[SCM] PostGIS branch master updated. 3.6.0rc2-496-gf09adbed3
Thu Jun 4 12:18:13 PDT 2026
the project "PostGIS".
       via  f09adbed379aad9ed9374cd19ca7ec3b6c2c0b49 (commit)
      from  c9bdc50fbdaac675ef784463df1849e27d447872 (commit)
revisions in full, below.
commit f09adbed379aad9ed9374cd19ca7ec3b6c2c0b49
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 4 12:17:19 2026 -0700
    Use nodata mask rather than a SQL filter in ST_Polygon
    Avoids polygonizing nodata areas with ST_Polygon, matches
    old behaviour pre-3.x (2018).
    Closes #6010
diff --git a/raster/rt_core/rt_geometry.c b/raster/rt_core/rt_geometry.c
index 2c126f4b8..70d815c69 100644
--- a/raster/rt_core/rt_geometry.c
+++ b/raster/rt_core/rt_geometry.c
@@ -979,7 +979,6 @@ rt_raster_gdal_polygonize(
 	int *pnElements
 	CPLErr cplerr = CE_None;
-	char *pszQuery;
 	long j;
 	OGRSFDriverH ogr_drv = NULL;
 	GDALDriverH gdal_drv = NULL;
@@ -1140,9 +1139,14 @@ rt_raster_gdal_polygonize(
 	 * Why: We pass the shared interrupt-aware progress callback so GDAL can
 	 * unwind promptly when PostgreSQL requests cancellation (#4222).
+	 * Use the band's nodata mask so large/infinite nodata values are excluded
+	 * before polygonizing, bypassing the broken %f string-format filter (#6010).
+	GDALRasterBandH mask_band = iBandHasNodataValue
+	    ? GDALGetMaskBand(gdal_band)
+	    : NULL;
 	cplerr = GDALFPolygonize(
-	    gdal_band, NULL, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALFPolygonize");
+	    gdal_band, mask_band, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALFPolygonize");
 	if (cplerr != CE_None) {
 		rterror("rt_raster_gdal_polygonize: Could not polygonize GDAL band");
@@ -1156,25 +1160,6 @@ rt_raster_gdal_polygonize(
 		return NULL;
-	 * Optimization: Apply a OGR SQL filter to the layer to select the
-	 * features different from NODATA value.
-	 * Thanks to David Zwarg.
-	if (iBandHasNodataValue) {
-		size_t sz = 50 * sizeof (char);
-		pszQuery = (char *) rtalloc(sz);
-		snprintf(pszQuery, sz, "PixelValue != %f", dBandNoData );
-		OGRErr e = OGR_L_SetAttributeFilter(hLayer, pszQuery);
-		if (e != OGRERR_NONE) {
-			rtwarn("Error filtering NODATA values for band. All values will be treated as data values");
-	else {
-		pszQuery = NULL;
 	 * Transform OGR layers to WKB polygons
 	 * XXX jorgearevalo: GDALPolygonize does not set the coordinate system
@@ -1193,8 +1178,6 @@ rt_raster_gdal_polygonize(
 		if (destroy_gdal_drv) GDALDestroyDriver(gdal_drv);
 		OGR_Fld_Destroy(hFldDfn);
 		OGR_DS_DeleteLayer(memdatasource, 0);
-		if (NULL != pszQuery)
-			rtdealloc(pszQuery);
 		OGRReleaseDataSource(memdatasource);
 		return NULL;
@@ -1225,8 +1208,6 @@ rt_raster_gdal_polygonize(
 			return NULL;
@@ -1291,7 +1272,6 @@ rt_raster_gdal_polygonize(
 	RASTER_DEBUG(3, "destroying OGR MEM vector");
-	if (NULL != pszQuery) rtdealloc(pszQuery);
 	return pols;
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index 18b1b6314..67fdaf55c 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -190,7 +190,8 @@ static void test_gdal_polygonize(void) {
 	nPols = 0;
 	gv = rt_raster_gdal_polygonize(rt, 0, TRUE, &nPols);
-	CU_ASSERT_DOUBLE_EQUAL(nPols, 4, FLT_EPSILON);
+	/* nodata=1.8 pixels are excluded: only 0.0 (x2 regions) and 2.8 remain */
+	CU_ASSERT_DOUBLE_EQUAL(nPols, 3, FLT_EPSILON);
 	total_area = 0; total_val = 0;
 	for (i = 0; i < nPols; i++) {
 		total_val += gv[i].val;
@@ -199,8 +200,8 @@ static void test_gdal_polygonize(void) {
 		lwgeom_free((LWGEOM *) gv[i].geom);
 	printf("total area, total_val, polys = %f, %f, %i\n", total_area, total_val, nPols);
-	CU_ASSERT_DOUBLE_EQUAL(total_val, 4.6, FLT_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(total_area, 81, FLT_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(total_val, 2.8, FLT_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(total_area, 65, FLT_EPSILON);
 	rtdealloc(gv);
@@ -214,7 +215,8 @@ static void test_gdal_polygonize(void) {
 	nPols = 0;
+	/* nodata=2.8 pixels are excluded: only 0.0 (x2 regions) and 1.8 remain */
@@ -224,8 +226,8 @@ static void test_gdal_polygonize(void) {
+	CU_ASSERT_DOUBLE_EQUAL(total_val, 1.8, FLT_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(total_area, 69, FLT_EPSILON);
 	rtdealloc(gv);
 	cu_free_raster(rt);
diff --git a/raster/test/regress/rt_polygon.sql b/raster/test/regress/rt_polygon.sql
index 111f089fa..ea1e3461d 100644
--- a/raster/test/regress/rt_polygon.sql
+++ b/raster/test/regress/rt_polygon.sql
@@ -151,3 +151,17 @@ FROM (
 DROP FUNCTION temp_geos_version();
 DROP TABLE IF EXISTS raster_polygon;
+-- #6010: nodata=FLT_MAX (32BF): only the 8 valid pixels should polygonize, not the nodata center pixel
+SELECT count(*) = 1 FROM ST_DumpAsPolygons(
+	ST_SetValue(
+		ST_AddBand(ST_MakeEmptyRaster(3, 3, 0, 0, 1, -1, 0, 0, 0),
+		           1, '32BF'::text, -9.0, 3.4028234663852886e+38),
+		1, 2, 2, 3.4028234663852886e+38));
+-- #6010: nodata=DBL_MAX (64BF): only the 8 valid pixels should polygonize, not the nodata center pixel
+	ST_SetValue(
+		           1, '64BF'::text, -9.0, 1.7976931348623157e+308),
+		1, 2, 2, 1.7976931348623157e+308));
diff --git a/raster/test/regress/rt_polygon_expected b/raster/test/regress/rt_polygon_expected
index 3d2628a5e..22ec3b719 100644
--- a/raster/test/regress/rt_polygon_expected
+++ b/raster/test/regress/rt_polygon_expected
@@ -5,3 +5,5 @@ t
 t
 t
 t
+t
+t
Summary of changes:
 raster/rt_core/rt_geometry.c            | 32 ++++++--------------------------
 raster/test/cunit/cu_gdal.c             | 14 ++++++++------
 raster/test/regress/rt_polygon.sql      | 14 ++++++++++++++
 raster/test/regress/rt_polygon_expected |  2 ++
 4 files changed, 30 insertions(+), 32 deletions(-)
hooks/post-receive
