[SCM] PostGIS branch master updated. 3.6.0rc2-495-gc9bdc50fb
Thu Jun 4 09:33:47 PDT 2026
the project "PostGIS".
       via  c9bdc50fbdaac675ef784463df1849e27d447872 (commit)
      from  7761433a55ce7445282798f018d57819f44dc319 (commit)
revisions in full, below.
commit c9bdc50fbdaac675ef784463df1849e27d447872
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 4 09:32:40 2026 -0700
    Change target target reskew calculation from an iterative
    process to a deterministic calculation. Closes #5854.
    References #5918.
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index 6847319cf..618d1292d 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -1544,21 +1544,17 @@ rt_errorstate rt_raster_get_perimeter(
  * Compute skewed extent that covers unskewed extent.
- * @param envelope : unskewed extent of type rt_envelope
- * @param skew : pointer to 2-element array (x, y) of skew
- * @param scale : pointer to 2-element array (x, y) of scale
- * @param tolerance : value between 0 and 1 where the smaller the tolerance
- * results in an extent approaching the "minimum" skewed extent.
- * If value <= 0, tolerance = 0.1.  If value > 1, tolerance = 1.
+ * @param extent : unskewed extent of type rt_envelope
+ * @param skew   : pointer to 2-element array {skew_x, skew_y}
+ * @param scale  : pointer to 2-element array {fabs(scale_x), fabs(scale_y)}
- * @return skewed raster who's extent covers unskewed extent, NULL on error
+ * @return skewed raster whose extent covers unskewed extent, NULL on error
 rt_raster
 rt_raster_compute_skewed_raster(
 	rt_envelope extent,
 	double *skew,
-	double *scale,
-	double tolerance
+	double *scale
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index 99578fe87..3ce611261 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -854,381 +854,96 @@ rt_raster_get_envelope(
- * Compute skewed extent that covers unskewed extent.
+ * Compute skewed raster extent that covers the given unskewed extent.
+ * Uses a direct linear-algebra solution rather than an iterative approach.
 rt_raster
 	rt_envelope extent,
 	double *skew,
-	double *scale,
-	double tolerance
+	double *scale
-	uint32_t run = 0;
-	uint32_t max_run = 1;
-	double dbl_run = 0;
-	int rtn;
-	int covers = 0;
+	double sx, syg, kx, ky, det;
+	double col_nums[4], row_nums[4];
+	double col_min, col_max, row_min, row_max;
+	double K1, K2, eps;
+	double ulx, uly;
+	int width, height;
 	rt_raster raster;
-	double _gt[6] = {0};
-	double _igt[6] = {0};
-	int _d[2] = {1, -1};
-	int _dlast = 0;
-	int _dlastpos = 0;
-	double _w[2] = {0};
-	double _r[2] = {0};
-	double _xy[2] = {0};
 	int i;
-	int j;
-	int x;
-	int y;
-	LWGEOM *geom = NULL;
-	GEOSGeometry *sgeom = NULL;
-	GEOSGeometry *ngeom = NULL;
-	if (
-		(tolerance < 0.) ||
-		FLT_EQ(tolerance, 0.)
-		tolerance = 0.1;
-	else if (tolerance > 1.)
-		tolerance = 1;
-	dbl_run = tolerance;
-	while (dbl_run < 10) {
-		dbl_run *= 10.;
-		max_run *= 10;
-	/* scale must be provided */
-	if (scale == NULL)
+	if (scale == NULL || skew == NULL)
 		return NULL;
-	for (i = 0; i < 2; i++) {
-		if (FLT_EQ(scale[i], 0.0))
-			rterror("rt_raster_compute_skewed_raster: Scale cannot be zero");
-			return 0;
-		if (i < 1)
-			_gt[1] = fabs(scale[i] * tolerance);
-		else
-			_gt[5] = fabs(scale[i] * tolerance);
-	/* conform scale-y to be negative */
-	_gt[5] *= -1;
-	/* skew not provided or skew is zero, return raster of correct dim and spatial attributes */
-	if ((skew == NULL) || (FLT_EQ(skew[0], 0.0) && FLT_EQ(skew[1], 0.0)))
-		int _dim[2] = {
-			(int) fmax((fabs(extent.MaxX - extent.MinX) + (fabs(scale[0]) / 2.)) / fabs(scale[0]), 1),
-			(int) fmax((fabs(extent.MaxY - extent.MinY) + (fabs(scale[1]) / 2.)) / fabs(scale[1]), 1)
-		raster = rt_raster_new(_dim[0], _dim[1]);
-		if (raster == NULL) {
-			rterror("rt_raster_compute_skewed_raster: Could not create output raster");
-			return NULL;
-		rt_raster_set_offsets(raster, extent.MinX, extent.MaxY);
-		rt_raster_set_scale(raster, fabs(scale[0]), -1 * fabs(scale[1]));
-		rt_raster_set_skews(raster, skew[0], skew[1]);
-		return raster;
-	/* direction to shift upper-left corner */
-	if (skew[0] > 0.)
-		_d[0] = -1;
-	if (skew[1] < 0.)
-		_d[1] = 1;
-	/* geotransform */
-	_gt[0] = extent.UpperLeftX;
-	_gt[2] = skew[0] * tolerance;
-	_gt[3] = extent.UpperLeftY;
-	_gt[4] = skew[1] * tolerance;
-	RASTER_DEBUGF(4, "Initial geotransform: %f, %f, %f, %f, %f, %f",
-		_gt[0], _gt[1], _gt[2], _gt[3], _gt[4], _gt[5]
-	RASTER_DEBUGF(4, "Delta: %d, %d", _d[0], _d[1]);
-	/* simple raster */
-	if ((raster = rt_raster_new(1, 1)) == NULL) {
-		rterror("rt_raster_compute_skewed_raster: Out of memory allocating extent raster");
-		return NULL;
-	rt_raster_set_geotransform_matrix(raster, _gt);
-	/* get inverse geotransform matrix */
-	if (!GDALInvGeoTransform(_gt, _igt)) {
-		rterror("rt_raster_compute_skewed_raster: Could not compute inverse geotransform matrix");
-		rt_raster_destroy(raster);
-		return NULL;
-	RASTER_DEBUGF(4, "Inverse geotransform: %f, %f, %f, %f, %f, %f",
-		_igt[0], _igt[1], _igt[2], _igt[3], _igt[4], _igt[5]
-	/* shift along axis */
-		covers = 0;
-		run = 0;
-		RASTER_DEBUGF(3, "Shifting along %s axis", i < 1 ? "X" : "Y");
-		do {
-			/* prevent possible infinite loop */
-			if (run > max_run) {
-				rterror("rt_raster_compute_skewed_raster: Could not compute skewed extent due to check preventing infinite loop");
-				return NULL;
-				check the four corners that they are covered along the specific axis
-				pixel column should be >= 0
-			for (j = 0; j < 4; j++) {
-				switch (j) {
-					/* upper-left */
-					case 0:
-						_xy[0] = extent.MinX;
-						_xy[1] = extent.MaxY;
-						break;
-					/* lower-left */
-					case 1:
-						_xy[1] = extent.MinY;
-						break;
-					/* lower-right */
-					case 2:
-						_xy[0] = extent.MaxX;
-						break;
-					/* upper-right */
-					case 3:
-						break;
-				rtn = rt_raster_geopoint_to_cell(
-					raster,
-					_xy[0], _xy[1],
-					&(_r[0]), &(_r[1]),
-					_igt
-				if (rtn != ES_NONE) {
-					rterror("rt_raster_compute_skewed_raster: Could not compute raster pixel for spatial coordinates");
-					return NULL;
-				RASTER_DEBUGF(4, "Point %d at cell %d x %d", j, (int) _r[0], (int) _r[1]);
-				/* raster doesn't cover point */
-				if ((int) _r[i] < 0) {
-					RASTER_DEBUGF(4, "Point outside of skewed extent: %d", j);
-					covers = 0;
-					if (_dlastpos != j) {
-						_dlast = (int) _r[i];
-						_dlastpos = j;
-					else if ((int) _r[i] < _dlast) {
-						RASTER_DEBUG(4, "Point going in wrong direction.  Reversing direction");
-						_d[i] *= -1;
-						_dlastpos = -1;
-						run = 0;
-					break;
-				covers++;
-			if (!covers) {
-				x = 0;
-				y = 0;
-				if (i < 1)
-					x = _d[i] * fabs(_r[i]);
-				else
-					y = _d[i] * fabs(_r[i]);
-				rtn = rt_raster_cell_to_geopoint(
-					raster,
-					x, y,
-					&(_w[0]), &(_w[1]),
-					_gt
-					rterror("rt_raster_compute_skewed_raster: Could not compute spatial coordinates for raster pixel");
-					return NULL;
-				/* adjust ul */
-				if (i < 1)
-					_gt[0] = _w[i];
-				else
-					_gt[3] = _w[i];
-				RASTER_DEBUGF(4, "Shifted geotransform: %f, %f, %f, %f, %f, %f",
-					return NULL;
-			run++;
-		while (!covers);
-	/* covers test */
-		raster,
-		extent.MaxX, extent.MinY,
-		_igt
+	if (FLT_EQ(scale[0], 0.0) || FLT_EQ(scale[1], 0.0)) {
+		rterror("rt_raster_compute_skewed_raster: Scale cannot be zero");
 		return NULL;
-	RASTER_DEBUGF(4, "geopoint %f x %f at cell %d x %d", extent.MaxX, extent.MinY, (int) _r[0], (int) _r[1]);
+	sx  = fabs(scale[0]);
+	syg = -fabs(scale[1]);   /* gt[5]: negative for north-up */
+	kx  = skew[0];
+	ky  = skew[1];
+	det = sx * syg - kx * ky;
-	raster->width = _r[0];
-	raster->height = _r[1];
-	/* initialize GEOS */
-	initGEOS(rtinfo, lwgeom_geos_error);
-	/* create reference LWPOLY */
-		LWPOLY *npoly = rt_util_envelope_to_lwpoly(extent);
-		if (npoly == NULL) {
-			rterror("rt_raster_compute_skewed_raster: Could not build extent's geometry for covers test");
-			return NULL;
-		ngeom = (GEOSGeometry *) LWGEOM2GEOS(lwpoly_as_lwgeom(npoly), 0);
-		lwpoly_free(npoly);
+	if (FLT_EQ(det, 0.0)) {
+		rterror("rt_raster_compute_skewed_raster: Degenerate geotransform (determinant is zero)");
+		return NULL;
-	do {
-		covers = 0;
-		/* construct sgeom from raster */
-		if ((rt_raster_get_convex_hull(raster, &geom) != ES_NONE) || geom == NULL) {
-			rterror("rt_raster_compute_skewed_raster: Could not build skewed extent's geometry for covers test");
-			GEOSGeom_destroy(ngeom);
-			return NULL;
-		sgeom = (GEOSGeometry *) LWGEOM2GEOS(geom, 0);
-		lwgeom_free(geom);
-		covers = GEOSRelatePattern(sgeom, ngeom, "******FF*");
-		GEOSGeom_destroy(sgeom);
-		if (covers == 2) {
-			rterror("rt_raster_compute_skewed_raster: Could not run covers test");
-			return NULL;
-		if (!covers)
-			raster->width++;
-			raster->height++;
-	while (!covers);
-	RASTER_DEBUGF(4, "Skewed extent does cover normal extent with dimensions %d x %d", raster->width, raster->height);
-	raster->width = (int) ((((double) raster->width) * fabs(_gt[1]) + fabs(scale[0] / 2.)) / fabs(scale[0]));
-	raster->height = (int) ((((double) raster->height) * fabs(_gt[5]) + fabs(scale[1] / 2.)) / fabs(scale[1]));
-	_gt[1] = fabs(scale[0]);
-	_gt[5] = -1 * fabs(scale[1]);
-	_gt[2] = skew[0];
-	_gt[4] = skew[1];
-	/* minimize width/height */
-		covers = 1;
-		do {
-			if (i < 1)
-				raster->width--;
-			else
-				raster->height--;
-				rterror("rt_raster_compute_skewed_raster: Could not build skewed extent's geometry for minimizing dimensions");
-				return NULL;
-				rterror("rt_raster_compute_skewed_raster: Could not run covers test for minimizing dimensions");
-				return NULL;
-		} while (covers);
-		if (i < 1)
-			raster->width++;
-		else
-			raster->height++;
+	/* col_num(x,y) = syg*x - kx*y,  row_num(x,y) = -ky*x + sx*y */
+	col_nums[0] = syg * extent.MinX - kx * extent.MaxY;
+	col_nums[1] = syg * extent.MaxX - kx * extent.MaxY;
+	col_nums[2] = syg * extent.MaxX - kx * extent.MinY;
+	col_nums[3] = syg * extent.MinX - kx * extent.MinY;
+	row_nums[0] = -ky * extent.MinX + sx * extent.MaxY;
+	row_nums[1] = -ky * extent.MaxX + sx * extent.MaxY;
+	row_nums[2] = -ky * extent.MaxX + sx * extent.MinY;
+	row_nums[3] = -ky * extent.MinX + sx * extent.MinY;
+	col_min = col_max = col_nums[0];
+	row_min = row_max = row_nums[0];
+	for (i = 1; i < 4; i++) {
+		if (col_nums[i] < col_min) col_min = col_nums[i];
+		if (col_nums[i] > col_max) col_max = col_nums[i];
+		if (row_nums[i] < row_min) row_min = row_nums[i];
+		if (row_nums[i] > row_max) row_max = row_nums[i];
+	K1 = (det < 0.0) ? col_max : col_min;
+	K2 = (det < 0.0) ? row_max : row_min;
+	/* Tiny safety margin so FP rounding can't place boundary corners just outside */
+	eps = (fabs(K1) + fabs(K2) + fabs(det)) * DBL_EPSILON * 16.0;
+	if (det < 0.0) { K1 += eps; K2 += eps; }
+	else           { K1 -= eps; K2 -= eps; }
+	/* Solve: syg*ulx - kx*uly = K1,  -ky*ulx + sx*uly = K2 */
+	ulx = (sx  * K1 + kx  * K2) / det;
+	uly = (ky  * K1 + syg * K2) / det;
+	width  = (int)floor((col_max - col_min) / fabs(det)) + 1;
+	height = (int)floor((row_max - row_min) / fabs(det)) + 1;
+	raster = rt_raster_new(width, height);
+	if (raster == NULL) {
+		rterror("rt_raster_compute_skewed_raster: Could not create output raster");
+		return NULL;
+	rt_raster_set_offsets(raster, ulx, uly);
+	rt_raster_set_scale(raster, fabs(scale[0]), -fabs(scale[1]));
+	rt_raster_set_skews(raster, skew[0], skew[1]);
 	return raster;
  * Return TRUE if the raster is empty. i.e. is NULL, width = 0 or height = 0
@@ -2749,8 +2464,7 @@ rt_raster_gdal_rasterize(
 		skewedrast = rt_raster_compute_skewed_raster(
 			extent,
 			_skew,
-			_scale,
-			0.01
+			_scale
 		if (skewedrast == NULL) {
 			rterror("rt_raster_gdal_rasterize: Could not compute skewed raster");
diff --git a/raster/rt_core/rt_warp.c b/raster/rt_core/rt_warp.c
index 59110feec..f5854fd0f 100644
--- a/raster/rt_core/rt_warp.c
+++ b/raster/rt_core/rt_warp.c
@@ -145,34 +145,9 @@ _rti_warp_arg_destroy(_rti_warp_arg arg) {
- * Return a warped raster using GDAL Warp API
- * @param raster : raster to transform
- * @param src_srs : the raster's coordinate system in OGC WKT
- * @param dst_srs : the warped raster's coordinate system in OGC WKT
- * @param scale_x : the x size of pixels of the warped raster's pixels in
- *   units of dst_srs
- * @param scale_y : the y size of pixels of the warped raster's pixels in
- * @param width : the number of columns of the warped raster.  note that
- *   width/height CANNOT be used with scale_x/scale_y
- * @param height : the number of rows of the warped raster.  note that
- * @param ul_xw : the X value of upper-left corner of the warped raster in
- * @param ul_yw : the Y value of upper-left corner of the warped raster in
- * @param grid_xw : the X value of point on a grid to align warped raster
- *   to in units of dst_srs
- * @param grid_yw : the Y value of point on a grid to align warped raster
- * @param skew_x : the X skew of the warped raster in units of dst_srs
- * @param skew_y : the Y skew of the warped raster in units of dst_srs
- * @param resample_alg : the resampling algorithm
- * @param max_err : maximum error measured in input pixels permitted
- *   (0.0 for exact calculations)
- * @return the warped raster or NULL
+ * Return a warped raster using GDAL Warp API.
+ * When non-zero skew values are requested, the output extent is computed
+ * via rt_raster_compute_skewed_raster().
 rt_raster rt_raster_gdal_warp(
 	rt_raster raster,
@@ -207,103 +182,64 @@ rt_raster rt_raster_gdal_warp(
 	int i = 0;
 	int numBands = 0;
-	/* flag indicating that the spatial info is being substituted */
 	int subspatial = 0;
-	RASTER_DEBUG(3, "starting");
+	RASTER_DEBUG(3, "rt_raster_gdal_warp: starting");
 	assert(NULL != raster);
-	/* internal variables */
 	arg = _rti_warp_arg_init();
 	if (arg == NULL) {
 		rterror("rt_raster_gdal_warp: Could not initialize internal variables");
 		return NULL;
-		max_err must be gte zero
-		the value 0.125 is the default used in gdalwarp.cpp on line 283
 	if (max_err < 0.) max_err = 0.125;
-	RASTER_DEBUGF(4, "max_err = %f", max_err);
 	/* handle srs */
 	if (src_srs != NULL) {
-		/* reprojection taking place */
 		if (dst_srs != NULL && strcmp(src_srs, dst_srs) != 0) {
-			RASTER_DEBUG(4, "Warp operation does include a reprojection");
+			RASTER_DEBUG(4, "rt_raster_gdal_warp: Warp includes reprojection");
 			arg->src.srs = rt_util_gdal_convert_sr(src_srs, 0);
 			arg->dst.srs = rt_util_gdal_convert_sr(dst_srs, 0);
 			if (arg->src.srs == NULL || arg->dst.srs == NULL) {
 				rterror("rt_raster_gdal_warp: Could not convert srs values to GDAL accepted format");
 				_rti_warp_arg_destroy(arg);
 				return NULL;
-		/* no reprojection, a stub just for clarity */
-		else {
-			RASTER_DEBUG(4, "Warp operation does NOT include reprojection");
 	else if (dst_srs != NULL) {
-		/* dst_srs provided but not src_srs */
 		rterror("rt_raster_gdal_warp: SRS required for input raster if SRS provided for warped raster");
 		return NULL;
-	/* load raster into a GDAL MEM dataset */
+	/* load raster into GDAL MEM dataset */
 	arg->src.ds = rt_raster_to_gdal_mem(raster, arg->src.srs, NULL, NULL, 0, &(arg->src.drv), &(arg->src.destroy_drv));
 	if (NULL == arg->src.ds) {
 		rterror("rt_raster_gdal_warp: Could not convert raster to GDAL MEM format");
 		return NULL;
-	RASTER_DEBUG(3, "raster loaded into GDAL MEM dataset");
-	/* special case when src_srs and dst_srs is NULL and raster's geotransform matrix is default */
+	/* special case: default geotransform raster with no SRS */
 	if (
 		src_srs == NULL && dst_srs == NULL &&
 		rt_raster_get_srid(raster) == SRID_UNKNOWN
 		double gt[6];
-#if POSTGIS_DEBUG_LEVEL > 3
-		GDALGetGeoTransform(arg->src.ds, gt);
-		RASTER_DEBUGF(3, "GDAL MEM geotransform: %f, %f, %f, %f, %f, %f",
-			gt[0], gt[1], gt[2], gt[3], gt[4], gt[5]);
-#endif
-		/* default geotransform */
 		rt_raster_get_geotransform_matrix(raster, gt);
-		RASTER_DEBUGF(3, "raster geotransform: %f, %f, %f, %f, %f, %f",
-		/* substitute spatial info (lack of) with a real one EPSG:32731 (WGS84/UTM zone 31s) */
 		if (FLT_EQ(gt[0], 0.0) && FLT_EQ(gt[3], 0.0) && FLT_EQ(gt[1], 1.0) && FLT_EQ(gt[5], -1.0) &&
 		    FLT_EQ(gt[2], 0.0) && FLT_EQ(gt[4], 0.0))
 			double ngt[6] = {166021.4431, 0.1, 0, 10000000.0000, 0, -0.1};
 			rtwarn("Raster has default geotransform. Adjusting metadata for use of GDAL Warp API");
 			subspatial = 1;
 			GDALSetGeoTransform(arg->src.ds, ngt);
 			GDALFlushCache(arg->src.ds);
-			/* EPSG:32731 */
 			arg->src.srs = rt_util_gdal_convert_sr("EPSG:32731", 0);
 			arg->dst.srs = rt_util_gdal_convert_sr("EPSG:32731", 0);
-#endif
@@ -312,7 +248,7 @@ rt_raster rt_raster_gdal_warp(
 		arg->transform.option.len = 2;
 		arg->transform.option.item = rtalloc(sizeof(char *) * (arg->transform.option.len + 1));
 		if (NULL == arg->transform.option.item) {
-			rterror("rt_raster_gdal_warp: Could not allocation memory for transform options");
+			rterror("rt_raster_gdal_warp: Could not allocate memory for transform options");
 			return NULL;
@@ -322,15 +258,14 @@ rt_raster rt_raster_gdal_warp(
 			const char *srs = i ? arg->dst.srs : arg->src.srs;
 			const char *lbl = i ? "DST_SRS=" : "SRC_SRS=";
 			size_t sz = sizeof(char) * (strlen(lbl) + 1);
-			if ( srs ) sz += strlen(srs);
+			if (srs) sz += strlen(srs);
 			arg->transform.option.item[i] = (char *) rtalloc(sz);
 			if (NULL == arg->transform.option.item[i]) {
 				return NULL;
 			sprintf(arg->transform.option.item[i], "%s%s", lbl, srs ? srs : "");
-			RASTER_DEBUGF(4, "arg->transform.option.item[%d] = %s", i, arg->transform.option.item[i]);
 	else
@@ -339,7 +274,7 @@ rt_raster rt_raster_gdal_warp(
 	/* transformation object for building dst dataset */
 	arg->transform.arg.transform = GDALCreateGenImgProjTransformer2(arg->src.ds, NULL, arg->transform.option.item);
 	if (NULL == arg->transform.arg.transform) {
-		rterror("rt_raster_gdal_warp: Could not create GDAL transformation object for output dataset creation");
+		rterror("rt_raster_gdal_warp: Could not create GDAL transformation object");
 		return NULL;
@@ -349,70 +284,49 @@ rt_raster rt_raster_gdal_warp(
 		arg->src.ds, GDALGenImgProjTransform,
 		arg->transform.arg.transform, _gt, &(_dim[0]), &(_dim[1]), dst_extent, 0);
 	if (cplerr != CE_None) {
-		rterror("rt_raster_gdal_warp: Could not get GDAL suggested warp output for output dataset creation");
+		rterror("rt_raster_gdal_warp: Could not get GDAL suggested warp output");
 		return NULL;
 	GDALDestroyGenImgProjTransformer(arg->transform.arg.transform);
 	arg->transform.arg.transform = NULL;
-		don't use suggested dimensions as use of suggested scales
-		on suggested extent will result in suggested dimensions
 	_dim[0] = 0;
 	_dim[1] = 0;
-	RASTER_DEBUGF(3, "Suggested geotransform: %f, %f, %f, %f, %f, %f",
-		_gt[0], _gt[1], _gt[2], _gt[3], _gt[4], _gt[5]);
-	/* store extent in easier-to-use object */
 	extent.MinX = dst_extent[0];
 	extent.MinY = dst_extent[1];
 	extent.MaxX = dst_extent[2];
 	extent.MaxY = dst_extent[3];
 	extent.UpperLeftX = dst_extent[0];
 	extent.UpperLeftY = dst_extent[3];
-	RASTER_DEBUGF(3, "Suggested extent: %f, %f, %f, %f",
-		extent.MinX, extent.MinY, extent.MaxX, extent.MaxY);
 	/* scale and width/height are mutually exclusive */
 	if (
 		((NULL != scale_x) || (NULL != scale_y)) &&
 		((NULL != width) || (NULL != height))
-		rterror("rt_raster_gdal_warp: Scale X/Y and width/height are mutually exclusive.  Only provide one");
+		rterror("rt_raster_gdal_warp: Scale X/Y and width/height are mutually exclusive");
 		return NULL;
-	/* user-defined width */
 	if (NULL != width) {
 		_dim[0] = abs(*width);
 		_scale[0] = fabs((extent.MaxX - extent.MinX) / ((double) _dim[0]));
-	/* user-defined height */
 	if (NULL != height) {
 		_dim[1] = abs(*height);
 		_scale[1] = fabs((extent.MaxY - extent.MinY) / ((double) _dim[1]));
-	/* user-defined scale */
 	if (
 		((NULL != scale_x) && (FLT_NEQ(*scale_x, 0.0))) &&
 		((NULL != scale_y) && (FLT_NEQ(*scale_y, 0.0)))
 		_scale[0] = fabs(*scale_x);
 		_scale[1] = fabs(*scale_y);
-		/* special override since we changed the original GT scales */
 		if (subspatial) {
-			_scale[0] *= 10;
-			_scale[1] *= 10;
 			_scale[0] /= 10;
 			_scale[1] /= 10;
@@ -421,83 +335,59 @@ rt_raster rt_raster_gdal_warp(
 		((NULL != scale_x) && (NULL == scale_y)) ||
 		((NULL == scale_x) && (NULL != scale_y))
-		rterror("rt_raster_gdal_warp: Both X and Y scale values must be provided for scale");
+		rterror("rt_raster_gdal_warp: Both X and Y scale values must be provided");
 		return NULL;
-	/* scale not defined, use suggested */
-	if (FLT_EQ(_scale[0], 0.0) && FLT_EQ(_scale[1], 0.0))
+	/* scale not defined: use suggested */
+	if (FLT_EQ(_scale[0], 0.0) && FLT_EQ(_scale[1], 0.0)) {
 		_scale[0] = fabs(_gt[1]);
 		_scale[1] = fabs(_gt[5]);
-	RASTER_DEBUGF(4, "Using scale: %f x %f", _scale[0], -1 * _scale[1]);
+	RASTER_DEBUGF(4, "rt_raster_gdal_warp: Using scale: %f x %f", _scale[0], -1 * _scale[1]);
-	/* user-defined skew */
+	/* skew */
 	if (NULL != skew_x) {
 		_skew[0] = *skew_x;
-			negative scale-x affects skew
-			for now, force skew to be in left-right, top-down orientation
-		if (
-			NULL != scale_x &&
-			*scale_x < 0.
+		if (NULL != scale_x && *scale_x < 0.)
 			_skew[0] *= -1;
 	if (NULL != skew_y) {
 		_skew[1] = *skew_y;
-			positive scale-y affects skew
-		if (
-			NULL != scale_y &&
-			*scale_y > 0.
+		if (NULL != scale_y && *scale_y > 0)
 			_skew[1] *= -1;
-	RASTER_DEBUGF(4, "Using skew: %f x %f", _skew[0], _skew[1]);
+	RASTER_DEBUGF(4, "rt_raster_gdal_warp: Using skew: %f x %f", _skew[0], _skew[1]);
-	/* reprocess extent if skewed */
-	if (FLT_NEQ(_skew[0], 0.0) || FLT_NEQ(_skew[1], 0.0))
+	/* Compute the output grid parameters when skew is requested. */
+	if (FLT_NEQ(_skew[0], 0.0) || FLT_NEQ(_skew[1], 0.0)) {
 		rt_raster skewedrast;
-		RASTER_DEBUG(3, "Computing skewed extent's envelope");
+		RASTER_DEBUG(3, "rt_raster_gdal_warp: Computing skewed extent");
-		skewedrast = rt_raster_compute_skewed_raster(
-			extent,
-			_skew,
-			_scale,
-			0.01
+		skewedrast = rt_raster_compute_skewed_raster(extent, _skew, _scale);
-			rterror("rt_raster_gdal_warp: Could not compute skewed raster");
+			rterror("rt_raster_gdal_warp: Could not compute skewed extent");
 			return NULL;
-		if (_dim[0] == 0)
-			_dim[0] = skewedrast->width;
-		if (_dim[1] == 0)
-			_dim[1] = skewedrast->height;
+		if (_dim[0] == 0) _dim[0] = rt_raster_get_width(skewedrast);
+		if (_dim[1] == 0) _dim[1] = rt_raster_get_height(skewedrast);
-		extent.UpperLeftX = skewedrast->ipX;
-		extent.UpperLeftY = skewedrast->ipY;
+		extent.UpperLeftX = rt_raster_get_x_offset(skewedrast);
+		extent.UpperLeftY = rt_raster_get_y_offset(skewedrast);
+		RASTER_DEBUGF(3, "rt_raster_gdal_warp: Skewed extent: UL=(%f,%f) dim=%dx%d",
+			extent.UpperLeftX, extent.UpperLeftY, _dim[0], _dim[1]);
 		rt_raster_destroy(skewedrast);
-	/* dimensions not defined, compute */
+	/* dimensions not defined, compute from extent */
 	if (!_dim[0])
 		_dim[0] = (int) fmax((fabs(extent.MaxX - extent.MinX) + (_scale[0] / 2.)) / _scale[0], 1);
 	if (!_dim[1])
@@ -517,21 +407,12 @@ rt_raster rt_raster_gdal_warp(
 	rt_raster_set_skews(rast, _skew[0], _skew[1]);
 	rt_raster_get_geotransform_matrix(rast, _gt);
-	RASTER_DEBUGF(3, "Temp raster's geotransform: %f, %f, %f, %f, %f, %f",
+	RASTER_DEBUGF(3, "rt_raster_gdal_warp: Temp raster geotransform: %f,%f,%f,%f,%f,%f",
-	RASTER_DEBUGF(3, "Temp raster's dimensions (width x height): %d x %d",
-		_dim[0], _dim[1]);
 	/* user-defined upper-left corner */
-	if (
-		NULL != ul_xw &&
-		NULL != ul_yw
+	if (NULL != ul_xw && NULL != ul_yw) {
 		ul_user = 1;
-		RASTER_DEBUGF(4, "Using user-specified upper-left corner: %f, %f", *ul_xw, *ul_yw);
-		/* set upper-left corner */
 		rt_raster_set_offsets(rast, *ul_xw, *ul_yw);
 		extent.UpperLeftX = *ul_xw;
 		extent.UpperLeftY = *ul_yw;
@@ -599,7 +480,6 @@ rt_raster rt_raster_gdal_warp(
 				NULL
 			) != ES_NONE) {
 				rterror("rt_raster_gdal_warp: Could not compute spatial coordinates for raster pixel");
 				rt_raster_destroy(rast);
 				return NULL;
@@ -646,7 +526,6 @@ rt_raster rt_raster_gdal_warp(
 						NULL
 					) != ES_NONE) {
 						return NULL;
@@ -662,68 +541,35 @@ rt_raster rt_raster_gdal_warp(
 		while (0);
-		after this point, rt_envelope extent is no longer used
-	/* get key attributes from rast */
+	/* get key attributes */
 	_dim[0] = rast->width;
 	_dim[1] = rast->height;
-	/* scale-x is negative or scale-y is positive */
-	if ((
-		(NULL != scale_x) && (*scale_x < 0.)
-		(NULL != scale_y) && (*scale_y > 0)
+	/* handle negative scale-x or positive scale-y (same as original) */
+	if ((NULL != scale_x && *scale_x < 0.) || (NULL != scale_y && *scale_y > 0)) {
 		double _w[2] = {0};
-		/* negative scale-x */
-		if (
-			(*scale_x < 0.)
-			if (rt_raster_cell_to_geopoint(
-				rast,
-				rast->width, 0,
-				NULL
-			) != ES_NONE) {
+		if (NULL != scale_x && *scale_x < 0.) {
+			if (rt_raster_cell_to_geopoint(rast, rast->width, 0, &(_w[0]), &(_w[1]), NULL) != ES_NONE) {
 				return NULL;
 			_gt[0] = _w[0];
 			_gt[1] = *scale_x;
-			/* check for skew */
 			if (NULL != skew_x && FLT_NEQ(*skew_x, 0.0))
 				_gt[2] = *skew_x;
-		/* positive scale-y */
-		if (
-			(*scale_y > 0)
-				rast,
-				0, rast->height,
-				NULL
-			) != ES_NONE) {
+		if (NULL != scale_y && *scale_y > 0) {
+			if (rt_raster_cell_to_geopoint(rast, 0, rast->height, &(_w[0]), &(_w[1]), NULL) != ES_NONE) {
 				return NULL;
 			_gt[3] = _w[1];
 			_gt[5] = *scale_y;
 			if (NULL != skew_y && FLT_NEQ(*skew_y, 0.0))
 				_gt[4] = *skew_y;
@@ -732,12 +578,11 @@ rt_raster rt_raster_gdal_warp(
 	rast = NULL;
-	RASTER_DEBUGF(3, "Applied geotransform: %f, %f, %f, %f, %f, %f",
+	RASTER_DEBUGF(3, "rt_raster_gdal_warp: Final geotransform: %f,%f,%f,%f,%f,%f",
-	RASTER_DEBUGF(3, "Raster dimensions (width x height): %d x %d",
+	RASTER_DEBUGF(3, "rt_raster_gdal_warp: Raster dimensions: %d x %d", _dim[0], _dim[1]);
-	if ( _dim[0] == 0 || _dim[1] == 0 ) {
+	if (_dim[0] == 0 || _dim[1] == 0) {
 		rterror("rt_raster_gdal_warp: The width (%d) or height (%d) of the warped raster is zero", _dim[0], _dim[1]);
 		return NULL;
@@ -745,7 +590,6 @@ rt_raster rt_raster_gdal_warp(
 	/* load VRT driver */
 	if (!rt_util_gdal_driver_registered("VRT")) {
-		RASTER_DEBUG(3, "Registering VRT driver");
 		GDALRegister_VRT();
 		arg->dst.destroy_drv = 1;
@@ -772,7 +616,6 @@ rt_raster rt_raster_gdal_warp(
 			return NULL;
-		RASTER_DEBUGF(3, "Applied SRS: %s", GDALGetProjectionRef(arg->dst.ds));
 	/* set dst geotransform */
@@ -783,7 +626,7 @@ rt_raster rt_raster_gdal_warp(
 		return NULL;
-	/* add bands to dst dataset */
+	/* add bands */
 	numBands = rt_raster_get_num_bands(raster);
 	for (i = 0; i < numBands; i++) {
 		rtband = rt_raster_get_band(raster, i);
@@ -805,8 +648,6 @@ rt_raster rt_raster_gdal_warp(
 			return NULL;
-		/* get band to write data to */
-		band = NULL;
 		band = GDALGetRasterBand(arg->dst.ds, i + 1);
 		if (NULL == band) {
 			rterror("rt_raster_gdal_warp: Could not get GDAL band for additional processing");
@@ -814,12 +655,10 @@ rt_raster rt_raster_gdal_warp(
 			return NULL;
-		/* set nodata */
 		if (rt_band_get_hasnodata_flag(rtband) != FALSE) {
 			rt_band_get_nodata(rtband, &nodata);
 			if (GDALSetRasterNoDataValue(band, nodata) != CE_None)
 				rtwarn("rt_raster_gdal_warp: Could not set nodata value for band %d", i);
-			RASTER_DEBUGF(3, "nodata value set to %f", GDALGetRasterNoDataValue(band, NULL));
@@ -835,7 +674,6 @@ rt_raster rt_raster_gdal_warp(
 	arg->transform.func = GDALGenImgProjTransform;
-	/* use approximate transformation object */
 	if (max_err > 0.0) {
 		arg->transform.arg.transform = arg->transform.arg.approx = GDALCreateApproxTransformer(
@@ -846,7 +684,6 @@ rt_raster rt_raster_gdal_warp(
 			return NULL;
 		arg->transform.func = GDALApproxTransform;
@@ -858,37 +695,25 @@ rt_raster rt_raster_gdal_warp(
 		return NULL;
-	/* set options */
 	arg->wopts->eResampleAlg = resample_alg;
 	arg->wopts->hSrcDS = arg->src.ds;
 	arg->wopts->hDstDS = arg->dst.ds;
 	arg->wopts->pfnTransformer = arg->transform.func;
 	arg->wopts->pTransformerArg = arg->transform.arg.transform;
 	arg->wopts->papszWarpOptions = (char **) CPLMalloc(sizeof(char *) * 2);
 	arg->wopts->papszWarpOptions[0] = (char *) CPLMalloc(sizeof(char) * (strlen("INIT_DEST=NO_DATA") + 1));
 	strcpy(arg->wopts->papszWarpOptions[0], "INIT_DEST=NO_DATA");
 	arg->wopts->papszWarpOptions[1] = NULL;
-	/* set band mapping */
+	/* band mapping */
 	arg->wopts->nBandCount = numBands;
 	arg->wopts->panSrcBands = (int *) CPLMalloc(sizeof(int) * arg->wopts->nBandCount);
 	arg->wopts->panDstBands = (int *) CPLMalloc(sizeof(int) * arg->wopts->nBandCount);
 	for (i = 0; i < arg->wopts->nBandCount; i++)
 		arg->wopts->panDstBands[i] = arg->wopts->panSrcBands[i] = i + 1;
-	* https://trac.osgeo.org/postgis/ticket/5881
-	* In order to call GDALWarp with BAND_INIT=NO_DATA we need to ensure
-	* that the src and dst rasters have nodata values and they are
-	* matched up nicely. This block used by tested with the hasnodata
-	* check on all src raster bands, but now we just do it every time
-	* because that makes sense (any warped raster is likely to have
-	* empty corners on output, and those corners need to be filled with
-	* some kind of NODATA value).
+	/* nodata mapping */
-		RASTER_DEBUG(3, "Setting nodata mapping");
 		arg->wopts->padfSrcNoDataReal = (double *) CPLMalloc(numBands * sizeof(double));
 		arg->wopts->padfDstNoDataReal = (double *) CPLMalloc(numBands * sizeof(double));
 		arg->wopts->padfSrcNoDataImag = (double *) CPLMalloc(numBands * sizeof(double));
@@ -910,68 +735,43 @@ rt_raster rt_raster_gdal_warp(
 				return NULL;
-			if (!rt_band_get_hasnodata_flag(band)) {
-					based on line 1004 of gdalwarp.cpp
-					the problem is that there is a chance that this number is a legitimate value
+			if (!rt_band_get_hasnodata_flag(band))
 				arg->wopts->padfSrcNoDataReal[i] = -123456.789;
-			else {
+			else
 				rt_band_get_nodata(band, &(arg->wopts->padfSrcNoDataReal[i]));
 			arg->wopts->padfDstNoDataReal[i] = arg->wopts->padfSrcNoDataReal[i];
 			arg->wopts->padfDstNoDataImag[i] = arg->wopts->padfSrcNoDataImag[i] = 0.0;
-			RASTER_DEBUGF(4, "Mapped nodata value for band %d: %f (%f) => %f (%f)",
-				i,
-				arg->wopts->padfSrcNoDataReal[i], arg->wopts->padfSrcNoDataImag[i],
-				arg->wopts->padfDstNoDataReal[i], arg->wopts->padfDstNoDataImag[i]
-	/* warp raster */
-	RASTER_DEBUG(3, "Warping raster");
+	/* warp */
 	cplerr = GDALInitializeWarpedVRT(arg->dst.ds, arg->wopts);
 		rterror("rt_raster_gdal_warp: Could not warp raster");
 		return NULL;
-	GDALSetDescription(arg->dst.ds, "/tmp/warped.vrt");
 	GDALFlushCache(arg->dst.ds);
-	RASTER_DEBUG(3, "Raster warped");
-	/* convert gdal dataset to raster */
-	RASTER_DEBUG(3, "Converting GDAL dataset to raster");
+	/* convert to raster */
 	rast = rt_raster_from_gdal_dataset(arg->dst.ds);
 	if (NULL == rast) {
-		rterror("rt_raster_gdal_warp: Could not warp raster");
+		rterror("rt_raster_gdal_warp: Could not convert warped dataset to raster");
 		return NULL;
-	/* substitute spatial, reset back to default */
+	/* reset spatial info for default-geotransform rasters */
 	if (subspatial) {
 		double gt[6] = {0, 1, 0, 0, 0, -1};
-		/* See http://trac.osgeo.org/postgis/ticket/2911 */
-		/* We should probably also tweak rotation here */
-		/* NOTE: the times 10 is because it was divided by 10 in a section above,
-		 *       I'm not sure the above division was needed */
 		gt[1] = _scale[0] * 10;
 		gt[5] = -1 * _scale[1] * 10;
 		rt_raster_set_geotransform_matrix(rast, gt);
 		rt_raster_set_srid(rast, SRID_UNKNOWN);
-	RASTER_DEBUG(3, "done");
+	RASTER_DEBUG(3, "rt_raster_gdal_warp: done");
 	return rast;
diff --git a/raster/test/cunit/cu_raster_misc.c b/raster/test/cunit/cu_raster_misc.c
index 90888a9aa..048749193 100644
--- a/raster/test/cunit/cu_raster_misc.c
+++ b/raster/test/cunit/cu_raster_misc.c
@@ -191,17 +191,14 @@ static void test_raster_compute_skewed_raster(void) {
 		extent,
 		skew,
-		scale,
-		0
+		scale
 	CU_ASSERT(rast != NULL);
-	/* Check disabled: See https://trac.osgeo.org/postgis/ticket/4379
-	 * CU_ASSERT_EQUAL(rt_raster_get_width(rast), 2);
+	CU_ASSERT_EQUAL(rt_raster_get_width(rast), 3);
 	CU_ASSERT_EQUAL(rt_raster_get_height(rast), 3);
-	CU_ASSERT_DOUBLE_EQUAL(rt_raster_get_x_offset(rast), -0.5, DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_raster_get_y_offset(rast), 0, DBL_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(rt_raster_get_x_offset(rast), -8.0/17.0, 1e-8);
+	CU_ASSERT_DOUBLE_EQUAL(rt_raster_get_y_offset(rast), -2.0/17.0, 1e-8);
 	cu_free_raster(rast);
diff --git a/raster/test/regress/rt_asraster_expected b/raster/test/regress/rt_asraster_expected
index 1e8fef17d..50110cee8 100644
--- a/raster/test/regress/rt_asraster_expected
+++ b/raster/test/regress/rt_asraster_expected
@@ -46,10 +46,10 @@ NOTICE:  The rasters have different scales on the X axis
 3.0||||||||||||||||
 3.1|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 3.2|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
-3.3|993310|100|100|1|1406.537|-869.114|1.000|0.000|-175565.609|114987.661|8BUI|0.000|t|255.000|255.000|
-3.4|993310|100|100|1|1406.537|-869.114|0.000|1.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
-3.5|993310|101|101|1|1406.537|-869.114|10.000|-5.000|-176465.793|115491.747|8BUI|0.000|t|255.000|255.000|
-3.6|993310|100|101|1|1406.537|-869.114|-5.000|10.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
+3.3|993310|101|101|1|1406.537|-869.114|1.000|0.000|-175553.086|114987.661|8BUI|0.000|t|255.000|255.000|
+3.4|993310|100|101|1|1406.537|-869.114|0.000|1.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
+3.5|993310|101|101|1|1406.537|-869.114|10.000|-5.000|-176458.881|115491.236|8BUI|0.000|t|255.000|255.000|
+3.6|993310|101|102|1|1406.537|-869.114|-5.000|10.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 4.0||||||||||||||||
 4.1|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|8BUI|0.000|t|1.000|1.000|t
 4.10|993310|142|88|1|1000.000|-1000.000|0.000|0.000|-176100.000|115100.000|16BUI|0.000|t|13.000|13.000|f
diff --git a/raster/test/regress/rt_gdalwarp_expected b/raster/test/regress/rt_gdalwarp_expected
index 649f8d98e..d6bc47c1f 100644
--- a/raster/test/regress/rt_gdalwarp_expected
+++ b/raster/test/regress/rt_gdalwarp_expected
@@ -14,7 +14,7 @@ NOTICE:  Values must be provided for both X and Y when specifying the scale.  Re
 0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
-0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
+0.18|992163|11|11|1|1000.000|-1000.000|3.000|3.000|-500030.000|599999.910|t|t|t
 0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
 0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
 0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
@@ -31,14 +31,14 @@ NOTICE:  Values must be provided for both X and Y when specifying the scale.  Re
 1.13|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
 1.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 1.15|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
-1.16|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
-1.17|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
-1.18|992163|10|10|1|1000.000|-1000.000|1.000|3.000|-500010.000|600000.000|t|t|t
-1.19|992163|20|20|1|500.000|500.000|3.000|3.000|-500065.000|590065.000|t|t|t
+1.16|992163|11|11|1|1000.000|-1000.000|3.000|3.000|-500030.000|599999.910|t|t|t
+1.17|992163|11|11|1|1000.000|-1000.000|3.000|3.000|-500030.000|599999.910|t|t|t
+1.18|992163|11|11|1|1000.000|-1000.000|1.000|3.000|-500010.000|599999.970|t|t|t
+1.19|992163|21|21|1|500.000|500.000|3.000|3.000|-500060.362|589560.362|t|t|t
 1.2|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
-1.20|992163|21|21|1|500.000|500.000|0.000|6.000|-500048.000|590038.000|t|t|t
-1.21|992163|207|101|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
-1.22|992163|207|101|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
+1.20|992163|22|22|1|500.000|500.000|0.000|6.000|-500048.000|589538.000|t|t|t
+1.21|992163|208|102|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
+1.22|992163|208|102|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
 1.23|992163|150|150|1|66.667|-66.667|0.000|0.000|-500000.000|600000.000|t|t|t
 1.24|992163|5|5|1|2064.200|-2291.200|0.000|0.000|-500321.000|601456.000|t|t|t
 1.25|||||||||||||
@@ -62,11 +62,11 @@ NOTICE:  Values must be provided for both X and Y when specifying the scale.  Re
 3.7|992163|67|80|1|150.000|125.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.8|992163|67|80|1|150.000|125.000|0.000|0.000|-500000.000|590000.000|t|t|t
 4.1|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
-4.2|992163|10|10|1|1000.000|-1000.000|1.000|1.000|-500010.000|600000.000|t|t|t
-4.3|992163|10|10|1|1000.000|-1000.000|0.500|0.000|-500010.000|600000.000|t|t|t
-4.4|992163|10|10|1|1000.000|-1000.000|10.000|10.000|-500100.000|600000.000|t|t|t
-4.5|992163|10|10|1|1000.000|-1000.000|10.000|10.000|-500100.000|600000.000|t|t|t
-4.6|992163|10|10|1|1000.000|-1000.000|10.000|10.000|-500100.000|600000.000|t|t|t
+4.2|992163|11|11|1|1000.000|-1000.000|1.000|1.000|-500010.000|599999.990|t|t|t
+4.3|992163|11|11|1|1000.000|-1000.000|0.500|0.000|-500005.000|600000.000|t|t|t
+4.4|992163|11|11|1|1000.000|-1000.000|10.000|10.000|-500099.990|599999.000|t|t|t
+4.5|992163|11|11|1|1000.000|-1000.000|10.000|10.000|-500099.990|599999.000|t|t|t
+4.6|992163|11|11|1|1000.000|-1000.000|10.000|10.000|-500099.990|599999.000|t|t|t
 5.1|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 5.10|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500005.000|600001.000|t|t|t
 5.11|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500991.000|600991.000|t|t|t
diff --git a/raster/test/regress/tickets.sql b/raster/test/regress/tickets.sql
index a22717160..7a58d86e8 100644
--- a/raster/test/regress/tickets.sql
+++ b/raster/test/regress/tickets.sql
@@ -18,8 +18,8 @@ SELECT '#2532.2', NULL::geometry @ null::raster;
 -- added OFFSET 0 to force PostgreSQL 12+ to materialize the cte
 WITH data AS ( SELECT '#2911' l, ST_Metadata(ST_Rescale(
  ST_AddBand(
-  ST_MakeEmptyRaster(10, 10, 0, 0, 1, -1, 0, 0, 0),
-  1, '8BUI', 0, 0
+	ST_MakeEmptyRaster(10, 10, 0, 0, 1, -1, 0, 0, 0),
+	1, '8BUI', 0, 0
  2.0,
  -2.0
@@ -37,38 +37,38 @@ DROP TABLE IF EXISTS test_raster_scale_big;
 DROP TABLE IF EXISTS test_raster_scale_small;
 CREATE TABLE test_raster_scale_regular (
-  rid integer,
- 	rast raster
+	rid integer,
+	rast raster
 CREATE TABLE test_raster_scale_big (
-  rid integer,
- 	rast raster
+	rid integer,
+	rast raster
 CREATE TABLE test_raster_scale_small (
- 	rid integer,
- 	rast raster
+	rid integer,
+	rast raster
 CREATE OR REPLACE FUNCTION make_test_raster(
-  table_suffix text,
+	table_suffix text,
 	rid integer,
-  scale_x double precision,
-  scale_y double precision DEFAULT 1.0
+	scale_x double precision,
+	scale_y double precision DEFAULT 1.0
 RETURNS void
 AS $$
 DECLARE
 	rast raster;
- 	width integer := 2;
- 	height integer := 2;
- 	ul_x double precision := 0;
- 	ul_y double precision := 0;
- 	skew_x double precision := 0;
- 	skew_y double precision := 0;
- 	initvalue double precision := 1;
- 	nodataval double precision := 0;
+	width integer := 2;
+	height integer := 2;
+	ul_x double precision := 0;
+	ul_y double precision := 0;
+	skew_x double precision := 0;
+	skew_y double precision := 0;
+	initvalue double precision := 1;
+	nodataval double precision := 0;
 BEGIN
 	rast := ST_MakeEmptyRaster(width, height, ul_x, ul_y, scale_x, scale_y, skew_x, skew_y, 0);
 	rast := ST_AddBand(rast, 1, '8BUI', initvalue, nodataval);
@@ -83,7 +83,7 @@ SELECT make_test_raster('regular', 1, 1.0000001);
 SELECT make_test_raster('regular', 2, 0.9999999);
 SELECT AddRasterConstraints('test_raster_scale_regular'::name, 'rast'::name, 'scale_x', 'scale_y');
 SELECT r_table_name, r_raster_column, scale_x, scale_y FROM raster_columns
-  WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_regular';
+	WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_regular';
 -- Issues enforce_scaley_rast constraint violation
 SELECT make_test_raster('regular', 3, 1.001, 0.9999999);
@@ -91,7 +91,7 @@ SELECT make_test_raster('regular', 3, 1.001, 0.9999999);
 SELECT make_test_raster('big', 0, -1234567890123456789.0);
 SELECT AddRasterConstraints('test_raster_scale_big'::name, 'rast'::name, 'scale_x', 'scale_y');
-  WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_big';
+	WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_big';
 -- Issues enforce_scalex_rast constraint violation
 SELECT make_test_raster('big', 1, -12345678901234567890.0);
@@ -101,7 +101,7 @@ SELECT make_test_raster('small', 1, 0.000011);
 SELECT make_test_raster('small', 2, 0.00000999);
 SELECT AddRasterConstraints('test_raster_scale_small'::name, 'rast'::name, 'scale_x', 'scale_y');
-  WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_small';
+	WHERE  r_raster_column = 'rast' AND r_table_name = 'test_raster_scale_small';
 SELECT make_test_raster('small', 3, 0.00001, 1.00001);
@@ -153,10 +153,12 @@ FROM (VALUES ('A0006', 300), ('A0006', 302)) t(a,b);
 SELECT '#4770.b',
  ST_Union(NULL::raster) OVER (PARTITION BY a ORDER BY b)
-	         ('A0006', 302)) t(a, b);
+					 ('A0006', 302)) t(a, b);
 SELECT '#4724.a', ST_SummaryStatsAgg(NULL::raster, NULL::int4, NULL::bool)
  OVER (ORDER BY q) FROM generate_series(1,2) AS e(q);
 SELECT '#4724.b', ST_SummaryStatsAgg(NULL::raster, NULL::int4, NULL::bool)
+SELECT '#5854',Round(ST_Rotation(ST_Reskew(ST_AddBand(ST_MakeEmptyRaster(100, 430, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0), 0.0015))::numeric,3);
diff --git a/raster/test/regress/tickets_expected b/raster/test/regress/tickets_expected
index 46e1297be..1087ddadc 100644
--- a/raster/test/regress/tickets_expected
+++ b/raster/test/regress/tickets_expected
@@ -77,3 +77,4 @@ NOTICE:  Adding maximum extent constraint
 #4724.a|(0,,,,,)
 #4724.a|(0,,,,,)
 #4724.b|(0,,,,,)
+#5854|-0.983
Summary of changes:
 raster/rt_core/librtcore.h               |  14 +-
 raster/rt_core/rt_raster.c               | 404 +++++--------------------------
 raster/rt_core/rt_warp.c                 | 312 +++++-------------------
 raster/test/cunit/cu_raster_misc.c       |  11 +-
 raster/test/regress/rt_asraster_expected |   8 +-
 raster/test/regress/rt_gdalwarp_expected |  26 +-
 raster/test/regress/tickets.sql          |  48 ++--
 raster/test/regress/tickets_expected     |   1 +
 8 files changed, 167 insertions(+), 657 deletions(-)
hooks/post-receive
