[SCM] PostGIS branch master updated. 3.6.0rc2-607-g663d84635
git at osgeo.org
git at osgeo.org
Thu Jun 18 09:20:31 PDT 2026
the project "PostGIS".
via 663d846350266125cbed07fa50e3b534cfc4fe81 (commit)
from b1b94b6aaba4ef0c9a5fadc18ef0b7edfb43cda9 (commit)
revisions in full, below.
commit 663d846350266125cbed07fa50e3b534cfc4fe81
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 20:18:07 2026 +0400
doc: document PostGIS function cost tiers
Document the SQL cost-tier rule of thumb near the shared cost macros so contributors can pick DEFAULT, LOW, MEDIUM, or HIGH consistently.
Clarify that detoasting is not a separate stable multiplier because its cost depends on input size and prior detoasting.
Closes https://github.com/postgis/postgis/pull/933
Closes #2898
diff --git a/NEWS b/NEWS
index 4cf3f5e26..ce02af436 100644
--- a/NEWS
+++ b/NEWS
@@ -50,6 +50,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Enhancements *
+ - #2898, Document SQL function cost tiers for contributors
+ (Darafei Praliaskouski)
- #6062, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)
- #6065, Improved winding order computation robustness for rings having collapsed elements
(Sandro Santilli)
diff --git a/postgis/sqldefines.h.in b/postgis/sqldefines.h.in
index d8bbfa312..4b88a65ba 100644
--- a/postgis/sqldefines.h.in
+++ b/postgis/sqldefines.h.in
@@ -20,7 +20,19 @@
* where the support functions have been used in
* place of index SQL inlining.
* See https://trac.osgeo.org/postgis/ticket/3675
- * for sideffects of costing inlined SQL.
+ * for side effects of costing inlined SQL.
+ * Cost tiers:
+ * - DEFAULT: metadata, casts, accessors, operators, and index helpers.
+ * - LOW: simple serialization, measurement, or calculation over one value.
+ * - MEDIUM: constructors, parsers, exporters, transforms, or algorithms that
+ * usually walk most or all coordinates, pixels, or input elements.
+ * - HIGH: expensive GEOS, geography, raster, or multi-input operations where
+ * planner support functions preserve index-assisted plans.
+ * These tiers describe planner-visible function work. Do not add a separate
+ * detoasting multiplier here: detoast cost depends on toasted input size and
+ * on whether the datum has already been detoasted before the function call.
#define _COST_DEFAULT COST 1
#define _COST_LOW COST 50
@@ -52,4 +64,3 @@
#endif /* _LWPGIS_DEFINES */
Summary of changes:
NEWS | 2 ++
postgis/sqldefines.h.in | 15 +++++++++++++--
2 files changed, 15 insertions(+), 2 deletions(-)
hooks/post-receive
