[SCM] PostGIS branch master updated. 3.6.0rc2-605-g5034847fe
git at osgeo.org
git at osgeo.org
Thu Jun 18 09:04:12 PDT 2026
the project "PostGIS".
via 5034847fea82a43f56353719e2481056b3bd8860 (commit)
from 5f207dbe59a552eba46617f8436d4478aa7045f7 (commit)
revisions in full, below.
commit 5034847fea82a43f56353719e2481056b3bd8860
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 19:59:58 2026 +0400
Add single-geometry distance wrappers
Add one-argument ST_MaxDistance and ST_LongestLine SQL wrappers that delegate to the existing same-geometry binary behavior, and document the new public overloads with regression coverage.
Closes https://github.com/postgis/postgis/pull/953
Closes #4208
diff --git a/NEWS b/NEWS
index 249f6c879..1c7f5fc8d 100644
--- a/NEWS
+++ b/NEWS
@@ -22,6 +22,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #1124, shp2pgsql can create UNLOGGED tables for transient staging loads
(Darafei Praliaskouski)
+ - #4208, Add single-geometry variants of ST_MaxDistance and ST_LongestLine
+ (Darafei Praliaskouski)
- [topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)
- ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
polygonal coverage (Paul Ramsey)
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 5b2de34fa..66585ee67 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -1242,6 +1242,12 @@ CAST('SPHEROID["GRS_1980",6378137,298.257222101]' As spheroid) As sph_m) as foo
<refsynopsisdiv>
<funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_LongestLine</function></funcdef>
+ <paramdef><type>geometry </type>
+ <parameter>g</parameter></paramdef>
+ </funcprototype>
<funcprototype>
@@ -1265,10 +1271,11 @@ CAST('SPHEROID["GRS_1980",6378137,298.257222101]' As spheroid) As sph_m) as foo
The length of the line is equal to the distance returned by <xref linkend="ST_MaxDistance"/>.
</para>
<para>
- If g1 and g2 are the same geometry, returns the line between the two vertices farthest apart in the geometry.
+ If only one geometry is provided, or g1 and g2 are the same geometry, returns the line between the two vertices farthest apart in the geometry.
The endpoints of the line lie on the circle computed by <xref linkend="ST_MinimumBoundingCircle"/>.
</para>
<para role="availability" conformance="1.5.0">Availability: 1.5.0</para>
+ <para role="enhanced" conformance="3.7.0">Enhanced: 3.7.0 - support for a single geometry input.</para>
</refsection>
@@ -1322,9 +1329,9 @@ LINESTRING(20 10,105.3073372946034 186.95518130045156)
</mediaobject>
</informalfigure>
<programlisting>
-SELECT ST_AsText( ST_LongestLine( geom, geom)) AS llinewkt,
- ST_MaxDistance( geom, geom) AS max_dist,
- ST_Length( ST_LongestLine(geom, geom)) AS lenll
+SELECT ST_AsText( ST_LongestLine( geom)) AS llinewkt,
+ ST_MaxDistance( geom) AS max_dist,
+ ST_Length( ST_LongestLine(geom)) AS lenll
FROM (SELECT 'POLYGON ((40 180, 110 160, 180 180, 180 120, 140 90, 160 40, 80 10, 70 40, 20 50, 40 180),
(60 140, 99 77.5, 90 140, 60 140))'::geometry AS geom) AS t;
@@ -1452,6 +1459,10 @@ SELECT ST_AsEWKT(ST_3DLongestLine(line,pt)) AS lol3d_line_pt,
<refsynopsisdiv>
<funcsynopsis>
+ <funcprototype>
+ <funcdef>float <function>ST_MaxDistance</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>g</parameter></paramdef>
+ </funcprototype>
<funcprototype>
<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
@@ -1468,11 +1479,12 @@ SELECT ST_AsEWKT(ST_3DLongestLine(line,pt)) AS lol3d_line_pt,
The maximum distance always occurs between two vertices.
This is the length of the line returned by <xref linkend="ST_LongestLine"/>.
</para>
- <para>If g1 and g2 are the same geometry, returns the distance between
+ <para>If only one geometry is provided, or g1 and g2 are the same geometry, returns the distance between
the two vertices farthest apart in that geometry.
</para>
</refsection>
<refsection>
<title>Examples</title>
@@ -1489,8 +1501,7 @@ SELECT ST_MaxDistance('POINT(0 0)'::geometry, 'LINESTRING ( 2 2, 2 2 )'::geometr
<para>Maximum distance between vertices of a single geometry.</para>
<programlisting>
-SELECT ST_MaxDistance('POLYGON ((10 10, 10 0, 0 0, 10 10))'::geometry,
- 'POLYGON ((10 10, 10 0, 0 0, 10 10))'::geometry);
+SELECT ST_MaxDistance('POLYGON ((10 10, 10 0, 0 0, 10 10))'::geometry);
14.142135623730951
</programlisting>
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 580237410..1264a0822 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6168,6 +6168,12 @@ CREATE OR REPLACE FUNCTION ST_MaxDistance(geom1 geometry, geom2 geometry)
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_MaxDistance(geom geometry)
+ RETURNS float8
+ AS 'SELECT @extschema at .ST_MaxDistance($1, $1)'
+ LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_HIGH;
CREATE OR REPLACE FUNCTION ST_ClosestPoint(geom1 geometry, geom2 geometry)
RETURNS geometry
AS 'MODULE_PATHNAME', 'LWGEOM_closestpoint'
@@ -6192,6 +6198,12 @@ CREATE OR REPLACE FUNCTION ST_LongestLine(geom1 geometry, geom2 geometry)
_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_LongestLine(geom geometry)
+ RETURNS geometry
+ AS 'SELECT @extschema at .ST_LongestLine($1, $1)'
+ _COST_HIGH;
-- Availability: 2.2.0
CREATE OR REPLACE FUNCTION ST_SwapOrdinates(geom geometry, ords cstring)
RETURNS geometry
diff --git a/regress/core/measures.sql b/regress/core/measures.sql
index 3e01f5175..544ceb84b 100644
--- a/regress/core/measures.sql
+++ b/regress/core/measures.sql
@@ -45,6 +45,7 @@ select 'st_maxdistance_134', st_maxdistance('POINT(1 2)', 'POINT(1 2)');
select 'st_maxdistance_135', st_maxdistance('POINT(5 0)', 'POINT(10 12)');
select 'st_maxdistance_136', st_maxdistance('POINT(0 0)', ST_translate('POINT(0 0)', 5, 12, 0));
+select 'st_maxdistance_1arg', st_maxdistance('LINESTRING(0 0,3 4,6 0)'::geometry);
-- postgis-users/2006-May/012174.html
select 'st_maxdistance_dist', st_maxdistance(a,b)::numeric(12,6), st_maxdistance(b,a)::numeric(12,6) from (
@@ -59,6 +60,7 @@ select 'st_longestline_134', st_astext(st_longestline('POINT(1 2)', 'POINT(1 2)'
select 'st_longestline_135', st_astext(st_longestline('POINT(5 0)', 'POINT(10 12)'));
select 'st_longestline_136', st_astext(st_longestline('POINT(0 0)', ST_translate('POINT(0 0)', 5, 12, 0)));
+select 'st_longestline_1arg', st_astext(st_longestline('LINESTRING(0 0,3 4,6 0)'::geometry));
select 'st_longestline_dist', st_astext(st_longestline(a,b)), st_astext(st_longestline(b,a)) from (
diff --git a/regress/core/measures_expected b/regress/core/measures_expected
index e0b654476..798eaa2fc 100644
--- a/regress/core/measures_expected
+++ b/regress/core/measures_expected
@@ -16,10 +16,12 @@ st_shortestline_dist|LINESTRING(10 0,11 0)|LINESTRING(11 0,10 0)
st_maxdistance_134|0
st_maxdistance_135|13
st_maxdistance_136|13
+st_maxdistance_1arg|6
st_maxdistance_dist|22.360680|22.360680
st_longestline_134|LINESTRING(1 2,1 2)
st_longestline_135|LINESTRING(5 0,10 12)
st_longestline_136|LINESTRING(0 0,5 12)
+st_longestline_1arg|LINESTRING(0 0,6 0)
st_longestline_dist|LINESTRING(0 0,20 10)|LINESTRING(20 10,0 0)
distancetest1|1|50|LINESTRING(17 18,17 19)|LINESTRING(17 19,17 18)|LINESTRING(29 39,-1 -1)|LINESTRING(-1 -1,29 39)
distancetest2|0|50|0.0000000000|0.0000000000|0.0000000000|0.0000000000|LINESTRING(-40 -20,-10 20)|LINESTRING(-10 20,-40 -20)
Summary of changes:
NEWS | 2 ++
doc/reference_measure.xml | 25 ++++++++++++++++++-------
postgis/postgis.sql.in | 12 ++++++++++++
regress/core/measures.sql | 2 ++
regress/core/measures_expected | 2 ++
5 files changed, 36 insertions(+), 7 deletions(-)
hooks/post-receive
