 pg_namespace n,
                 (SELECT connamespace, conrelid, conkey,
 pg_get_constraintdef(oid) As consrc
                     FROM pg_constraint) AS s
 -       WHERE t.typname = 'raster'::name
 -               AND a.attisdropped = false
 -               AND a.atttypid = t.oid
 +       WHERE a.attisdropped = false
 +               AND a.atttypid = 'raster'::regtype
                 AND a.attrelid = c.oid
                 AND c.relnamespace = n.oid
                 AND c.relkind = ANY(ARRAY['r'::char, 'v'::char, 'm'::char,
 'f'::char])
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6078>
