[PostGIS] #6003: unknown conversion warning in lwgeom under mingw64/msys2 gcc 13.2
trac at osgeo.org
Thu Jun 18 06:20:09 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 3.7.0
Component: postgis | Version: 3.5.x
Resolution: fixed | Keywords: windows
Changes (by Darafei Praliaskouski <me@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8c5ead8c7e0c3b152929189b8f5e4f00f23525af/git" 8c5ead8/git]:
{{{#!CommitTicketReference repository="git"
revision="8c5ead8c7e0c3b152929189b8f5e4f00f23525af"
Avoid size_t formats in lwgeom logs
Replace size_t formatting in liblwgeom logging and error messages with
unsigned-long casts so MinGW builds do not warn on unsupported %zu format
specifiers.
Closes https://github.com/postgis/postgis/pull/903
Closes #6003
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6003#comment:4>
