[SCM] PostGIS branch master updated. 3.6.0rc2-613-gfc2a5bdd5
Thu Jun 18 10:20:05 PDT 2026
the project "PostGIS".
       via  fc2a5bdd5ea9e0f9a26a9374e0d3bb69ae4288b3 (commit)
      from  2f87b9ef28eb63e50d935da7141647ceb34f520f (commit)
revisions in full, below.
commit fc2a5bdd5ea9e0f9a26a9374e0d3bb69ae4288b3
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 21:18:39 2026 +0400
    geography: stabilize 32-bit LRS and pole centroid tests
    Clamp geography interpolation at tolerant segment endpoints, skip zero-length interpolation segments, and assert signed pole latitude in centroid regressions.
    Closes https://github.com/postgis/postgis/pull/907
    Closes #6073
    Closes #6074
diff --git a/NEWS b/NEWS
index f4db1a5fc..8a8baa0d2 100644
--- a/NEWS
+++ b/NEWS
@@ -72,6 +72,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           finite coordinates (Darafei Praliaskouski)
  - GH-892, Add OSS-Fuzz coverage for TWKB and serialized raster inputs,
           including guards for malformed TWKB reads and counts (Darafei Praliaskouski)
+ - #6073, #6074, Stabilize geography LRS endpoint interpolation and pole
+          centroid regressions on 32-bit systems (Darafei Praliaskouski)
  - #6082, Fix Japanese PDF build by avoiding non-ASCII arrows in SQL
           program listings (Darafei Praliaskouski)
  - GH-888, [sfcgal] Avoid stale detoasted geometry access in
diff --git a/liblwgeom/lwgeodetic_measures.c b/liblwgeom/lwgeodetic_measures.c
index 27f57ecdb..0640d0c39 100644
--- a/liblwgeom/lwgeodetic_measures.c
+++ b/liblwgeom/lwgeodetic_measures.c
@@ -317,15 +317,34 @@ geography_interpolate_points(
 		else
 			segment_length_frac = spheroid_distance(&g1, &g2, s) / length;
+		/* Duplicate vertices produce zero-length geodetic segments. Skip them
+		 * before endpoint tolerance matching because spheroid interpolation with
+		 * identical endpoints has no stable direction. */
+		if (segment_length_frac <= 0.0)
+			p1 = p2;
+			g1 = g2;
+			continue;
 		/* If our target distance is before the total length we've seen
 		* so far. create a new point some distance down the current
 		* segment.
-		while ( length_fraction < length_fraction_consumed + segment_length_frac && points_found < points_to_interpolate )
+		while (length_fraction <= length_fraction_consumed + segment_length_frac + FP_TOLERANCE &&
+		       points_found < points_to_interpolate)
+			double segment_end_fraction = length_fraction_consumed + segment_length_frac;
+			double segment_fraction;
 			geog2cart(&g1, &q1);
 			geog2cart(&g2, &q2);
-			double segment_fraction = (length_fraction - length_fraction_consumed) / segment_length_frac;
+			/* The endpoint tolerance compensates for 32-bit accumulated fraction
+			 * drift, but it must clamp before segment normalization so short
+			 * segments are not extrapolated. */
+			if (length_fraction > segment_end_fraction)
+				segment_fraction = 1.0;
+			else
+				segment_fraction = (length_fraction - length_fraction_consumed) / segment_length_frac;
 			interpolate_point4d_spheroid(&p1, &p2, &pt, s, segment_fraction);
 			ptarray_set_point4d(opa, points_found++, &pt);
 			length_fraction += length_fraction_increment;
@@ -342,7 +361,7 @@ geography_interpolate_points(
 	if (points_found < points_to_interpolate)
 		getPoint4d_p(ipa, ipa->npoints - 1, &pt);
-		ptarray_set_point4d(opa, points_found, &pt);
+		ptarray_set_point4d(opa, points_found++, &pt);
 	if (opa->npoints <= 1)
diff --git a/regress/core/geography.sql b/regress/core/geography.sql
index 5f98c7066..6e5ca26c5 100644
--- a/regress/core/geography.sql
+++ b/regress/core/geography.sql
@@ -141,6 +141,14 @@ SELECT 'lrs_lip_2', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.3
 SELECT 'lrs_lip_3', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 1.0, false), 2);
 SELECT 'lrs_lip_4', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.1, true), 2);
 SELECT 'lrs_lip_5', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.1, false), 2);
+SELECT 'lrs_lip_6073_short_segment', ST_Distance(
+  ST_LineInterpolatePoint(geography 'LINESTRING(0 0, 0 0.000000000001, 1 0)', 0.000000000001),
+  geography 'POINT(0 0.000000000001)'
+) < 1e-8;
+SELECT 'lrs_lip_6073_duplicate_start', ST_Distance(
+  ST_LineInterpolatePoint(geography 'LINESTRING(0 0, 0 0, 1 0)', 0.00000000000001),
+  geography 'POINT(0.00000000000001 0)'
+) < 1e-8;
 SELECT 'lrs_llp_1', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(25 0)')::numeric, 2);
 SELECT 'lrs_llp_2', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(-5 0)')::numeric, 2);
@@ -157,4 +165,3 @@ SELECT 'ticket_6076_perimeter', round(ST_Perimeter(ST_GeogFromText('GEOMETRYCOLL
 --SELECT 'lrs_cp_2', ST_AsText(ST_ClosestPoint(geography 'Point(25 20)', geography 'Linestring(0 20, 50 20)'), 3);
 SELECT 'lrs_sl_1', ST_AsText(ST_ShortestLine(geography 'linestring(0 40, 50 40)', 'Point(25 40)', true), 2);
diff --git a/regress/core/geography_centroid.sql b/regress/core/geography_centroid.sql
index 260e4d32a..077a64ce2 100644
--- a/regress/core/geography_centroid.sql
+++ b/regress/core/geography_centroid.sql
@@ -1,6 +1,6 @@
 -- check for pole crossing
-SELECT c, ST_AsText(ST_Centroid(g::geography),6) FROM
+SELECT c, ST_Y(ST_Centroid(g::geography)::geometry)::numeric(12,6) FROM
 ( VALUES
     ('geog_centroid_mpt_pole_north', 'MULTIPOINT ( 90 80, -90 80)'),
     ('geog_centroid_mpt_pole_south', 'MULTIPOINT ( 90 -80, -90 -80)')
diff --git a/regress/core/geography_centroid_expected b/regress/core/geography_centroid_expected
index b9e5ca7ca..805e6987c 100644
--- a/regress/core/geography_centroid_expected
+++ b/regress/core/geography_centroid_expected
@@ -1,5 +1,5 @@
-geog_centroid_mpt_pole_north|POINT(0 90)
-geog_centroid_mpt_pole_south|POINT(0 -90)
+geog_centroid_mpt_pole_north|90.000000
+geog_centroid_mpt_pole_south|-90.000000
 geog_centroid_mpt_idl_1|180.000000|0.000000
 geog_centroid_mpt_idl_2|179.500000|0.000000
 geog_centroid_mpt_idl_3|-179.500000|0.000000
diff --git a/regress/core/geography_expected b/regress/core/geography_expected
index 8584b7df0..6c5af43d8 100644
--- a/regress/core/geography_expected
+++ b/regress/core/geography_expected
@@ -61,6 +61,8 @@ lrs_lip_2|POINT(4.35 50.85)
 lrs_lip_3|POINT(37.62 55.76)
 lrs_lip_4|MULTIPOINT((7.27 51.73),(10.3 52.54),(13.43 53.27),(16.67 53.91),(20 54.47),(23.42 54.93),(26.9 55.29),(30.44 55.55),(34.02 55.7),(37.62 55.76))
 lrs_lip_5|MULTIPOINT((7.27 51.73),(10.29 52.54),(13.43 53.27),(16.67 53.91),(20 54.46),(23.42 54.92),(26.9 55.29),(30.44 55.55),(34.02 55.7),(37.62 55.76))
+lrs_lip_6073_short_segment|t
+lrs_lip_6073_duplicate_start|t
 lrs_llp_1|0.50
 lrs_llp_2|0.00
 lrs_llp_3|1.00
Summary of changes:
 NEWS                                     |  2 ++
 liblwgeom/lwgeodetic_measures.c          | 25 ++++++++++++++++++++++---
 regress/core/geography.sql               |  9 ++++++++-
 regress/core/geography_centroid.sql      |  2 +-
 regress/core/geography_centroid_expected |  4 ++--
 regress/core/geography_expected          |  2 ++
 6 files changed, 37 insertions(+), 7 deletions(-)
hooks/post-receive
