[SCM] PostGIS branch master updated. 3.6.0rc2-630-g6c7ab193e
git at osgeo.org
git at osgeo.org
Sat Jun 20 05:47:35 PDT 2026
the project "PostGIS".
via 6c7ab193ea99ea6dabd5fb05dac9a995f4aa6be4 (commit)
from 7a62d652e3a3ed1402e633a198f8871464c27c35 (commit)
revisions in full, below.
commit 6c7ab193ea99ea6dabd5fb05dac9a995f4aa6be4
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 20 16:45:34 2026 +0400
raster2pgsql: avoid padding single-tile overviews
Trim overview edge tiles whenever padding is disabled, including the case where the overview fits in one tile. Compute overview tile counts independently for each axis so one matching dimension does not suppress tiling on the other.
Add a loader regression that builds a single-tile overview with a larger requested tile size and verifies the generated overview keeps the unpadded dimensions and extent.
Closes #2832
Closes https://github.com/postgis/postgis/pull/995
diff --git a/NEWS b/NEWS
index a8b25af45..42f7dbaa8 100644
--- a/NEWS
+++ b/NEWS
@@ -68,6 +68,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Bug Fixes *
+ - #2832, [raster] Avoid padding single-tile raster2pgsql overviews
+ when padding is not requested (Darafei Praliaskouski)
- Fix WKB and TWKB parser resource exhaustion on malformed input
- #6083, Pass configured dependency include paths to fuzzer smoke builds
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 68f68b526..e8ddcc478 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -1424,13 +1424,10 @@ build_overview(int idx, RTLOADERCFG *config, RASTERINFO *info, uint32_t ovx, STR
tile_size[1] = config->tile_size[1];
/* number of tiles */
- if (
- tile_size[0] != dimOv[0] &&
- tile_size[1] != dimOv[1]
+ if (tile_size[0] != dimOv[0])
ntiles[0] = (dimOv[0] + tile_size[0] - 1) / tile_size[0];
- ntiles[1] = (dimOv[1] + tile_size[1] - 1) / tile_size[1];
+ if (tile_size[1] != dimOv[1])
+ ntiles[1] = (dimOv[1] + tile_size[1] - 1) / tile_size[1];
/* working copy of geotransform matrix */
memcpy(gt, gtOv, sizeof(double) * 6);
@@ -1440,7 +1437,7 @@ build_overview(int idx, RTLOADERCFG *config, RASTERINFO *info, uint32_t ovx, STR
for (ytile = 0; ytile < ntiles[1]; ytile++) {
/* edge y tile */
- if (!config->pad_tile && ntiles[1] > 1 && (ytile + 1) == ntiles[1])
+ if (!config->pad_tile && (ytile + 1) == ntiles[1])
_tile_size[1] = dimOv[1] - (ytile * tile_size[1]);
else
_tile_size[1] = tile_size[1];
@@ -1452,7 +1449,7 @@ build_overview(int idx, RTLOADERCFG *config, RASTERINFO *info, uint32_t ovx, STR
/* edge x tile */
- if (!config->pad_tile && ntiles[0] > 1 && (xtile + 1) == ntiles[0])
+ if (!config->pad_tile && (xtile + 1) == ntiles[0])
_tile_size[0] = dimOv[0] - (xtile * tile_size[0]);
else
_tile_size[0] = tile_size[0];
diff --git a/raster/test/regress/loader/OverviewNoPadding-post.sql b/raster/test/regress/loader/OverviewNoPadding-post.sql
new file mode 100644
index 000000000..5739609f6
--- /dev/null
+++ b/raster/test/regress/loader/OverviewNoPadding-post.sql
@@ -0,0 +1,2 @@
+-- "loadedrast" is removed automatically !
+DROP TABLE o_16_loadedrast;
diff --git a/raster/test/regress/loader/OverviewNoPadding.opts b/raster/test/regress/loader/OverviewNoPadding.opts
index 000000000..e8044640c
--- /dev/null
+++ b/raster/test/regress/loader/OverviewNoPadding.opts
@@ -0,0 +1 @@
+-l 16 -t 256x256
diff --git a/raster/test/regress/loader/OverviewNoPadding.select.expected b/raster/test/regress/loader/OverviewNoPadding.select.expected
index 000000000..ebb6336f3
--- /dev/null
+++ b/raster/test/regress/loader/OverviewNoPadding.select.expected
@@ -0,0 +1,3 @@
+1
+6|3
+POLYGON((0 0,96 0,96 -48,0 -48,0 0))
diff --git a/raster/test/regress/loader/OverviewNoPadding.select.sql b/raster/test/regress/loader/OverviewNoPadding.select.sql
index 000000000..1ba47a441
--- /dev/null
+++ b/raster/test/regress/loader/OverviewNoPadding.select.sql
@@ -0,0 +1,3 @@
+SELECT count(*) FROM o_16_loadedrast;
+SELECT ST_Width(rast), ST_Height(rast) FROM o_16_loadedrast;
+SELECT ST_AsText(ST_Envelope(rast)) FROM o_16_loadedrast;
diff --git a/raster/test/regress/loader/OverviewNoPadding.tif.ref b/raster/test/regress/loader/OverviewNoPadding.tif.ref
index 000000000..1e1cc0fc8
--- /dev/null
+++ b/raster/test/regress/loader/OverviewNoPadding.tif.ref
@@ -0,0 +1 @@
+testraster.tif
diff --git a/raster/test/regress/tests.mk.in b/raster/test/regress/tests.mk.in
index 111be04e7..996f26583 100644
--- a/raster/test/regress/tests.mk.in
+++ b/raster/test/regress/tests.mk.in
@@ -130,6 +130,7 @@ RASTER_TEST_BUGS = \
RASTER_TEST_LOADER = \
$(top_srcdir)/raster/test/regress/loader/Basic \
$(top_srcdir)/raster/test/regress/loader/Projected \
+ $(top_srcdir)/raster/test/regress/loader/OverviewNoPadding \
$(top_srcdir)/raster/test/regress/loader/BasicCopy \
$(top_srcdir)/raster/test/regress/loader/BasicFilename \
$(top_srcdir)/raster/test/regress/loader/BasicOutDB \
Summary of changes:
NEWS | 2 ++
raster/loader/raster2pgsql.c | 13 +++++--------
.../{Projected-post.sql => OverviewNoPadding-post.sql} | 2 +-
raster/test/regress/loader/OverviewNoPadding.opts | 1 +
.../test/regress/loader/OverviewNoPadding.select.expected | 3 +++
raster/test/regress/loader/OverviewNoPadding.select.sql | 3 +++
.../loader/{Basic.tif.ref => OverviewNoPadding.tif.ref} | 0
raster/test/regress/tests.mk.in | 1 +
8 files changed, 16 insertions(+), 9 deletions(-)
copy raster/test/regress/loader/{Projected-post.sql => OverviewNoPadding-post.sql} (60%)
create mode 100644 raster/test/regress/loader/OverviewNoPadding.opts
create mode 100644 raster/test/regress/loader/OverviewNoPadding.select.expected
create mode 100644 raster/test/regress/loader/OverviewNoPadding.select.sql
copy raster/test/regress/loader/{Basic.tif.ref => OverviewNoPadding.tif.ref} (100%)
hooks/post-receive
