[PostGIS] #4794: ST_3DIntersection does not behave correctly with line strings when no vertex is seen within the intersecion
trac at osgeo.org
Thu Jun 11 00:11:55 PDT 2026
Reporter: basilrabi | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: medium | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 3.0.x
Resolution: | Keywords:
Comment (by Loïc Bartoletti):
I haven't tested with older versions, but it's ok with PostGIS 3.7.0dev
and SFCGAL 2.3.0dev.
gis=# WITH solid AS (
SELECT CG_MakeSolid(
CG_Extrude(
ST_Translate(
ST_Force3D(
ST_GeomFromText('POLYGON ((-1 1,1 1,1 -1,-1 -1,-1
1))')
0, 0, -1
0, 0, 2
) geom
SELECT
ST_AsText(CG_3DIntersection(
'LINESTRING (-2 0 0,2 0 2)'::geometry,
solid.geom
'LINESTRING (-2 0 0,0 0 1,2 0 2)'::geometry,
solid.geom
FROM solid;
returns:
st_astext | st_astext
LINESTRING Z (-1 0 0.5,0 0 1) | LINESTRING Z (-1 0 0.5,0 0 1)
(1 ligne)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4794#comment:4>
