[SCM] PostGIS branch master updated. 3.6.0rc2-524-ge1dbdc5ff
git at osgeo.org
git at osgeo.org
Fri Jun 12 09:58:36 PDT 2026
the project "PostGIS".
via e1dbdc5fffeda2d1f32c82c8df0d043524788400 (commit)
from 24e75f75b94ce51ce88fad7a4b9fadae12ae3ef3 (commit)
revisions in full, below.
commit e1dbdc5fffeda2d1f32c82c8df0d043524788400
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jun 12 12:58:21 2026 -0400
get rid of 3.6 news in release and make room for 3.7
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 9fa7182f7..34e2034d9 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,57 +3,18 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<section>
- <title>PostGIS 3.6.0rc2</title>
- <para>2025/08/25</para>
- <para>This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
- To take advantage of all features, GEOS 3.14+ is needed.
- To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.</para>
- <para>Many thanks to our translation teams, in particular:</para>
- <para>Teramoto Ikuhiro (Japanese Team)</para>
- <para>Daniel Nylander (Swedish Team)</para>
- <para>Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)</para>
- <para>Denys Kovshun (Ukrainian Team)</para>
+ <title>PostGIS 3.7.0beta1</title>
+ <para>2026/06/xx</para>
+ <para>This version requires GEOS 3.10 or higher. PostgreSQL 14-19beta1 required. Proj 6.1+ required.
+To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
+To take advantage of all postgis_sfcgal extension features SFCGAL 2.2+ is needed.</para>
<simplesect><title>Breaking Changes</title>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5799">#5799</link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5829">#5829</link>, remove constraint checking from geometry_columns view (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3373">#3373</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/255">GT-255</link>, [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/252">GT-252</link>, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
- use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link>, [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5359">#5359</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5897">#5897</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/260">GT-260</link>
- [tiger_geocoder] Use @extschema:extension@ for PG >= 16 to schema qualify dependent extensions, switch to use typmod for tiger tables (Regina Obe)</para>
- </simplesect>
- <simplesect><title>Removed / Deprecate signatures</title>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5498">#5498</link> Drop st_approxquantile(raster, double precision), wasn't usable as it triggered
- is not unique error when used (Regina Obe)</para>
</simplesect>
<simplesect><title>New Features</title>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/803">GH-803</link>, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)</para>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/805">GH-805</link>, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)</para>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/801">GH-801</link>, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5894">#5894</link>, [topology] TotalTopologySize (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5890">#5890</link>, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5861">#5861</link>, [topology] Add --drop-topology switch to pgtopo_import (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1247">#1247</link>, [raster] ST_AsRasterAgg (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5784">#5784</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/223">GT-223</link> Export circ_tree_distance_tree_internal for mobilitydb use
- (Maxime Schoemans)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/228">GT-228</link> [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and
- Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)</para>
- <para>[raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
- and routes them into the PostgreSQL logging system. (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5841">#5841</link>, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)</para>
- <para>Add ST_CoverageClean to edge match and gap remove polygonal
- coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
- <para>[raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)</para>
</simplesect>
</section>
</appendix>
Summary of changes:
doc/release_notes.xml | 51 ++++++---------------------------------------------
1 file changed, 6 insertions(+), 45 deletions(-)
hooks/post-receive
