[SCM] PostGIS branch master updated. 3.6.0rc2-629-g7a62d652e
git at osgeo.org
git at osgeo.org
Fri Jun 19 14:33:20 PDT 2026
the project "PostGIS".
via 7a62d652e3a3ed1402e633a198f8871464c27c35 (commit)
from 3abf37d25803fe25c564dd16b7d426f22f8ad18e (commit)
revisions in full, below.
commit 7a62d652e3a3ed1402e633a198f8871464c27c35
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 20 01:24:51 2026 +0400
doc: add raster2pgsql man page
Install the raster2pgsql(1) manual page and align its examples with the raster loader workflows documented in the main manual.
Closes #2386
Closes https://github.com/postgis/postgis/pull/979
diff --git a/NEWS b/NEWS
index 6523cb57e..a8b25af45 100644
--- a/NEWS
+++ b/NEWS
@@ -82,6 +82,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
deprecated-function cleanup (Darafei Praliaskouski)
- GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
progress callbacks (Darafei Praliaskouski)
+ - #2386, Add missing raster2pgsql man page (Darafei Praliaskouski)
- #5975, Initialize skipped union-find cluster ids deterministically
- GH-885, [topology] Avoid GMP overflow in ring orientation for very large
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 1c792eb0d..b7f684108 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -564,7 +564,7 @@ endif
comments-uninstall:
$(MAKE) -f Makefile.comments uninstall
-man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1
+man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/raster2pgsql.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1
mkdir -p $(DESTDIR)$(mandir)/man1
for f in $^; do \
$(INSTALL_DATA) $$f $(DESTDIR)$(mandir)/man1/`basename $$f`; \
@@ -573,6 +573,7 @@ man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1 man/pgtopo_impo
man-uninstall:
rm -f $(DESTDIR)$(mandir)/man1/shp2pgsql.1
rm -f $(DESTDIR)$(mandir)/man1/pgsql2shp.1
+ rm -f $(DESTDIR)$(mandir)/man1/raster2pgsql.1
rm -f $(DESTDIR)$(mandir)/man1/pgtopo_export.1
rm -f $(DESTDIR)$(mandir)/man1/pgtopo_import.1
rm -f $(DESTDIR)$(mandir)/man1/postgis.1
diff --git a/doc/man/raster2pgsql.1 b/doc/man/raster2pgsql.1
new file mode 100644
index 000000000..f33b9c504
--- /dev/null
+++ b/doc/man/raster2pgsql.1
@@ -0,0 +1,171 @@
+.TH "raster2pgsql" "1" "" "" "PostGIS"
+.SH "NAME"
+.LP
+raster2pgsql - raster to postgis loader
+.SH "SYNTAX"
+.LP
+raster2pgsql [\fIoptions\fR] \fIraster\fR [\fIraster\fR ...] [[\fIschema\fR\fB.\fR]\fItable\fR]
+.SH "DESCRIPTION"
+.LP
+The raster2pgsql data loader converts raster files supported by GDAL into SQL
+suitable for insertion into a PostGIS raster table. Multiple raster files may
+be passed on the command line, and shell wildcards can be used to select input
+files.
+.SH "OPTIONS"
+.LP
+The commandline options are:
+.TP
+\fB\-s\fR [<\fIFROM_SRID\fR>:]<\fISRID\fR>
+Set the SRID field. If FROM_SRID is given, the input raster is treated as that
+source SRID before being transformed to SRID. If no SRID is provided, or if SRID
+is 0, raster metadata is used when possible.
+.TP
+\fB\-b\fR <\fIband\fR>
+Index, starting from 1, of the band to extract from the raster. Separate
+multiple band indexes with commas. Ranges can be written with a dash. If this
+option is omitted, all bands are extracted.
+.TP
+\fB\-t\fR <\fItile_size\fR>
+Cut each raster into tiles inserted one per table row. The tile size is written
+as WIDTHxHEIGHT. Use "auto" to let the loader choose a tile size from the first
+raster and apply it to all rasters.
+.TP
+\fB\-P\fR
+Pad right-most and bottom-most tiles so all tiles have the same width and
+height.
+.TP
+\fB\-R\fR
+Register the raster as an out-of-db filesystem raster. Input raster paths must
+be absolute.
+.TP
+\fB\-d\fR
+Drop the table, recreate it, and populate it with the raster data.
+.TP
+\fB\-a\fR
+Append raster data into the existing table. The target table must have the same
+schema.
+.TP
+\fB\-c\fR
+Create a new table and populate it. This is the default mode.
+.TP
+\fB\-p\fR
+Prepare mode. Only emit SQL to create the table.
+.TP
+\fB\-f\fR <\fIcolumn\fR>
+Specify the name of the raster column.
+.TP
+\fB\-F\fR
+Add a column containing the source raster filename.
+.TP
+\fB\-n\fR <\fIcolumn\fR>
+Specify the filename column name. This implies \-F.
+.TP
+\fB\-l\fR <\fIoverview_factor\fR>
+Create overview tables for the raster. Separate multiple factors with commas.
+Overview table names follow the pattern o_<overview factor>_<table>. Created
+overviews are stored in the database and are not affected by \-R.
+.TP
+\fB\-q\fR
+Wrap PostgreSQL identifiers in quotes.
+.TP
+\fB\-I\fR
+Create a GiST spatial index on the raster column.
+.TP
+\fB\-M\fR
+Run VACUUM ANALYZE on the raster table. This is most useful when appending to an
+existing table with \-a.
+.TP
+\fB\-C\fR
+Set the standard raster constraints after the rasters are loaded. Some
+constraints may fail if one or more input rasters violate the constraint.
+.TP
+\fB\-x\fR
+Disable setting the max extent constraint. Only applies with \-C.
+.TP
+\fB\-r\fR
+Set spatially unique and coverage tile constraints for regular blocking. Only
+applies with \-C.
+.TP
+\fB\-T\fR <\fItablespace\fR>
+Specify the tablespace for the new table.
+.TP
+\fB\-X\fR <\fItablespace\fR>
+Specify the tablespace for the new table's indexes. This applies to the primary
+key and the spatial index when \-I is used.
+.TP
+\fB\-N\fR <\fInodata\fR>
+NODATA value to use on bands without a NODATA value.
+.TP
+\fB\-k\fR
+Keep empty tiles by skipping NODATA value checks for each raster band.
+.TP
+\fB\-E\fR <\fIendian\fR>
+Control endianness of generated binary raster output. Use 0 for XDR and 1 for
+NDR. Only NDR is currently supported.
+.TP
+\fB\-V\fR <\fIversion\fR>
+Specify the output WKB format version. Only version 0 is currently supported.
+.TP
+\fB\-e\fR
+Execute each statement individually instead of wrapping the load in a
+transaction.
+.TP
+\fB\-Y\fR [<\fImax_rows_per_copy\fR>]
+Use COPY statements instead of INSERT statements. If no row limit is provided,
+50 rows are written per COPY.
+.TP
+\fB\-G\fR
+Print the supported GDAL raster formats.
+.TP
+\fB\-?\fR
+Display version and usage information.
+.SH "EXAMPLES"
+.LP
+Load one projected population raster using COPY statements, automatic tiling,
+and post-load VACUUM ANALYZE:
+# \fBpsql \-c "drop table if exists ghs_globe_population_raster;"\fR
+.br
+# \fBraster2pgsql \-M \-Y \-s 54009 data/mid/ghs/GHS_POP.tif \-t auto ghs_globe_population_raster | psql \-q\fR
+.LP
+Create an empty raster table first, then append many rasters in parallel. This
+pattern is useful when loading large raster collections:
+# \fBpsql \-c "drop table if exists hrsl_population_raster;"\fR
+.br
+# \fBraster2pgsql \-p \-Y \-s 4326 data/in/hrsl/*.tif \-t auto hrsl_population_raster | psql \-q\fR
+.br
+# \fBfind data/in/hrsl \-name "*.tif" \-type f | parallel --eta 'GDAL_CACHEMAX=10000 GDAL_NUM_THREADS=4 raster2pgsql \-a \-Y \-s 4326 {} \-t auto hrsl_population_raster | psql \-q'\fR
+.br
+# \fBpsql \-c "create index hrsl_population_raster_rast_idx on hrsl_population_raster using gist (ST_ConvexHull(rast));"\fR
+.br
+# \fBpsql \-c "vacuum analyze hrsl_population_raster;"\fR
+.LP
+Create and append a tiled raster set from pre-cut tiles. The first tile creates
+the table definition; the remaining tiles append into it:
+# \fBls data/mid/night_lights/*.tif | head \-1 | parallel 'raster2pgsql \-p \-Y \-s 4326 {} \-t auto night_lights_raster | psql \-q'\fR
+.br
+# \fBls data/mid/night_lights/*.tif | parallel --eta 'GDAL_CACHEMAX=10000 GDAL_NUM_THREADS=4 raster2pgsql \-a \-Y \-s 4326 {} \-t auto night_lights_raster | psql \-q'\fR
+.LP
+List the raster formats supported by the GDAL library used by raster2pgsql:
+# \fBraster2pgsql \-G\fR
+.SH "AUTHORS"
+.LP
+Originally written by WKTRaster/PostGIS Raster contributors.
+Improved and maintained by the PostGIS project.
+.SH "SEE ALSO"
+.LP
+shp2pgsql(1), pgsql2shp(1)
+More information is available at http://postgis.net
Summary of changes:
NEWS | 1 +
doc/Makefile.in | 3 +-
doc/man/raster2pgsql.1 | 171 +++++++++++++++++++++++++++++++++++++++++++++++++
3 files changed, 174 insertions(+), 1 deletion(-)
create mode 100644 doc/man/raster2pgsql.1
hooks/post-receive
