[SCM] PostGIS branch master updated. 3.6.0rc2-623-g767201c79
Fri Jun 19 12:28:57 PDT 2026
the project "PostGIS".
       via  767201c79e8fdd691b8f244df0b6c74f6118c901 (commit)
      from  c451c27eb8cd4e52d66e281f1178d0b542d6be1a (commit)
revisions in full, below.
commit 767201c79e8fdd691b8f244df0b6c74f6118c901
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jun 19 23:17:49 2026 +0400
    ptarray_from_twkb_state: avoid signed integer overflow
    Accumulate TWKB coordinate deltas through explicit unsigned wraparound so malformed inputs cannot trigger undefined signed-overflow behavior. Keep the current generalized dimension loop and existing malformed-input hardening while adding focused regression coverage for the OSS-Fuzz reproducer class.
    Adapted from Even Rouault's patch in https://github.com/postgis/postgis/pull/982.
    Closes https://issues.oss-fuzz.com/issues/525554772
    Closes https://github.com/postgis/postgis/pull/982
    Co-authored-by: Even Rouault <even.rouault at spatialys.com>
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 71c38585d..9b2097e0f 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -341,7 +341,7 @@ test_twkb_in_deep_collection(void)
 static void
-test_twkb_in_coordinate_overflow(void)
+test_twkb_in_coordinate_delta_wraparound(void)
 	const uint8_t twkb[] = {0x03, 0x00, 0x16, 0x16, 0x16, 0x16, 0x16, 0x2f, 0x00, 0x00, 0x3d, 0x00, 0x00,
 				0x00, 0x00, 0x00, 0x16, 0x16, 0x16, 0x16, 0x16, 0x23, 0x06, 0x02, 0x7e, 0x84,
@@ -358,13 +358,14 @@ test_twkb_in_coordinate_overflow(void)
 	/* Delta-encoded coordinates must not rely on signed integer overflow to
 	 * wrap hostile inputs into the int64_t accumulator range.
-	ASSERT_STRING_EQUAL(cu_error_msg, "twkb_parse_state_accum_coord: TWKB coordinate delta overflows int64_t");
-	CU_ASSERT_PTR_NULL(geom);
+	CU_ASSERT(strstr(cu_error_msg, "called with n=0 and npoints=0") != NULL);
+	if (geom != NULL)
+		lwgeom_free(geom);
 	cu_error_msg_reset();
 static void
-test_twkb_in_linestring_coordinate_overflow(void)
+test_twkb_in_linestring_coordinate_delta_wraparound(void)
 	uint8_t twkb[64] = {0x02, 0x00, 0x02};
 	uint8_t *pos = twkb + 3;
@@ -379,8 +380,10 @@ test_twkb_in_linestring_coordinate_overflow(void)
 	geom = lwgeom_from_twkb(twkb, (size_t)(pos - twkb), LW_PARSER_CHECK_NONE);
+	ASSERT_STRING_EQUAL(cu_error_msg, "");
+	CU_ASSERT_PTR_NOT_NULL(geom);
+	if (geom != NULL)
@@ -403,6 +406,6 @@ void twkb_in_suite_setup(void)
 	PG_ADD_TEST(suite, test_twkb_in_overlong_varint);
 	PG_ADD_TEST(suite, test_twkb_in_count_exceeds_payload);
 	PG_ADD_TEST(suite, test_twkb_in_deep_collection);
-	PG_ADD_TEST(suite, test_twkb_in_coordinate_overflow);
-	PG_ADD_TEST(suite, test_twkb_in_linestring_coordinate_overflow);
+	PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_wraparound);
+	PG_ADD_TEST(suite, test_twkb_in_linestring_coordinate_delta_wraparound);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 04261848d..ad5dcd0c6 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -25,6 +25,7 @@
 #include <math.h>
 #include <limits.h>
+#include <string.h>
 #include "liblwgeom_internal.h"
 #include "lwgeom_log.h"
 #include "varint.h"
@@ -46,7 +47,6 @@ typedef struct
 	uint32_t check; /* Simple validity checks on geometries */
 	uint32_t lwtype; /* Current type we are handling */
 	uint8_t depth;   /* Current recursion level, to prevent stack overflows */
-	uint8_t error;   /* A hard parse error was found */
 	uint8_t has_bbox;
 	uint8_t has_size;
@@ -162,21 +162,23 @@ twkb_parse_state_has_min_bytes(twkb_parse_state *s, uint32_t count, size_t min_b
 	return LW_TRUE;
-static inline int
+/** Implements *pa += b using explicit wraparound semantics. */
+#if defined(__clang__) && __clang_major__ >= 4
+__attribute__((no_sanitize("unsigned-integer-overflow")))
+#endif
+static inline void
+safe_add_int64(int64_t *pa, int64_t b)
+	uint64_t u_a = (uint64_t)*pa;
+	uint64_t u_b = (uint64_t)b;
+	u_a += u_b;
+	memcpy(pa, &u_a, sizeof(int64_t));
+static inline void
 twkb_parse_state_accum_coord(twkb_parse_state *s, int coord_index)
-	const int64_t delta = twkb_parse_state_varint(s);
-	if ((delta > 0 && s->coords[coord_index] > INT64_MAX - delta) ||
-	    (delta < 0 && s->coords[coord_index] < INT64_MIN - delta))
-		s->error = LW_TRUE;
-		lwerror("%s: TWKB coordinate delta overflows int64_t", __func__);
-		return LW_FALSE;
-	s->coords[coord_index] += delta;
-	return LW_TRUE;
+	safe_add_int64(&s->coords[coord_index], twkb_parse_state_varint(s));
 static uint32_t lwtype_from_twkb_type(uint8_t twkb_type)
@@ -261,11 +263,7 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
 		for (j = 0; j < ndims; j++)
-			if (!twkb_parse_state_accum_coord(s, j))
-				ptarray_free(pa);
-				return NULL;
+			twkb_parse_state_accum_coord(s, j);
 			dlist[ndims * i + j] = s->coords[j] / factors[j];
@@ -312,12 +310,8 @@ static LWLINE* lwline_from_twkb_state(twkb_parse_state *s)
 	/* Read coordinates */
 	pa = ptarray_from_twkb_state(s, npoints);
-	if( pa == NULL )
-		if (s->error)
-			return NULL;
+	if (pa == NULL)
 		return lwline_construct_empty(SRID_UNKNOWN, s->has_z, s->has_m);
 	if( s->check & LW_PARSER_CHECK_MINPOINTS && pa->npoints < 2 )
@@ -364,15 +358,8 @@ static LWPOLY* lwpoly_from_twkb_state(twkb_parse_state *s)
 		POINTARRAY *pa = ptarray_from_twkb_state(s, npoints);
 		/* Skip empty rings */
-		if( pa == NULL )
-			if (s->error)
-				lwpoly_free(poly);
-				return NULL;
+		if (pa == NULL)
 			continue;
 		/* Force first and last points to be the same. */
 		if( ! ptarray_is_closed_2d(pa) )
Summary of changes:
 liblwgeom/cunit/cu_in_twkb.c | 19 ++++++++++-------
 liblwgeom/lwin_twkb.c        | 51 +++++++++++++++++---------------------------
 2 files changed, 30 insertions(+), 40 deletions(-)
hooks/post-receive
