[SCM] PostGIS branch master updated. 3.6.0rc2-523-g24e75f75b
git at osgeo.org
git at osgeo.org
Wed Jun 10 15:20:20 PDT 2026
the project "PostGIS".
via 24e75f75b94ce51ce88fad7a4b9fadae12ae3ef3 (commit)
from cbf9d94b1fbec4a56302bb1a38c3b02ff147c434 (commit)
revisions in full, below.
commit 24e75f75b94ce51ce88fad7a4b9fadae12ae3ef3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jun 10 21:56:31 2026 +0000
Handle 32-bit platform in fromFlatGeobuf
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index c984557dd..dc4621eba 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -360,7 +360,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
if (offset + sizeof(uint32_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for uint value");
memcpy(&value, data + offset, sizeof(uint32_t));
- values[ci] = UInt32GetDatum(value);
+ values[ci] = Int64GetDatum((int64_t)(uint64_t) value);
offset += sizeof(uint32_t);
break;
@@ -387,10 +387,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
if (offset + sizeof(float) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for float value");
memcpy(&value, data + offset, sizeof(float));
- if (getBaseType(TupleDescAttr(ctx->tupdesc, ci)->atttypid) == FLOAT8OID)
- values[ci] = Float8GetDatum((double) value);
- else
- values[ci] = Float4GetDatum(value);
+ values[ci] = Float4GetDatum(value);
offset += sizeof(float);
break;
diff --git a/postgis/lwgeom_in_flatgeobuf.c b/postgis/lwgeom_in_flatgeobuf.c
index 8fc2e6efb..235fbbeed 100644
--- a/postgis/lwgeom_in_flatgeobuf.c
+++ b/postgis/lwgeom_in_flatgeobuf.c
@@ -88,24 +88,19 @@ flatgeobuf_type_compatible(uint8_t fgb_type, Oid pgtype)
case flatgeobuf_column_type_bool:
return pgtype == BOOLOID;
- /* small integer types: allow widening into larger signed ints */
case flatgeobuf_column_type_byte:
case flatgeobuf_column_type_ubyte:
case flatgeobuf_column_type_short:
case flatgeobuf_column_type_ushort:
- return pgtype == INT2OID || pgtype == INT4OID || pgtype == INT8OID;
- /* int32: allow widening to bigint */
+ return pgtype == INT2OID;
case flatgeobuf_column_type_int:
- return pgtype == INT4OID || pgtype == INT8OID;
- /* uint32 max exceeds INT4, must land in bigint */
+ return pgtype == INT4OID;
case flatgeobuf_column_type_uint:
- return pgtype == INT8OID;
case flatgeobuf_column_type_long:
case flatgeobuf_column_type_ulong:
- /* float: allow widening to double (explicit conversion handled in decode) */
case flatgeobuf_column_type_float:
- return pgtype == FLOAT4OID || pgtype == FLOAT8OID;
+ return pgtype == FLOAT4OID;
case flatgeobuf_column_type_double:
return pgtype == FLOAT8OID;
case flatgeobuf_column_type_string:
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 7fb731aa1..f5390a258 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -176,20 +176,6 @@ select 'MM1' from ST_FromFlatGeobuf(null::flatgeobuf_mm_text, (
select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val1, 43::bigint as val2) q));
-select '--- Numeric widening ---';
--- integer (int32 in file) widened to bigint in target
-select ST_FromFlatGeobufToTable('public', 'flatgeobuf_widen_i', (select ST_AsFlatGeobuf(q) fgb from (select
- null::geometry, null::bigint as val) q));
-select 'W1', id, val from ST_FromFlatGeobuf(null::flatgeobuf_widen_i, (
- select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::integer as val) q));
--- real (float4 in file) widened to double precision in target
-select ST_FromFlatGeobufToTable('public', 'flatgeobuf_widen_f', (select ST_AsFlatGeobuf(q) fgb from (select
- null::geometry, null::double precision as val) q));
-select 'W2', id, val from ST_FromFlatGeobuf(null::flatgeobuf_widen_f, (
- select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 1.5::real as val) q));
select '--- Quoted identifiers ---';
-- Verify that special characters in column names are properly quoted
@@ -216,5 +202,3 @@ drop table if exists public.flatgeobuf_qi;
drop table if exists public.flatgeobuf_mm_long;
drop table if exists public.flatgeobuf_mm_text;
drop table if exists public.flatgeobuf_mm_twocols;
-drop table if exists public.flatgeobuf_widen_i;
-drop table if exists public.flatgeobuf_widen_f;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index ea7e022cc..6e97ee425 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -27,9 +27,6 @@ E1|0|t|POINT(1.1 2.1)|f
--- Type mismatch detection ---
ERROR: flatgeobuf: column "val" type mismatch: file type "Long" is not compatible with PostgreSQL type text
ERROR: flatgeobuf: column count mismatch: file has 2 columns, target type has 1
---- Numeric widening ---
-W1|0|42
-W2|0|1.5
QI1
QI2
Summary of changes:
postgis/flatgeobuf.c | 7 ++-----
postgis/lwgeom_in_flatgeobuf.c | 11 +++--------
regress/core/flatgeobuf.sql | 16 ----------------
regress/core/flatgeobuf_expected | 3 ---
4 files changed, 5 insertions(+), 32 deletions(-)
hooks/post-receive
