[PostGIS] #5357: Invalid conversion of 2-points line in ST_LineFromEncodedPolyline
PostGIS trac at osgeo.org
Tue Jun 9 15:51:41 PDT 2026
  Reporter:  perikrone  |      Owner:  pramsey
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS PostgreSQL
 Component:  postgis    |    Version:  3.2.x
Resolution:  fixed      |   Keywords:  ST_LineFromEncodedPolyline
Changes (by Paul Ramsey <pramsey@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"38faa8d5146b32dbc71a99e64208fd23719999e8/git"
 38faa8d5/git]:
 {{{#!CommitTicketReference repository="git"
 revision="38faa8d5146b32dbc71a99e64208fd23719999e8"
 Fix ST_LineFromEncodedPolyline dropping close points
 Use int32_t accumulators instead of double.
 Closes #5357
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5357#comment:1>
