[PostGIS] #6022: Add documentation on simplification performed by ST_AsMVTGeom
PostGIS trac at osgeo.org
Fri Jun 19 12:09:28 PDT 2026
  Reporter:  robintw        |      Owner:  robe
      Type:  enhancement    |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.7.0
 Component:  documentation  |    Version:  3.5.x
Resolution:  fixed          |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"c451c27eb8cd4e52d66e281f1178d0b542d6be1a/git" c451c27/git]:
 {{{#!CommitTicketReference repository="git"
 revision="c451c27eb8cd4e52d66e281f1178d0b542d6be1a"
 doc: document ST_AsMVTGeom tile-coordinate simplification
 Clarify that ST_AsMVTGeom simplifies only within tile coordinate space by
 snapping to the integer grid, removing repeated points, and removing
 collinear points after transformation. Direct callers to run explicit map-
 coordinate simplification before tile conversion when they need broader
 detail reduction.
 Closes #6022
 Closes https://github.com/postgis/postgis/pull/983
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6022#comment:2>
