[SCM] PostGIS branch master updated. 3.6.0rc2-606-gb1b94b6aa
Thu Jun 18 09:08:08 PDT 2026
the project "PostGIS".
       via  b1b94b6aaba4ef0c9a5fadc18ef0b7edfb43cda9 (commit)
      from  5034847fea82a43f56353719e2481056b3bd8860 (commit)
revisions in full, below.
commit b1b94b6aaba4ef0c9a5fadc18ef0b7edfb43cda9
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 20:06:45 2026 +0400
    Remove ST_MemCollect aggregate
    Remove the ST_MemCollect aggregate from the install script, drop any existing aggregate during upgrades, and document the removal as a 3.7 breaking change.
    Closes https://github.com/postgis/postgis/pull/909
    Closes #1793
diff --git a/NEWS b/NEWS
index 1c7f5fc8d..4cf3f5e26 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #6052, [tiger_geocoder] Extension removed and moved to
           https://git.osgeo.org/postgis/postgis_tiger_geocoder (Regina Obe)
  - #6079, Remove support for GEOS < 3.10 (Sandro Santilli)
+ - #1793, Remove ST_MemCollect aggregate (Darafei Praliaskouski)
 * New Features *
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 1264a0822..3647429c3 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4271,16 +4271,6 @@ CREATE OR REPLACE FUNCTION ST_Collect(geom1 geometry, geom2 geometry)
 	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
 	_COST_LOW;
--- Availability: 1.2.2
--- Changed: 2.3.0 to support PostgreSQL 9.6
--- Changed: 2.3.1 to support PostgreSQL 9.6 parallel safe
-CREATE AGGREGATE ST_MemCollect(geometry)(
-	sfunc = ST_collect,
-	combinefunc = ST_collect,
-	parallel = safe,
-	stype = geometry
 CREATE OR REPLACE FUNCTION ST_Collect(geometry[])
 	RETURNS geometry
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 0e6f507d2..7d86c9a5b 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -28,6 +28,7 @@ DROP AGGREGATE IF EXISTS st_geomunion(geometry);
 DROP AGGREGATE IF EXISTS accum_old(geometry);
 DROP AGGREGATE IF EXISTS st_accum_old(geometry);
 DROP AGGREGATE IF EXISTS st_accum(geometry); -- Dropped in 3.0.0
+DROP AGGREGATE IF EXISTS ST_MemCollect(geometry); -- Dropped in 3.7.0
 SELECT _postgis_drop_function_by_signature('pgis_geometry_accum_finalfn(internal)');
 DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer); -- temporarily introduced before 2.2.0 final
Summary of changes:
 NEWS                              |  1 +
 postgis/postgis.sql.in            | 10 ----------
 postgis/postgis_after_upgrade.sql |  1 +
 3 files changed, 2 insertions(+), 10 deletions(-)
hooks/post-receive
