[PostGIS] #6083: Compile error on fuzzing engine on winnie
trac at osgeo.org
Thu Jun 18 22:47:18 PDT 2026
Reporter: robe | Owner: komzpa
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.7.0
Component: postgis | Version: 3.6.x
Keywords: |
I thought it was just woodie getting compile failures on fuzzingengine.
But it's winnie as well.
Output from winnie which started erroring at [746769bc/git]
This as of [6f291bf547/git]
mkdir -p "/projects/postgis/tmp/3.7.0dev_pg19_geos3.15_gdal3.9.2w64
/postgis-fuzzer-check.bG7HYY"
ar r libFuzzingEngine.a fuzzingengine.o
C:\ming64\mingw64\bin\ar.exe: creating libFuzzingEngine.a
CC="cc" CXX="g++" CXXFLAGS="-L/projects/postgis/branches/3.7/fuzzers "
LDFLAGS="-Wl,--enable-auto-import -L/projects/postgresql/rel/pg19w64/lib
-L/projects/lz4/rel-lz4-1.9.3w64/lib -L/projects/rel-libiconv-1.17w64/lib
-L/projects/zlib/rel-zlib-1.2.13w64/lib -lm
-LE:/jenkins/geos/rel-3.15w64/lib -lgeos_c -LE:/jenkins/proj/rel-
proj-8.2.1w64/lib -lproj -LE:/jenkins/json-c/rel-0.16w64/lib -ljson-c "
POSTGIS_BUILD_DIR="/projects/postgis/branches/3.7"
SRC="/projects/postgis/branches/3.7/fuzzers"
OUT="/projects/postgis/tmp/3.7.0dev_pg19_geos3.15_gdal3.9.2w64/postgis-
/projects/postgis/branches/3.7/fuzzers/build_google_oss_fuzzers.sh
Building fuzzer geojson_import_fuzzer
In file included from
E:/jenkins/postgis/branches/3.7/fuzzers/geojson_import_fuzzer.cpp:37:
E:/jenkins/postgis/branches/3.7/liblwgeom/liblwgeom.h:39:10: fatal error:
proj.h: No such file or directory
39 | #include "proj.h"
compilation terminated.
make[2]: *** [Makefile:22: dummyfuzzers] Error 1
make[2]: Leaving directory '/projects/postgis/branches/3.7/fuzzers'
make[1]: *** [/projects/postgis/branches/3.7/fuzzers/Makefile:26: check]
Error 2
make[1]: Leaving directory '/projects/postgis/branches/3.7/fuzzers'
make: *** [GNUmakefile:104: check-fuzzers] Error 2
Woodie seems fixed now as of [965711/git] but winnie is still broken.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6083>
