[SCM] PostGIS branch master updated. 3.6.0rc2-614-gafc9284ef
git at osgeo.org
git at osgeo.org
Thu Jun 18 10:42:25 PDT 2026
the project "PostGIS".
via afc9284efd51e84ce985e3637e5177fe93f41e36 (commit)
from fc2a5bdd5ea9e0f9a26a9374e0d3bb69ae4288b3 (commit)
revisions in full, below.
commit afc9284efd51e84ce985e3637e5177fe93f41e36
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 21:33:25 2026 +0400
doc: clarify ST_LineSubstring 2D fractions
References #5776
Closes https://github.com/postgis/postgis/pull/956
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index c0c797c65..8080dedfb 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -381,8 +381,8 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
starting and ending at the given fractional locations.
The first argument must be a LINESTRING.
The second and third arguments are values in the range [0, 1]
- representing the start and end locations
- as fractions of line length.
+ representing the start and end locations.
+ For geometry inputs, the fractions are measured in 2D line length.
The Z and M values are interpolated for added endpoints if present.
</para>
@@ -479,6 +479,23 @@ SELECT ST_AsText(ST_LineSubstring( 'LINESTRING(-118.2436 34.0522, -71.0570 42.36
geog_sub | LINESTRING(-104.167064 38.854691,-87.674646 41.849854)
geom_sub | LINESTRING(-102.530462 36.819064,-86.817324 39.585927)
</programlisting>
+ <para>For geometry inputs, the fractional locations are based on the 2D
+ length of the line, even when the input has Z values. The resulting Z values
+ are interpolated along the selected 2D location.</para>
+ <programlisting>
+ WITH data AS (
+ SELECT 'LINESTRING Z (0 0 0, 0 2 5, 0 10 10)'::geometry AS geom
+ SELECT ST_Length(geom) AS length_2d,
+ ST_3DLength(geom) AS length_3d,
+ ST_AsText(ST_LineSubstring(geom, 0, 0.5)) AS substring
+ FROM data;
+ length_2d | length_3d | substring
+ 10 | 14.8191459391911 | LINESTRING Z (0 0 0,0 2 5,0 5 6.875)
+ </programlisting>
</refsection>
<!-- Optionally add a "See Also" section -->
Summary of changes:
doc/reference_lrs.xml | 21 +++++++++++++++++++--
1 file changed, 19 insertions(+), 2 deletions(-)
hooks/post-receive
