[SCM] PostGIS branch master updated. 3.6.0rc2-497-g7318e9522
git at osgeo.org
git at osgeo.org
Thu Jun 4 13:45:30 PDT 2026
the project "PostGIS".
via 7318e95222b33f24eb606e958eb48fcfef06411f (commit)
from f09adbed379aad9ed9374cd19ca7ec3b6c2c0b49 (commit)
revisions in full, below.
commit 7318e95222b33f24eb606e958eb48fcfef06411f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jun 4 13:45:12 2026 -0700
Avoid Inf looping and memory use in ST_Split
When fed with very large coordinates, ST_Split could be
fooled into an Inf loop, this fixes that case,
closes #5916
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index a69b3d502..15ca6ff5c 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -282,9 +282,12 @@ lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
LWDEBUGF(3, "Projected point:(%.15g %.15g), seg:%d, p1:(%.15g %.15g), p2:(%.15g %.15g)", pt_projected.x, pt_projected.y, seg, p1.x, p1.y, p2.x, p2.y);
- /* When closest point == an endpoint, this is a boundary intersection */
- if ( ( (seg == nsegs-1) && P4D_SAME_STRICT(&pt_projected, &p2) ) ||
- ( (seg == 0) && P4D_SAME_STRICT(&pt_projected, &p1) ) )
+ /* When closest point == an endpoint, this is a boundary intersection.
+ * Compare only X and Y since pt_projected.x/y were forced to pt.x/y above,
+ * and Z/M may be NaN when line coordinates are very large (causing Inf/Inf
+ * in closest_point_on_segment). See #5916. */
+ if ( ( (seg == nsegs-1) && (pt_projected.x == p2.x) && (pt_projected.y == p2.y) ) ||
+ ( (seg == 0) && (pt_projected.x == p1.x) && (pt_projected.y == p1.y) ) )
return 1;
diff --git a/regress/core/split.sql b/regress/core/split.sql
index a1087e171..3b82a6708 100644
--- a/regress/core/split.sql
+++ b/regress/core/split.sql
@@ -114,4 +114,8 @@ SELECT '#5635a', ST_Split('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)'::geometry
-- https://trac.osgeo.org/postgis/ticket/5635 (split by nan blade)
SELECT '#5635b', ST_Split('LINESTRING Z (1 2 1,3 4 10,5 6 3)'::geometry
,'MULTIPOINT(1 NaN,2 1,2 4, 4 5)'::geometry);
+-- https://trac.osgeo.org/postgis/ticket/5916 (split hangs on huge-but-finite coordinates)
+SELECT '#5916', ST_NumGeometries(ST_Split(
+ ST_GeomFromText('LINESTRING(123456789 9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999, 0 1)'),
+ ST_GeomFromText('MULTIPOINT(0 1, 0 0, 2 3)')));
-- TODO: split line by collapsed line
diff --git a/regress/core/split_expected b/regress/core/split_expected
index 62ec3cfeb..9e5be98a0 100644
--- a/regress/core/split_expected
+++ b/regress/core/split_expected
@@ -31,3 +31,4 @@ ERROR: Splitter line has linear intersection with input
87|SRID=4326;GEOMETRYCOLLECTION(LINESTRING EMPTY)
ERROR: Input Geometry contains invalid coordinates
ERROR: Blade Geometry contains invalid coordinates
+#5916|1
Summary of changes:
liblwgeom/lwgeom_geos_split.c | 9 ++++++---
regress/core/split.sql | 4 ++++
regress/core/split_expected | 1 +
3 files changed, 11 insertions(+), 3 deletions(-)
hooks/post-receive
