[PostGIS] #5916: ST_Split consumes excessive memory when input contains infinity values
PostGIS trac at osgeo.org
Mon Jun 8 10:29:55 PDT 2026
  Reporter:  dmyzl    |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.5.5
 Component:  postgis  |    Version:  3.5.x
Resolution:  fixed    |   Keywords:  ST_Split
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"d6e0a906d3665f58588d2b5086e9fe785dab5d1a/git" d6e0a90/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d6e0a906d3665f58588d2b5086e9fe785dab5d1a"
 Avoid Inf looping and memory use in ST_Split
 When fed with very large coordinates, ST_Split could be
 fooled into an Inf loop, this fixes that case,
 closes #5916
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5916#comment:8>
