[SCM] PostGIS branch master updated. 3.6.0rc2-509-gbbbe84257
git at osgeo.org
git at osgeo.org
Tue Jun 9 12:40:11 PDT 2026
the project "PostGIS".
via bbbe84257be29b0101088e5da69677924f65cdd0 (commit)
via 8da97650d154e7b70b0a58f5be4c2870848bd06c (commit)
from 6216b684aaff36b393d5d5707c95a896b1e89ffc (commit)
revisions in full, below.
commit bbbe84257be29b0101088e5da69677924f65cdd0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 9 12:40:05 2026 -0700
News item for #4560
diff --git a/NEWS b/NEWS
index aaf9f2c05..17b07b97f 100644
--- a/NEWS
+++ b/NEWS
@@ -40,6 +40,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.2+ is needed
- #2614, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)
- GH-839, ST_Multi support for TIN and surfaces (Loïc Bartoletti)
- #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
+ - #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
* Enhancements *
commit 8da97650d154e7b70b0a58f5be4c2870848bd06c
Date: Tue Jun 9 19:32:57 2026 +0000
Add ST_3DInterpolatePoint for ZM geometry measure interpolation
Projects a query point onto a LINESTRING ZM using 3D (XYZ) distance,
returning the interpolated M value. Closes #4560.
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 570d4daea..c0c797c65 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -744,6 +744,68 @@ SELECT ST_AsText(
<para><xref linkend="ST_AddMeasure"/>, <xref linkend="ST_LocateAlong"/>, <xref linkend="ST_LocateBetween"/></para>
</refsection>
+ </refentry>
+ <refentry xml:id="ST_3DInterpolatePoint">
+ <refnamediv>
+ <refname>ST_3DInterpolatePoint</refname>
+ <refpurpose>Returns the interpolated measure of a geometry closest to a point in 3D.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float8 <function>ST_3DInterpolatePoint</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>linear_geom_with_measure</parameter></paramdef>
+ <paramdef><type>geometry </type> <parameter>point</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns the interpolated measure value of a linear ZM geometry
+ at the location closest to the given point, using 3D (XYZ) distance
+ for the projection. Use this function when the geometry has
+ significant Z variation, such as flight trajectories, where
+ <xref linkend="ST_InterpolatePoint"/> would give incorrect results
+ by ignoring the Z dimension.</para>
+ <note><para>The line must have both Z and M dimensions.
+ The point should have a Z dimension.</para></note>
+ <para role="availability" conformance="3.7.0">Availability: 3.7.0</para>
+ <para>&Z_support;</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>-- Line rising diagonally in Z; point at the 3D midpoint
+SELECT ST_3DInterpolatePoint(
+ 'LINESTRING ZM (0 0 0 0, 10 0 10 20)',
+ 'POINT Z (5 0 5)');
+ 10
+-- Vertical line (zero XY extent); 3D projection works where 2D would not
+ 'LINESTRING ZM (0 0 0 0, 0 0 10 100)',
+ 'POINT Z (5 5 5)');
+ 50
+ </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_InterpolatePoint"/>, <xref linkend="ST_AddMeasure"/>,
+ <xref linkend="ST_LocateAlong"/>, <xref linkend="ST_LocateBetween"/></para>
+ </refsection>
</refentry>
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 1194785c4..6ac9da3c7 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -596,6 +596,52 @@ test_lwline_interpolate_point_3d(void)
lwline_free(line);
+static void
+test_lwgeom_interpolate_point_3d(void)
+ LWGEOM *line;
+ LWPOINT *pt;
+ double result;
+ /* Simple diagonal line in XYZ, point at 3D midpoint */
+ line = lwgeom_from_wkt("LINESTRING ZM (0 0 0 0, 10 0 10 20)", LW_PARSER_CHECK_NONE);
+ pt = lwgeom_as_lwpoint(lwgeom_from_wkt("POINT Z (5 0 5)", LW_PARSER_CHECK_NONE));
+ result = lwgeom_interpolate_point_3d(line, pt);
+ CU_ASSERT_DOUBLE_EQUAL(result, 10.0, 1e-10);
+ lwpoint_free(pt);
+ /* Point offset in Y but same XZ projection: same result */
+ pt = lwgeom_as_lwpoint(lwgeom_from_wkt("POINT Z (5 99 5)", LW_PARSER_CHECK_NONE));
+ lwpoint_free(pt);
+ lwgeom_free(line);
+ /* Vertical line (zero XY extent): 3D projection works where 2D would not */
+ line = lwgeom_from_wkt("LINESTRING ZM (0 0 0 0, 0 0 10 100)", LW_PARSER_CHECK_NONE);
+ pt = lwgeom_as_lwpoint(lwgeom_from_wkt("POINT Z (5 5 5)", LW_PARSER_CHECK_NONE));
+ CU_ASSERT_DOUBLE_EQUAL(result, 50.0, 1e-10);
+ lwpoint_free(pt);
+ /* Point beyond end of line: clamped to end M */
+ line = lwgeom_from_wkt("LINESTRING ZM (0 0 0 0, 10 0 0 100)", LW_PARSER_CHECK_NONE);
+ pt = lwgeom_as_lwpoint(lwgeom_from_wkt("POINT Z (20 0 0)", LW_PARSER_CHECK_NONE));
+ CU_ASSERT_DOUBLE_EQUAL(result, 100.0, 1e-10);
+ lwpoint_free(pt);
+ /* Point before start of line: clamped to start M */
+ pt = lwgeom_as_lwpoint(lwgeom_from_wkt("POINT Z (-5 0 0)", LW_PARSER_CHECK_NONE));
+ CU_ASSERT_DOUBLE_EQUAL(result, 0.0, 1e-10);
+ lwpoint_free(pt);
static void test_lwline_clip(void)
LWCOLLECTION *c;
@@ -1844,6 +1890,7 @@ void algorithms_suite_setup(void)
PG_ADD_TEST(suite,test_point_interpolate);
PG_ADD_TEST(suite,test_lwline_interpolate_points);
PG_ADD_TEST(suite, test_lwline_interpolate_point_3d);
+ PG_ADD_TEST(suite, test_lwgeom_interpolate_point_3d);
PG_ADD_TEST(suite,test_lwline_clip);
PG_ADD_TEST(suite, test_lwpoly_clip);
PG_ADD_TEST(suite, test_lwtriangle_clip);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 3ac202217..692167c13 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1623,6 +1623,7 @@ extern LWCOLLECTION* lwgeom_locate_between(const LWGEOM *lwin, double from, doub
* Find the measure value at the location on the line closest to the point.
extern double lwgeom_interpolate_point(const LWGEOM *lwin, const LWPOINT *lwpt);
+extern double lwgeom_interpolate_point_3d(const LWGEOM *lwin, const LWPOINT *lwpt);
* Find the time of closest point of approach
diff --git a/liblwgeom/lwlinearreferencing.c b/liblwgeom/lwlinearreferencing.c
index 610f0cf4e..ace84cc08 100644
--- a/liblwgeom/lwlinearreferencing.c
+++ b/liblwgeom/lwlinearreferencing.c
@@ -947,6 +947,86 @@ lwgeom_interpolate_point(const LWGEOM *lwin, const LWPOINT *lwpt)
return ret;
+double
+lwgeom_interpolate_point_3d(const LWGEOM *lwin, const LWPOINT *lwpt)
+ POINT4D p, A, B, closest;
+ double mindist2 = DBL_MAX;
+ double best_m = 0.0;
+ uint32_t i;
+ if (!lwin)
+ lwerror("lwgeom_interpolate_point_3d: null input geometry!");
+ if (!lwgeom_has_m(lwin))
+ lwerror("Input geometry does not have a measure dimension");
+ if (!lwgeom_has_z(lwin))
+ lwerror("Input geometry does not have a Z dimension");
+ if (lwgeom_is_empty(lwin) || lwpoint_is_empty(lwpt))
+ lwerror("Input geometry is empty");
+ switch (lwin->type)
+ case LINETYPE:
+ LWLINE *lwline = lwgeom_as_lwline(lwin);
+ POINTARRAY *pa = lwline->points;
+ lwpoint_getPoint4d_p(lwpt, &p);
+ if (pa->npoints == 1)
+ getPoint4d_p(pa, 0, &closest);
+ return closest.m;
+ for (i = 0; i < pa->npoints - 1; i++)
+ double dx, dy, dz, len2, r;
+ double cx, cy, cz, d2;
+ getPoint4d_p(pa, i, &A);
+ getPoint4d_p(pa, i + 1, &B);
+ dx = B.x - A.x;
+ dy = B.y - A.y;
+ dz = B.z - A.z;
+ len2 = dx * dx + dy * dy + dz * dz;
+ if (len2 == 0.0)
+ /* Degenerate segment: distance to point A */
+ r = 0.0;
+ else
+ r = ((p.x - A.x) * dx + (p.y - A.y) * dy + (p.z - A.z) * dz) / len2;
+ if (r < 0.0) r = 0.0;
+ if (r > 1.0) r = 1.0;
+ cx = A.x + r * dx;
+ cy = A.y + r * dy;
+ cz = A.z + r * dz;
+ d2 = (p.x - cx) * (p.x - cx) + (p.y - cy) * (p.y - cy) + (p.z - cz) * (p.z - cz);
+ if (d2 < mindist2)
+ mindist2 = d2;
+ best_m = A.m + r * (B.m - A.m);
+ break;
+ default:
+ lwerror("This function does not accept %s geometries.", lwtype_name(lwin->type));
+ return best_m;
* Time of closest point of approach
diff --git a/postgis/lwgeom_functions_lrs.c b/postgis/lwgeom_functions_lrs.c
index 474d07ea9..b02afb5bb 100644
--- a/postgis/lwgeom_functions_lrs.c
+++ b/postgis/lwgeom_functions_lrs.c
@@ -214,6 +214,47 @@ Datum ST_InterpolatePoint(PG_FUNCTION_ARGS)
+Datum ST_3DInterpolatePoint(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_3DInterpolatePoint);
+ GSERIALIZED *gser_line = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *gser_point = PG_GETARG_GSERIALIZED_P(1);
+ LWGEOM *lwline;
+ LWPOINT *lwpoint;
+ if ( gserialized_get_type(gser_line) != LINETYPE )
+ elog(ERROR,"ST_3DInterpolatePoint: 1st argument isn't a line");
+ PG_RETURN_NULL();
+ if ( gserialized_get_type(gser_point) != POINTTYPE )
+ elog(ERROR,"ST_3DInterpolatePoint: 2nd argument isn't a point");
+ PG_RETURN_NULL();
+ gserialized_error_if_srid_mismatch(gser_line, gser_point, __func__);
+ if ( ! gserialized_has_m(gser_line) )
+ elog(ERROR,"ST_3DInterpolatePoint only accepts geometries that have an M dimension");
+ PG_RETURN_NULL();
+ if ( ! gserialized_has_z(gser_line) )
+ elog(ERROR,"ST_3DInterpolatePoint only accepts geometries that have a Z dimension");
+ PG_RETURN_NULL();
+ lwpoint = lwgeom_as_lwpoint(lwgeom_from_gserialized(gser_point));
+ lwline = lwgeom_from_gserialized(gser_line);
+ PG_RETURN_FLOAT8(lwgeom_interpolate_point_3d(lwline, lwpoint));
Datum LWGEOM_line_locate_point(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(LWGEOM_line_locate_point);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 73d41a465..bf3a094d9 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6682,6 +6682,13 @@ CREATE OR REPLACE FUNCTION ST_InterpolatePoint(Line geometry, Point geometry)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
+-- Availability: 3.7.0
+CREATE OR REPLACE FUNCTION ST_3DInterpolatePoint(Line geometry, Point geometry)
+ RETURNS float8
+ AS 'MODULE_PATHNAME', 'ST_3DInterpolatePoint'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_MEDIUM;
-- Grid / Hexagon coverage functions
diff --git a/regress/core/regress_lrs.sql b/regress/core/regress_lrs.sql
index 06e419dae..92706eb26 100644
--- a/regress/core/regress_lrs.sql
+++ b/regress/core/regress_lrs.sql
@@ -99,3 +99,11 @@ select 'addMeasure2', ST_AsText(ST_AddMeasure('LINESTRING(0 0, 9 0, 10 0)', 10,
select 'interpolatePoint1', ST_InterpolatePoint('LINESTRINGM(0 0 0, 10 0 4)', 'POINT(5 0)');
select 'interpolatePoint2', ST_InterpolatePoint('LINESTRINGM(0 0 0, 10 0 4)', 'POINT(7.5 0)');
+-- ST_3DInterpolatePoint
+select '3DinterpolatePoint1', ST_3DInterpolatePoint('LINESTRING ZM (0 0 0 0, 10 0 10 20)', 'POINT Z (5 0 5)');
+select '3DinterpolatePoint2', ST_3DInterpolatePoint('LINESTRING ZM (0 0 0 0, 10 0 10 20)', 'POINT Z (5 5 5)');
+select '3DinterpolatePoint3', ST_3DInterpolatePoint('LINESTRING ZM (0 0 0 0, 0 0 10 100)', 'POINT Z (5 5 5)');
diff --git a/regress/core/regress_lrs_expected b/regress/core/regress_lrs_expected
index bdc232637..868662a6f 100644
--- a/regress/core/regress_lrs_expected
+++ b/regress/core/regress_lrs_expected
@@ -47,3 +47,6 @@ addMeasure1|LINESTRING M (0 0 10,2 0 15,4 0 20)
addMeasure2|LINESTRING M (0 0 10,9 0 19,10 0 20)
interpolatePoint1|2
interpolatePoint2|3
+3DinterpolatePoint1|10
+3DinterpolatePoint2|10
+3DinterpolatePoint3|50
Summary of changes:
NEWS | 1 +
doc/reference_lrs.xml | 62 ++++++++++++++++++++++++++++++
liblwgeom/cunit/cu_algorithm.c | 47 +++++++++++++++++++++++
liblwgeom/liblwgeom.h.in | 1 +
liblwgeom/lwlinearreferencing.c | 80 +++++++++++++++++++++++++++++++++++++++
postgis/lwgeom_functions_lrs.c | 41 ++++++++++++++++++++
postgis/postgis.sql.in | 7 ++++
regress/core/regress_lrs.sql | 8 ++++
regress/core/regress_lrs_expected | 3 ++
9 files changed, 250 insertions(+)
hooks/post-receive
