[SCM] PostGIS branch master updated. 3.6.0rc2-625-g9aee37109
git at osgeo.org
git at osgeo.org
Fri Jun 19 12:51:50 PDT 2026
the project "PostGIS".
via 9aee37109ed245fc322dfec6b1ac7bb1227eb942 (commit)
from 6f11ffd051915508ef244399043b484a2de46295 (commit)
revisions in full, below.
commit 9aee37109ed245fc322dfec6b1ac7bb1227eb942
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jun 19 23:49:01 2026 +0400
postgis: add coordinate size accessors
Add ST_XSize, ST_YSize, and ST_ZSize as box3d dimension helpers that also work for geometry and box2d through existing casts. Add ST_MSize for geometry measures, implemented from ST_MMax and ST_MMin.
Closes #2863
Closes https://github.com/postgis/postgis/pull/955
diff --git a/NEWS b/NEWS
index c6231dfc7..f0c449087 100644
--- a/NEWS
+++ b/NEWS
@@ -48,6 +48,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
- #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
- GT-270, Add NURBSCurve (Loïc Bartoletti)
+ - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
+ (Darafei Praliaskouski)
* Enhancements *
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index 797c36f3d..4a6be9df9 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -995,6 +995,165 @@ st_zmin
</refsection>
</refentry>
+ <refentry xml:id="ST_XSize">
+ <refnamediv>
+ <refname>ST_XSize</refname>
+ <refpurpose>Returns the X size of a 2D or 3D bounding box or a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float <function>ST_XSize</function></funcdef>
+ <paramdef><type>box3d </type> <parameter>aGeomorBox2DorBox3D</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns the X size of a 2D or 3D bounding box or a geometry, computed as <code>ST_XMax(aGeomorBox2DorBox3D) - ST_XMin(aGeomorBox2DorBox3D)</code>.</para>
+ <note>
+ <para>Although this function is only defined for box3d, it also works for box2d and geometry values due to automatic casting.
+ However it will not accept a geometry or box2d text representation, since those do not auto-cast.</para>
+ </note>
+ <para>&Z_support;</para>
+ <para>&curve_support;</para>
+ <para role="availability" conformance="3.7.0">Availability: 3.7.0</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>SELECT ST_XSize('BOX3D(1 2 3, 4 5 6)');
+st_xsize
+3
+SELECT ST_XSize(ST_GeomFromText('LINESTRING(1 3, 5 6)'));
+st_xsize
+4
+ </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YSize"/>, <xref linkend="ST_ZSize"/>, <xref linkend="ST_MSize"/></para>
+ </refsection>
+ </refentry>
+ <refentry xml:id="ST_YSize">
+ <refnamediv>
+ <refname>ST_YSize</refname>
+ <refpurpose>Returns the Y size of a 2D or 3D bounding box or a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float <function>ST_YSize</function></funcdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>Returns the Y size of a 2D or 3D bounding box or a geometry, computed as <code>ST_YMax(aGeomorBox2DorBox3D) - ST_YMin(aGeomorBox2DorBox3D)</code>.</para>
+ <note>
+ </note>
+ </refsection>
+ <refsection>
+ <programlisting>SELECT ST_YSize('BOX3D(1 2 3, 4 5 6)');
+st_ysize
+3
+SELECT ST_YSize(ST_GeomFromText('LINESTRING(1 3, 5 6)'));
+st_ysize
+3
+ </programlisting>
+ </refsection>
+ <refsection>
+ <para><xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_XSize"/>, <xref linkend="ST_ZSize"/>, <xref linkend="ST_MSize"/></para>
+ </refsection>
+ </refentry>
+ <refentry xml:id="ST_ZSize">
+ <refnamediv>
+ <refname>ST_ZSize</refname>
+ <refpurpose>Returns the Z size of a 2D or 3D bounding box or a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float <function>ST_ZSize</function></funcdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>Returns the Z size of a 2D or 3D bounding box or a geometry, computed as <code>ST_ZMax(aGeomorBox2DorBox3D) - ST_ZMin(aGeomorBox2DorBox3D)</code>.</para>
+ <note>
+ </note>
+ </refsection>
+ <refsection>
+ <programlisting>SELECT ST_ZSize('BOX3D(1 2 3, 4 5 6)');
+st_zsize
+3
+SELECT ST_ZSize(ST_GeomFromEWKT('LINESTRING(1 3 4, 5 6 7)'));
+st_zsize
+3
+ </programlisting>
+ </refsection>
+ <refsection>
+ <para><xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_XSize"/>, <xref linkend="ST_YSize"/>, <xref linkend="ST_MSize"/></para>
+ </refsection>
+ </refentry>
<refentry xml:id="ST_MMin">
<refnamediv>
<refname>ST_MMin</refname>
@@ -1013,7 +1172,7 @@ st_zmin
<refsection>
- <para>Returns the M minima of a geometry, or null of the geometry lacks M values.</para>
+ <para>Returns the M minima of a geometry, or null if the geometry lacks M values.</para>
@@ -1032,7 +1191,7 @@ st_mmin
<refsection>
- <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMax"/></para>
+ <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMax"/>, <xref linkend="ST_MSize"/></para>
</refsection>
</refentry>
@@ -1041,7 +1200,7 @@ st_mmin
<refnamediv>
<refname>ST_MMax</refname>
- <refpurpose>Returns the M minima of a geometry.</refpurpose>
+ <refpurpose>Returns the M maxima of a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -1054,7 +1213,7 @@ st_mmin
<refsection>
+ <para>Returns the M maxima of a geometry, or null if the geometry lacks M values.</para>
@@ -1070,7 +1229,45 @@ st_mmax
<refsection>
- <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/></para>
+ <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MSize"/></para>
+ </refsection>
+ </refentry>
+ <refentry xml:id="ST_MSize">
+ <refnamediv>
+ <refname>ST_MSize</refname>
+ <refpurpose>Returns the M size of a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float <function>ST_MSize</function></funcdef><paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>Returns the M size of a geometry, computed as <code>ST_MMax(geom) - ST_MMin(geom)</code>, or null if the geometry lacks M values.</para>
+ </refsection>
+ <refsection>
+ <programlisting>SELECT ST_MSize('LINESTRING M (1 2 3, 4 6 8)');
+st_msize
+5 </programlisting>
+ </refsection>
+ <refsection>
+ <para><xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/>, <xref linkend="ST_XSize"/>, <xref linkend="ST_YSize"/>, <xref linkend="ST_ZSize"/></para>
</refsection>
</refentry>
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 8167cbe72..7e5cd081b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1130,6 +1130,27 @@ CREATE OR REPLACE FUNCTION ST_ZMax(box3d)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_DEFAULT;
+-- Availability: 3.7.0
+CREATE OR REPLACE FUNCTION ST_XSize(box3d)
+ RETURNS FLOAT8
+ AS 'SELECT @extschema at .ST_XMax($1) - @extschema at .ST_XMin($1)'
+ LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_DEFAULT;
+CREATE OR REPLACE FUNCTION ST_YSize(box3d)
+ RETURNS FLOAT8
+ AS 'SELECT @extschema at .ST_YMax($1) - @extschema at .ST_YMin($1)'
+ _COST_DEFAULT;
+CREATE OR REPLACE FUNCTION ST_ZSize(box3d)
+ RETURNS FLOAT8
+ AS 'SELECT @extschema at .ST_ZMax($1) - @extschema at .ST_ZMin($1)'
+ _COST_DEFAULT;
CREATE OR REPLACE FUNCTION ST_MMin(geometry)
RETURNS FLOAT8
@@ -1144,6 +1165,13 @@ CREATE OR REPLACE FUNCTION ST_MMax(geometry)
_COST_DEFAULT;
+CREATE OR REPLACE FUNCTION ST_MSize(geometry)
+ RETURNS FLOAT8
+ AS 'SELECT @extschema at .ST_MMax($1) - @extschema at .ST_MMin($1)'
+ _COST_DEFAULT;
-- BOX2D FUNCTIONS
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 413a1b9f1..b31490528 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -123,6 +123,10 @@ SELECT '#175', ST_AsEWKT(ST_GeomFromEWKT('SRID=26915;POINT(482020 4984378.)'));
-- #178 --
SELECT '#178a', ST_XMin(ST_MakeBox2D(ST_Point(5, 5), ST_Point(0, 0)));
SELECT '#178b', ST_XMax(ST_MakeBox2D(ST_Point(5, 5), ST_Point(0, 0)));
+SELECT '#2863a', ST_XSize(ST_MakeBox2D(ST_Point(5, 5), ST_Point(0, 0)));
+SELECT '#2863b', ST_YSize('LINESTRING(1 2 3, 4 6 8)'::geometry);
+SELECT '#2863c', ST_ZSize('LINESTRING(1 2 3, 4 6 8)'::geometry);
+SELECT '#2863d', ST_MSize('LINESTRING M (1 2 3, 4 6 8)'::geometry);
-- #179 --
SELECT '#179a', ST_MakeLine(ARRAY[NULL,NULL,NULL,NULL]);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index dc67b09d2..9e968e2dd 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -37,6 +37,10 @@ ERROR: Invalid hex string, length (267) has to be a multiple of two!
#175|SRID=26915;POINT(482020 4984378)
#178a|0
#178b|5
+#2863a|5
+#2863b|4
+#2863c|5
+#2863d|5
NOTICE: No points or linestrings in input array
#179a|
Summary of changes:
NEWS | 2 +
doc/reference_bbox.xml | 207 +++++++++++++++++++++++++++++++++++++++++-
postgis/postgis.sql.in | 28 ++++++
regress/core/tickets.sql | 4 +
regress/core/tickets_expected | 4 +
5 files changed, 240 insertions(+), 5 deletions(-)
hooks/post-receive
