[SCM] PostGIS branch master updated. 3.6.0rc2-615-ge80ff0a0c
git at osgeo.org
git at osgeo.org
Thu Jun 18 10:50:41 PDT 2026
the project "PostGIS".
via e80ff0a0cf01e8834eb7fdef7d17161dd2a825b1 (commit)
from afc9284efd51e84ce985e3637e5177fe93f41e36 (commit)
revisions in full, below.
commit e80ff0a0cf01e8834eb7fdef7d17161dd2a825b1
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 21:48:41 2026 +0400
doc: flatten PDF manual images
Closes #1408
Closes https://github.com/postgis/postgis/pull/931
diff --git a/NEWS b/NEWS
index 8a8baa0d2..ad8c66e92 100644
--- a/NEWS
+++ b/NEWS
@@ -107,6 +107,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #5593, Docs: render manual images with GraphicsMagick without temporary files,
enabling parallel builds, keeping ImageMagick fallbacks working, and
documenting the generator workflow for contributors (Darafei Praliaskouski)
+ - #1408, Docs: flatten transparent manual images onto white backgrounds for
+ PDF builds while keeping HTML images transparent (Darafei Praliaskouski)
- [fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts,
prefer requested CXX over pg_config --cc for internal C++ checks, and
make fuzzer linking/runtime dependency packaging portable
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 418d46ab6..6230b2031 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -49,6 +49,7 @@ DOCSUFFIX=-en
# TODO: change this ?
html_builddir=$(abs_builddir)/html
images_builddir=$(html_builddir)/images
+pdf_images_builddir=$(abs_builddir)/pdf/images
ifneq (,$(findstring dev,$(POSTGIS_MICRO_VERSION)))
POSTGIS_DOWNLOAD_URL=https://postgis.net/stuff
@@ -422,7 +423,7 @@ $(html_builddir)/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile
-postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: postgis-out.xml $(abs_srcdir)/texstyle-common.sty $(abs_srcdir)/texstyle.sty | images
+postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: postgis-out.xml $(abs_srcdir)/texstyle-common.sty $(abs_srcdir)/texstyle.sty | images pdf-images
ifeq ($(DBLATEX),)
@echo
@echo "configure was unable to find the 'dblatex' utility program."
@@ -432,7 +433,7 @@ ifeq ($(DBLATEX),)
else
$(DBLATEX) -T native -t pdf \
-x "--path $(XSLT_PATH)" \
- -I "$(abs_builddir)/html" \
+ -I "$(abs_builddir)/pdf" \
-P doc.collab.show=0 \
-P figure.note="images/note" \
-P figure.tip="images/tip" \
@@ -487,12 +488,16 @@ doxygen: doxygen.cfg
images images-install images-uninstall images-clean:
$(MAKE) -C $(images_builddir) $@
+pdf-images: images
+ $(MAKE) -C $(images_builddir) $@ PDF_IMAGES_BUILD_DIR="$(pdf_images_builddir)"
html-clean:
rm -f $(html_builddir)/postgis$(DOCSUFFIX).html
rm -rf $(html_builddir)/postgis$(DOCSUFFIX)/
pdf-clean:
rm -f postgis*$(DOCSUFFIX).pdf
+ rm -rf $(abs_builddir)/pdf
epub-clean:
rm -f postgis*$(DOCSUFFIX).epub
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 288065530..daeb3b706 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -262,6 +262,9 @@ ALL_IMAGES = \
$(GENERATED_IMAGES_RESIZED) \
$(STATIC_IMAGES)
+PDF_IMAGES_BUILD_DIR ?= pdf-images
+PDF_IMAGES = $(ALL_IMAGES:%=$(PDF_IMAGES_BUILD_DIR)/%)
OBJS=styles.o generator.o
# Build the generator
@@ -270,6 +273,8 @@ all: generator
# generate the images
images: $(ALL_IMAGES)
+pdf-images: $(PDF_IMAGES)
images-install: $(ALL_IMAGES)
mkdir -p $(DESTDIR)$(htmldir)/images
$(INSTALL_DATA) $(ALL_IMAGES) $(DESTDIR)$(htmldir)/images/
@@ -285,6 +290,23 @@ $(OBJS): %.o: %.c
$(STATIC_IMAGES):
ln -fs $(srcdir)/static/$@ $@
+$(PDF_IMAGES_BUILD_DIR)/%: %
+ @mkdir -p $(dir $@)
+ @converter=$${POSTGIS_DOC_CONVERTER:-}; \
+ if test -z "$$converter"; then \
+ if command -v gm >/dev/null 2>&1; then \
+ converter="gm convert"; \
+ elif command -v magick >/dev/null 2>&1; then \
+ converter="magick convert"; \
+ elif command -v convert >/dev/null 2>&1; then \
+ converter="convert"; \
+ else \
+ echo "Could not find GraphicsMagick or ImageMagick executables (gm, magick, convert)." >&2; \
+ exit 1; \
+ fi; \
+ fi; \
+ $$converter "$<" -background white -flatten "$@"
# Command to build each of the .wkt files
$(GENERATED_IMAGES): %.png: wkt/%.wkt generator wkt/styles.conf
@./generator $< $@
@@ -312,3 +334,4 @@ distclean: clean
images-clean:
rm -f $(ALL_IMAGES)
+ rm -rf $(PDF_IMAGES_BUILD_DIR)
Summary of changes:
NEWS | 2 ++
doc/Makefile.in | 9 +++++++--
doc/html/images/Makefile.in | 23 +++++++++++++++++++++++
3 files changed, 32 insertions(+), 2 deletions(-)
hooks/post-receive
