[SCM] PostGIS branch master updated. 3.6.0rc2-603-g3fd87bf0f
Thu Jun 18 08:28:17 PDT 2026
the project "PostGIS".
       via  3fd87bf0f0d4b3a2cec5eebb611f263af89010eb (commit)
      from  746769bc9603c34262f2a704369a5efda9ac4ebe (commit)
revisions in full, below.
commit 3fd87bf0f0d4b3a2cec5eebb611f263af89010eb
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Jun 17 12:29:03 2026 +0400
    Add shp2pgsql unlogged table option
    Allow shp2pgsql create, drop, prepare, and dump modes to emit CREATE UNLOGGED TABLE for transient staging loads, and expose the option through the GUI and documentation.
    Closes https://github.com/postgis/postgis/pull/940
    Closes #1124
diff --git a/NEWS b/NEWS
index 9c40c9f0c..578109e8d 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * New Features *
+ - #1124, shp2pgsql can create UNLOGGED tables for transient staging loads
+          (Darafei Praliaskouski)
  - [topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)
  - ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
           polygonal coverage (Paul Ramsey)
diff --git a/doc/man/shp2pgsql.1 b/doc/man/shp2pgsql.1
index 7b6e8ae18..37ccabcba 100644
--- a/doc/man/shp2pgsql.1
+++ b/doc/man/shp2pgsql.1
@@ -108,6 +108,11 @@ If this option is used the output will be encoded in UTF-8.
 \fB\-I\fR
 Create a GiST index on the geometry column.
 .TP
+\fB\-u\fR
+Create the target table as UNLOGGED. This can speed up loading transient
+staging data, but PostgreSQL does not preserve unlogged table contents after
+a crash or unclean shutdown.
+.TP
 \fB\-N\fR <\fIpolicy\fR>
 Specify NULL geometries handling policy (insert,skip,abort).
 .TP
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 0fc321fe7..8f840a5ce 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1995,6 +1995,17 @@ COMMIT;</programlisting>
       </listitem>
     </varlistentry>
+    <varlistentry>
+      <term><option>-u</option></term>
+      <listitem>
+        <para>
+          Create the target table as <literal>UNLOGGED</literal>. This can speed up loading
+          transient staging data, but PostgreSQL does not preserve unlogged table contents
+          after a crash or unclean shutdown.
+        </para>
+      </listitem>
+    </varlistentry>
     <varlistentry>
       <term><option>-m</option></term>
       <listitem>
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index c2c4719a9..784ba3a7e 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -47,6 +47,7 @@ usage()
 	printf(_( "  -k  Keep postgresql identifiers case.\n" ));
 	printf(_( "  -i  Use int4 type for all integer dbf fields.\n" ));
 	printf(_( "  -I  Create a spatial index on the geocolumn.\n" ));
+	printf(_( "  -u  Create the table as UNLOGGED.\n" ));
 	printf(_("  -m <filename>  Specify a file containing a set of mappings of (long) column\n"
 	         "     names to 10 character DBF column names. The content of the file is one or\n"
 	         "     more lines of two names separated by white space and no trailing or\n"
@@ -105,7 +106,7 @@ main (int argc, char **argv)
 	set_loader_config_defaults(config);
 	/* Keep the flag list alphabetic so it's easy to see what's left. */
-	while ((c = pgis_getopt(argc, argv, "-?acdeg:ikm:nps:t:wDGIN:ST:W:X:Z")) != EOF)
+	while ((c = pgis_getopt(argc, argv, "-?acdeg:ikm:nps:t:uwDGIN:ST:W:X:Z")) != EOF)
 		// can not do this inside the switch case
 		if ('-' == c)
@@ -178,6 +179,10 @@ main (int argc, char **argv)
 			config->createindex = 1;
 			break;
+		case 'u':
+			config->unlogged = 1;
+			break;
 		case 'w':
 			config->use_wkt = 1;
 			break;
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 9065bdf6f..ac1adc528 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -770,6 +770,7 @@ set_loader_config_defaults(SHPLOADERCONFIG *config)
 	config->quoteidentifiers = 0;
 	config->forceint4 = 0;
 	config->createindex = 0;
+	config->unlogged = 0;
 	config->analyze = 1;
 	config->readshape = 1;
 	config->force_output = FORCE_OUTPUT_DISABLE;
@@ -1350,12 +1351,14 @@ ShpLoaderGetSQLHeader(SHPLOADERSTATE *state, char **strheader)
 		if (state->config->schema)
-			stringbuffer_aprintf(sb, "CREATE TABLE \"%s\".\"%s\" (gid serial",
+			stringbuffer_aprintf(sb, "CREATE %sTABLE \"%s\".\"%s\" (gid serial",
+			                     state->config->unlogged ? "UNLOGGED " : "",
 			                     state->config->schema, state->config->table);
 		else
-			stringbuffer_aprintf(sb, "CREATE TABLE \"%s\" (gid serial", state->config->table);
+			stringbuffer_aprintf(sb, "CREATE %sTABLE \"%s\" (gid serial",
+			                     state->config->unlogged ? "UNLOGGED " : "", state->config->table);
 		/* Generate the field types based upon the shapefile information */
diff --git a/loader/shp2pgsql-core.h b/loader/shp2pgsql-core.h
index 748d4773a..fd078e21b 100644
--- a/loader/shp2pgsql-core.h
+++ b/loader/shp2pgsql-core.h
@@ -114,6 +114,9 @@ typedef struct shp_loader_config
 	/* 0 = no index, 1 = create index after load */
 	int createindex;
+	/* 0 = logged table, 1 = create as UNLOGGED table */
+	int unlogged;
     /* 0 = don't analyze tables , 1 = analyze tables */
 	int analyze;
diff --git a/loader/shp2pgsql-gui.c b/loader/shp2pgsql-gui.c
index bfc301f50..7f8dbbc87 100644
--- a/loader/shp2pgsql-gui.c
+++ b/loader/shp2pgsql-gui.c
@@ -113,6 +113,7 @@ static GtkWidget *checkbutton_loader_options_forceint = NULL;
 static GtkWidget *checkbutton_loader_options_autoindex = NULL;
 static GtkWidget *checkbutton_loader_options_dbfonly = NULL;
 static GtkWidget *checkbutton_loader_options_dumpformat = NULL;
+static GtkWidget *checkbutton_loader_options_unlogged = NULL;
 static GtkWidget *checkbutton_loader_options_geography = NULL;
 static GtkWidget *checkbutton_loader_options_simplegeoms = NULL;
@@ -540,6 +541,7 @@ update_loader_config_globals_from_options_ui(SHPLOADERCONFIG *config)
 	gboolean createindex = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_autoindex));
 	gboolean dbfonly = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_dbfonly));
 	gboolean dumpformat = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_dumpformat));
+	gboolean unlogged = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_unlogged));
 	gboolean geography = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_geography));
 	gboolean simplegeoms = gtk_toggle_button_get_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_simplegeoms));
@@ -606,6 +608,12 @@ update_loader_config_globals_from_options_ui(SHPLOADERCONFIG *config)
 	else
 		config->dump_format = 0;
+	/* Create an unlogged table */
+	if (unlogged)
+	else
 	/* Simple geometries only */
 	if (simplegeoms)
 		config->simple_geometries = 1;
@@ -625,6 +633,7 @@ update_options_ui_from_loader_config_globals(void)
 	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_autoindex), global_loader_config->createindex ? TRUE : FALSE);
 	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_dbfonly), global_loader_config->readshape ? FALSE : TRUE);
 	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_dumpformat), global_loader_config->dump_format ? TRUE : FALSE);
+	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_unlogged), global_loader_config->unlogged ? TRUE : FALSE);
 	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_geography), global_loader_config->geography ? TRUE : FALSE);
 	gtk_toggle_button_set_active(GTK_TOGGLE_BUTTON(checkbutton_loader_options_simplegeoms), global_loader_config->simple_geometries ? TRUE : FALSE);
@@ -2712,7 +2721,7 @@ pgui_create_loader_options_dialog()
 	gtk_window_set_keep_above (GTK_WINDOW(dialog_loader_options), TRUE);
 	gtk_window_set_default_size (GTK_WINDOW(dialog_loader_options), 180, -1);
-	table_options = gtk_table_new(7, 3, TRUE);
+	table_options = gtk_table_new(9, 3, TRUE);
 	gtk_container_set_border_width (GTK_CONTAINER (table_options), 12);
 	gtk_table_set_row_spacings(GTK_TABLE(table_options), 5);
 	gtk_table_set_col_spacings(GTK_TABLE(table_options), 10);
@@ -2752,16 +2761,22 @@ pgui_create_loader_options_dialog()
 	gtk_table_attach_defaults(GTK_TABLE(table_options), align_options_center, 0, 1, 5, 6 );
 	gtk_container_add (GTK_CONTAINER (align_options_center), checkbutton_loader_options_dumpformat);
-	pgui_create_options_dialog_add_label(table_options, _("Load into GEOGRAPHY column"), 0.0, 6);
-	checkbutton_loader_options_geography = gtk_check_button_new();
+	pgui_create_options_dialog_add_label(table_options, _("Create as UNLOGGED table"), 0.0, 6);
+	checkbutton_loader_options_unlogged = gtk_check_button_new();
 	align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 	gtk_table_attach_defaults(GTK_TABLE(table_options), align_options_center, 0, 1, 6, 7 );
-	gtk_container_add (GTK_CONTAINER (align_options_center), checkbutton_loader_options_geography);
+	gtk_container_add (GTK_CONTAINER (align_options_center), checkbutton_loader_options_unlogged);
-	pgui_create_options_dialog_add_label(table_options, _("Generate simple geometries instead of MULTI geometries"), 0.0, 7);
-	checkbutton_loader_options_simplegeoms = gtk_check_button_new();
+	pgui_create_options_dialog_add_label(table_options, _("Load into GEOGRAPHY column"), 0.0, 7);
+	checkbutton_loader_options_geography = gtk_check_button_new();
 	gtk_table_attach_defaults(GTK_TABLE(table_options), align_options_center, 0, 1, 7, 8 );
+	gtk_container_add (GTK_CONTAINER (align_options_center), checkbutton_loader_options_geography);
+	pgui_create_options_dialog_add_label(table_options, _("Generate simple geometries instead of MULTI geometries"), 0.0, 8);
+	checkbutton_loader_options_simplegeoms = gtk_check_button_new();
+	align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
+	gtk_table_attach_defaults(GTK_TABLE(table_options), align_options_center, 0, 1, 8, 9 );
 	gtk_container_add (GTK_CONTAINER (align_options_center), checkbutton_loader_options_simplegeoms);
 	/* Catch the response from the dialog */
Summary of changes:
 NEWS                          |  2 ++
 doc/man/shp2pgsql.1           |  5 +++++
 doc/using_postgis_dataman.xml | 11 +++++++++++
 loader/shp2pgsql-cli.c        |  7 ++++++-
 loader/shp2pgsql-core.c       |  7 +++++--
 loader/shp2pgsql-core.h       |  3 +++
 loader/shp2pgsql-gui.c        | 25 ++++++++++++++++++++-----
 7 files changed, 52 insertions(+), 8 deletions(-)
hooks/post-receive
