[SCM] PostGIS branch master updated. 3.6.0rc2-627-g650756cd2
Fri Jun 19 14:18:46 PDT 2026
the project "PostGIS".
       via  650756cd29999db62384b98f1c2e876c6a61efc6 (commit)
      from  bdf4f57279395f82cc323c14f828cbd50b678444 (commit)
revisions in full, below.
commit 650756cd29999db62384b98f1c2e876c6a61efc6
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 20 01:03:13 2026 +0400
    doc: validate manual with DocBook XMLSchema
    Detect the DocBook 5 XMLSchema during configure and include XMLSchema validation in the documentation check target.
    References #5532
    Closes https://github.com/postgis/postgis/pull/967
diff --git a/NEWS b/NEWS
index 4012eedcf..6523cb57e 100644
--- a/NEWS
+++ b/NEWS
@@ -63,6 +63,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           reprojection support (Darafei Praliaskouski)
  - #4749, Use point-in-polygon predicate fast paths for point-only
           GeometryCollections (Darafei Praliaskouski)
+ - #5532, Validate the manual against DocBook XMLSchema in check-xml
+          (Darafei Praliaskouski)
 * Bug Fixes *
diff --git a/configure.ac b/configure.ac
index 6d84d5568..57157d133 100644
--- a/configure.ac
+++ b/configure.ac
@@ -397,6 +397,19 @@ else
 fi
 AC_SUBST([DOCBOOK5_RNG])
+dnl
+dnl Ensure DocBook XMLSchema can be found
+dnl
+DOCBOOK5_XSD=http://docbook.org/xml/5.0/xsd/docbook.xsd
+if test "x$XMLCATALOG" = "x"; then
+  DOCBOOK5_XSD=
+else
+  if $XMLCATALOG '' "${DOCBOOK5_XSD}" > /dev/null; then :
+  else DOCBOOK5_XSD=
+  fi
+fi
+AC_SUBST([DOCBOOK5_XSD])
 dnl
 dnl Ensure DocBook DTD can be found
 dnl
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 6230b2031..1c792eb0d 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -64,6 +64,7 @@ XMLCATALOG=@XMLCATALOG@
 XSLTPROC=@XSLTPROC@
 XSLBASE=@XSLBASE@
 DOCBOOK5_RNG=@DOCBOOK5_RNG@
+DOCBOOK5_XSD=@DOCBOOK5_XSD@
 DOCBOOK5_DTD=@DOCBOOK5_DTD@
 CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
 XMLLINT=@XMLLINT@
@@ -287,6 +288,11 @@ ifeq ($(DOCBOOK5_RNG),)
 CAN_CHECK_XML = no
 endif
+ifeq ($(DOCBOOK5_XSD),)
+check-xml: requirements_not_met_docbook5_xsd
+CAN_CHECK_XML = no
+endif
 ifeq ($(DOCBOOK5_DTD),)
 CAN_CHECK_XML = no
 endif
@@ -624,6 +630,9 @@ check-xml: postgis-out.xml
 		--valid --loaddtd \
 		--relaxng $(DOCBOOK5_RNG) \
+	$(XMLLINT) --noout --nonet \
+		--schema $(DOCBOOK5_XSD) \
 check-cheatsheets: cheatsheets
 	for f in $(html_builddir)/*_cheatsheet-en.html; do \
@@ -657,6 +666,13 @@ requirements_not_met_xmlcatalog:
 	@echo
 	@false
+requirements_not_met_docbook5_xsd:
+	@echo
+	@echo "configure was unable to locate DocBook XMLSchema (docbook.xsd)."
+	@echo "Install DocBook 5 schemas/catalog entries and then re-run configure."
+	@echo
+	@false
 requirements_not_met_xslbase:
 	@echo
diff --git a/doc/README b/doc/README
index 905cbfef1..865190eb3 100644
--- a/doc/README
+++ b/doc/README
@@ -68,7 +68,8 @@ Make targets
   XML files. See ``make check-localized``
 ``make check``
-  check structural correctness of XML documentation
+  check structural correctness of XML documentation with DocBook DTD,
+  RelaxNG, and XMLSchema validation
   check structural correctness of localized (translated)
Summary of changes:
 NEWS            |  2 ++
 configure.ac    | 13 +++++++++++++
 doc/Makefile.in | 16 ++++++++++++++++
 doc/README      |  3 ++-
 4 files changed, 33 insertions(+), 1 deletion(-)
hooks/post-receive
