[SCM] PostGIS branch master updated. 3.6.0rc2-626-gbdf4f5727
Fri Jun 19 13:14:45 PDT 2026
the project "PostGIS".
       via  bdf4f57279395f82cc323c14f828cbd50b678444 (commit)
      from  9aee37109ed245fc322dfec6b1ac7bb1227eb942 (commit)
revisions in full, below.
commit bdf4f57279395f82cc323c14f828cbd50b678444
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 20 00:13:39 2026 +0400
    postgis: support curved rings in ST_MakePolygon
    Allow ST_MakePolygon to accept closed CircularString, CompoundCurve, and NURBSCurve rings, returning CurvePolygon when any input ring is curved.
    References #1291
    Closes https://github.com/postgis/postgis/pull/961
diff --git a/NEWS b/NEWS
index f0c449087..4012eedcf 100644
--- a/NEWS
+++ b/NEWS
@@ -47,6 +47,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-839, ST_Multi support for TIN and surfaces (Loïc Bartoletti)
  - #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
  - #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
+ - #1291, ST_MakePolygon support for curved rings (Darafei Praliaskouski)
  - GT-270, Add NURBSCurve (Loïc Bartoletti)
  - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 66fbb8b7c..1786be337 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -529,7 +529,7 @@ result
         <refnamediv>
         <refname>ST_MakePolygon</refname>
-        <refpurpose>Creates a Polygon from a shell and optional list of holes.</refpurpose>
+        <refpurpose>Creates a Polygon or CurvePolygon from a shell and optional list of holes.</refpurpose>
         </refnamediv>
         <refsynopsisdiv>
@@ -551,12 +551,14 @@ result
         <refsection>
             <title>Description</title>
-            <para>Creates a Polygon formed by the given shell and optional array of holes.
-            Input   geometries must be closed LineStrings (rings).</para>
+            <para>Creates a Polygon or CurvePolygon formed by the given shell and optional array of holes.
+            Input geometries must be closed LineStrings, CircularStrings, CompoundCurves, or NURBSCurves (rings).
+            If any input ring is curved, the result is a CurvePolygon.
+            </para>
-            <para><emphasis role="bold">Variant 1:</emphasis>  Accepts one shell LineString.</para>
-            <para><emphasis role="bold">Variant 2:</emphasis>  Accepts a shell LineString and an array of
-            inner (hole) LineStrings. A geometry array can be constructed using the PostgreSQL array_agg(), ARRAY[] or
+            <para><emphasis role="bold">Variant 1:</emphasis>  Accepts one shell ring.</para>
+            <para><emphasis role="bold">Variant 2:</emphasis>  Accepts a shell ring and an array of
+            inner (hole) rings. A geometry array can be constructed using the PostgreSQL array_agg(), ARRAY[] or
             ARRAY() constructs.</para>
             <note><para>This function does not accept MultiLineStrings.
@@ -564,6 +566,7 @@ result
             </note>
             <para>&Z_support;</para>
+            <para role="enhanced" conformance="3.7.0">Enhanced: 3.7.0 - Support for curved input rings was introduced.</para>
         </refsection>
         <refsection>
@@ -596,6 +599,15 @@ SELECT ST_AsEWKT( ST_MakePolygon( 'LINESTRINGM(75.15 29.53 1,77 29 1,77.6 29.5 2
 st_asewkt
 POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))
+</programlisting>
+<para>Create a CurvePolygon from a CircularString shell.</para>
+<programlisting>
+SELECT ST_AsText( ST_MakePolygon( 'CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0)' ));
+                     st_astext
+ CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0))
 </programlisting>
         </refsection>
         <refsection>
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index ec8b3ca18..f12b04b5c 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -20,6 +20,7 @@
  * Copyright 2001-2006 Refractions Research Inc.
  * Copyright 2017-2018 Daniel Baston <dbaston at gmail.com>
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
@@ -128,6 +129,23 @@ Datum ST_PointZM(PG_FUNCTION_ARGS);
+static int
+lwgeom_is_makepoly_ring_type(uint8_t type)
+	return type == LINETYPE || type == CIRCSTRINGTYPE || type == COMPOUNDTYPE || type == NURBSCURVETYPE;
+static void
+lwgeom_makepoly_validate_curve_ring(const LWGEOM *ring, const char *label)
+	uint32_t vertices_needed = ring->type == LINETYPE ? 4 : 3;
+	if (lwgeom_count_vertices(ring) < vertices_needed)
+		lwerror("%s must have at least %d points", label, vertices_needed);
+	if (!lwgeom_is_closed(ring))
+		lwerror("%s must be closed", label);
 /** find the size of geometry */
 PG_FUNCTION_INFO_V1(LWGEOM_mem_size);
 Datum LWGEOM_mem_size(PG_FUNCTION_ARGS)
@@ -1559,28 +1577,39 @@ Datum LWGEOM_makepoly(PG_FUNCTION_ARGS)
 	GSERIALIZED *pglwg1;
 	ArrayType *array = NULL;
 	GSERIALIZED *result = NULL;
-	const LWLINE *shell = NULL;
+	LWGEOM *shell = NULL;
+	LWGEOM **rings = NULL;
 	const LWLINE **holes = NULL;
 	LWPOLY *outpoly;
+	LWCURVEPOLY *outcurvepoly;
 	uint32 nholes = 0;
 	uint32 i;
 	size_t offset = 0;
+	int has_curve_ring = LW_FALSE;
+	int32_t srid;
+	int has_z;
+	int has_m;
 	POSTGIS_DEBUG(2, "LWGEOM_makepoly called.");
 	/* Get input shell */
 	pglwg1 = PG_GETARG_GSERIALIZED_P(0);
-	if (gserialized_get_type(pglwg1) != LINETYPE)
+	if (!lwgeom_is_makepoly_ring_type(gserialized_get_type(pglwg1)))
 		lwpgerror("Shell is not a line");
-	shell = lwgeom_as_lwline(lwgeom_from_gserialized(pglwg1));
+	shell = lwgeom_from_gserialized(pglwg1);
+	has_curve_ring = shell->type != LINETYPE;
+	srid = shell->srid;
+	has_z = FLAGS_GET_Z(shell->flags);
+	has_m = FLAGS_GET_M(shell->flags);
 	/* Get input holes if any */
 	if (PG_NARGS() > 1)
 		array = PG_GETARG_ARRAYTYPE_P(1);
 		nholes = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
+		rings = lwalloc(sizeof(LWGEOM *) * (nholes + 1));
 		holes = lwalloc(sizeof(LWLINE *) * nholes);
 		for (i = 0; i < nholes; i++)
@@ -1592,28 +1621,65 @@ Datum LWGEOM_makepoly(PG_FUNCTION_ARGS)
 #if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 6)
 #pragma GCC diagnostic pop
 #endif
-			LWLINE *hole;
+			LWGEOM *hole;
 			offset += INTALIGN(VARSIZE(g));
-			if (gserialized_get_type(g) != LINETYPE)
+			if (!lwgeom_is_makepoly_ring_type(gserialized_get_type(g)))
 				lwpgerror("Hole %d is not a line", i);
-			hole = lwgeom_as_lwline(lwgeom_from_gserialized(g));
-			holes[i] = hole;
+			hole = lwgeom_from_gserialized(g);
+			has_curve_ring |= hole->type != LINETYPE;
+			rings[i + 1] = hole;
+			holes[i] = lwgeom_as_lwline(hole);
-	outpoly = lwpoly_from_lwlines(shell, nholes, holes);
-	POSTGIS_DEBUGF(3, "%s", lwgeom_summary((LWGEOM *)outpoly, 0));
-	result = geometry_serialize((LWGEOM *)outpoly);
+	if (has_curve_ring)
+		if (!rings)
+			rings = lwalloc(sizeof(LWGEOM *));
+		rings[0] = shell;
+		outcurvepoly = lwcurvepoly_construct_empty(srid, FLAGS_GET_Z(shell->flags), FLAGS_GET_M(shell->flags));
-	lwline_free((LWLINE *)shell);
+		for (i = 0; i <= nholes; i++)
+			if (rings[i]->srid != srid)
+				lwerror("lwgeom_makepoly: mixed SRIDs in input rings");
+			if (FLAGS_GET_Z(rings[i]->flags) != has_z || FLAGS_GET_M(rings[i]->flags) != has_m)
+				lwerror("lwgeom_makepoly: mixed dimensioned rings");
+			lwgeom_makepoly_validate_curve_ring(rings[i], i == 0 ? "Shell" : "Hole");
+			if (LW_FAILURE == lwcurvepoly_add_ring(outcurvepoly, rings[i]))
+				lwerror("lwgeom_makepoly: could not add ring %d to curve polygon", i);
+			if (i == 0)
+				shell = NULL;
+			rings[i] = NULL;
+		POSTGIS_DEBUGF(3, "%s", lwgeom_summary((LWGEOM *)outcurvepoly, 0));
+		result = geometry_serialize((LWGEOM *)outcurvepoly);
+		lwgeom_free((LWGEOM *)outcurvepoly);
+	else
+		outpoly = lwpoly_from_lwlines(lwgeom_as_lwline(shell), nholes, holes);
+		POSTGIS_DEBUGF(3, "%s", lwgeom_summary((LWGEOM *)outpoly, 0));
+		result = geometry_serialize((LWGEOM *)outpoly);
+		lwpoly_free(outpoly);
+	if (shell)
+		lwgeom_free(shell);
 	PG_FREE_IF_COPY(pglwg1, 0);
-		lwline_free((LWLINE *)holes[i]);
+		if (rings && rings[i + 1])
+			lwgeom_free(rings[i + 1]);
+	if (rings)
+		lwfree(rings);
+	if (holes)
+		lwfree(holes);
 	PG_RETURN_POINTER(result);
diff --git a/regress/core/ctors.sql b/regress/core/ctors.sql
index d4038d44e..2b74d19a1 100644
--- a/regress/core/ctors.sql
+++ b/regress/core/ctors.sql
@@ -44,3 +44,30 @@ FROM (
   ('MULTILINESTRING((1 1, 2 2), (2 2, 3 3))'),
   ('MULTILINESTRING(EMPTY, (4 4, 5 5))')
   ) AS geoms(geom);
+SELECT 'ST_MakePolygonLine', ST_AsText(ST_MakePolygon(
+  'LINESTRING(0 0, 4 0, 4 4, 0 4, 0 0)'::geometry));
+SELECT 'ST_MakePolygonCurveShell', ST_AsText(ST_MakePolygon(
+  'CIRCULARSTRING(0 0, 1 1, 2 0, 1 -1, 0 0)'::geometry));
+SELECT 'ST_MakePolygonCurveHole', ST_AsText(ST_MakePolygon(
+  'LINESTRING(0 0, 4 0, 4 4, 0 4, 0 0)'::geometry,
+  ARRAY['CIRCULARSTRING(1 1, 2 2, 3 1, 2 0, 1 1)'::geometry]));
+SELECT 'ST_MakePolygonNurbsShell', ST_AsText(ST_MakePolygon(
+  'NURBSCURVE(2, (0 0, 5 10, 10 0, 5 -10, 0 0))'::geometry));
+SELECT 'ST_MakePolygonNurbsHole', ST_AsText(ST_MakePolygon(
+  ARRAY['NURBSCURVE(2, (1 1, 2 2, 3 1, 2 0, 1 1))'::geometry]));
+SELECT ST_MakePolygon('CIRCULARSTRING(0 0, 1 1, 2 0)'::geometry);
+  'CIRCULARSTRING Z (0 0 0, 1 1 0, 2 0 0, 1 -1 0, 0 0 0)'::geometry,
+  ARRAY['CIRCULARSTRING M (1 1 7, 2 2 7, 3 1 7, 2 0 7, 1 1 7)'::geometry]);
+  'CIRCULARSTRING M (0 0 0, 1 1 0, 2 0 0, 1 -1 0, 0 0 0)'::geometry,
+  ARRAY['CIRCULARSTRING Z (1 1 7, 2 2 7, 3 1 7, 2 0 7, 1 1 7)'::geometry]);
diff --git a/regress/core/ctors_expected b/regress/core/ctors_expected
index d18c7100c..bcdf4a5e7 100644
--- a/regress/core/ctors_expected
+++ b/regress/core/ctors_expected
@@ -10,3 +10,11 @@ ERROR:  BOX2D_construct: Operation on mixed SRID geometries (Point, 0) != (Point
 BOX3D(0 0 0,1 1 0)
 ERROR:  BOX3D_construct: Operation on mixed SRID geometries (Point, 0) != (Point, 3)
 ST_MakeLine2|LINESTRING(0 0,1 1,2 2,3 3,4 4,5 5)
+ST_MakePolygonLine|POLYGON((0 0,4 0,4 4,0 4,0 0))
+ST_MakePolygonCurveShell|CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0))
+ST_MakePolygonCurveHole|CURVEPOLYGON((0 0,4 0,4 4,0 4,0 0),CIRCULARSTRING(1 1,2 2,3 1,2 0,1 1))
+ST_MakePolygonNurbsShell|CURVEPOLYGON(NURBSCURVE(DEGREE 2,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 10),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(10 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 -10),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1)),KNOTS (KNOT(0,3),KNOT(0.333333333333333,1),KNOT(0.666666666666667,1),KNOT(1,3))))
+ST_MakePolygonNurbsHole|CURVEPOLYGON((0 0,4 0,4 4,0 4,0 0),NURBSCURVE(DEGREE 2,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(1 1),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2 2),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(3 1),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(1 1),WEIGHT 1)),KNOTS (KNOT(0,3),KNOT(0.333333333333333,1),KNOT(0.666666666666667,1),KNOT(1,3))))
+ERROR:  Shell must be closed
+ERROR:  lwgeom_makepoly: mixed dimensioned rings
Summary of changes:
 NEWS                             |  1 +
 doc/reference_constructor.xml    | 24 ++++++++---
 postgis/lwgeom_functions_basic.c | 90 ++++++++++++++++++++++++++++++++++------
 regress/core/ctors.sql           | 27 ++++++++++++
 regress/core/ctors_expected      |  8 ++++
 5 files changed, 132 insertions(+), 18 deletions(-)
hooks/post-receive
