[SCM] PostGIS branch master updated. 3.6.0rc2-533-gb4fcfb694
Fri Jun 12 21:13:44 PDT 2026
the project "PostGIS".
       via  b4fcfb694122e060fadfadb02e5b32711773a0ae (commit)
      from  fe42b211b8d4fa6aff42f7908f3f16e1aaceda8a (commit)
revisions in full, below.
commit b4fcfb694122e060fadfadb02e5b32711773a0ae
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jun 13 06:13:21 2026 +0200
    Update SFGAL dep information
diff --git a/NEWS b/NEWS
index 8013bf298..443712616 100644
--- a/NEWS
+++ b/NEWS
@@ -3,7 +3,7 @@ PostGIS 3.7.0beta1
 This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp.
 To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
-To take advantage of all postgis_sfcgal extension features SFCGAL 2.2+ is needed.
+To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
 * Breaking Changes *
diff --git a/doc/installation.xml b/doc/installation.xml
index 02cda543a..e337ae3ad 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -254,9 +254,12 @@ sh autogen.sh
     <listitem>
     <para>
-      SFCGAL, 1.4.1 or higher is required and 2.1+ is needed to be able to use all functionality. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal"/>. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <link xlink:href="https://sfcgal.org">https://sfcgal.org</link>)
+        SFCGAL, 1.4.1 or higher is required,
+        2.3+ is needed to be able to use all functionality.
+        SFCGAL can be used to provide additional 2D and 3D advanced
+        analysis functions to PostGIS cf <xref linkend="reference_sfcgal"/>.
-      <link xlink:href="https://gitlab.com/sfcgal/SFCGAL/">https://gitlab.com/sfcgal/SFCGAL/</link>.
+        <link xlink:href="https://gitlab.com/sfcgal/SFCGAL/">https://gitlab.com/sfcgal/SFCGAL/</link>.
     </para>
     </listitem>
Summary of changes:
 NEWS                 | 2 +-
 doc/installation.xml | 7 +++++--
 2 files changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
