[SCM] PostGIS branch master updated. 3.6.0rc2-631-g177963ca6
git at osgeo.org
git at osgeo.org
Sat Jun 20 06:05:36 PDT 2026
the project "PostGIS".
via 177963ca6c91740aea1ab0000637017f9ad5dda5 (commit)
from 6c7ab193ea99ea6dabd5fb05dac9a995f4aa6be4 (commit)
revisions in full, below.
commit 177963ca6c91740aea1ab0000637017f9ad5dda5
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 20 17:03:54 2026 +0400
loader: test index creation during data loads
Enable index creation in existing shapefile and raster loader regression fixtures, and verify the resulting GiST indexes after the loads complete.
Pin the shapefile loader SQL so the regression also covers the unnamed CREATE INDEX form.
Closes #2820
Closes https://github.com/postgis/postgis/pull/994
diff --git a/raster/test/regress/loader/Basic.opts b/raster/test/regress/loader/Basic.opts
index d51cca218..d02bb6a13 100644
--- a/raster/test/regress/loader/Basic.opts
+++ b/raster/test/regress/loader/Basic.opts
@@ -1 +1 @@
--C
+-I -C
diff --git a/raster/test/regress/loader/Basic.select.expected b/raster/test/regress/loader/Basic.select.expected
index 484721c35..0e7dc191e 100644
--- a/raster/test/regress/loader/Basic.select.expected
+++ b/raster/test/regress/loader/Basic.select.expected
@@ -2,3 +2,4 @@
POLYGON((0 0,1 0,1 -1,0 -1,0 0))|255
POLYGON((89 -49,90 -49,90 -50,89 -50,89 -49))|0
POLYGON((44 -24,45 -24,45 -25,44 -25,44 -24))|0
+1
diff --git a/raster/test/regress/loader/Basic.select.sql b/raster/test/regress/loader/Basic.select.sql
index bc0434c08..a412b8314 100644
--- a/raster/test/regress/loader/Basic.select.sql
+++ b/raster/test/regress/loader/Basic.select.sql
@@ -2,3 +2,8 @@ SELECT srid, scale_x::numeric(16, 10), scale_y::numeric(16, 10), blocksize_x, bl
SELECT ST_AsEWKT(geom), val FROM (SELECT (ST_PixelAsPolygons(rast, 1)).* FROM loadedrast WHERE rid = 1) foo WHERE x = 1 AND y = 1;
SELECT ST_AsEWKT(geom), val FROM (SELECT (ST_PixelAsPolygons(rast, 2)).* FROM loadedrast WHERE rid = 1) foo WHERE x = 90 AND y = 50;
SELECT ST_AsEWKT(geom), val FROM (SELECT (ST_PixelAsPolygons(rast, 3)).* FROM loadedrast WHERE rid = 1) foo WHERE x = 45 AND y = 25;
+SELECT COUNT(*)
+FROM pg_indexes
+WHERE schemaname = 'public'
+ AND tablename = 'loadedrast'
+ AND indexdef LIKE 'CREATE INDEX % ON public.loadedrast USING gist (st_convexhull(rast))';
diff --git a/regress/loader/TestANALYZE.opts b/regress/loader/TestANALYZE.opts
index d82cb4c58..c865f6dca 100644
--- a/regress/loader/TestANALYZE.opts
+++ b/regress/loader/TestANALYZE.opts
@@ -1,2 +1,2 @@
-# Test with ANALYZE
--g the_geom {regdir}/loader/TestSkipANALYZE loadedshp
+# Test with ANALYZE and index creation
+-I -g the_geom {regdir}/loader/TestSkipANALYZE loadedshp
diff --git a/regress/loader/TestANALYZE.select.expected b/regress/loader/TestANALYZE.select.expected
index d00491fd7..6ed281c75 100644
--- a/regress/loader/TestANALYZE.select.expected
+++ b/regress/loader/TestANALYZE.select.expected
@@ -1 +1,2 @@
1
+1
diff --git a/regress/loader/TestANALYZE.select.sql b/regress/loader/TestANALYZE.select.sql
index de569878f..90227e331 100644
--- a/regress/loader/TestANALYZE.select.sql
+++ b/regress/loader/TestANALYZE.select.sql
@@ -2,3 +2,8 @@
SELECT COUNT(stanumbers1)
FROM pg_statistic
WHERE starelid = 'public.loadedshp'::regclass AND stanumbers1 IS NOT NULL;
+SELECT COUNT(*)
+FROM pg_indexes
+ AND tablename = 'loadedshp'
+ AND indexdef LIKE 'CREATE INDEX % ON public.loadedshp USING gist (the_geom)';
diff --git a/regress/loader/TestANALYZE.sql.expected b/regress/loader/TestANALYZE.sql.expected
new file mode 100644
index 000000000..fe56dd4b1
--- /dev/null
+++ b/regress/loader/TestANALYZE.sql.expected
@@ -0,0 +1,12 @@
+SET CLIENT_ENCODING TO UTF8;
+SET STANDARD_CONFORMING_STRINGS TO ON;
+BEGIN;
+CREATE TABLE "loadedshp" (gid serial);
+ALTER TABLE "loadedshp" ADD PRIMARY KEY (gid);
+SELECT AddGeometryColumn('','loadedshp','the_geom','0','POINT',2);
+INSERT INTO "loadedshp" (the_geom) VALUES ('01010000000000000000000000000000000000F03F');
+INSERT INTO "loadedshp" (the_geom) VALUES ('01010000000000000000002240000000000000F0BF');
+CREATE INDEX ON "loadedshp" USING GIST ("the_geom");
+COMMIT;
+ANALYZE "loadedshp";
Summary of changes:
raster/test/regress/loader/Basic.opts | 2 +-
raster/test/regress/loader/Basic.select.expected | 1 +
raster/test/regress/loader/Basic.select.sql | 5 +++++
regress/loader/TestANALYZE.opts | 4 ++--
regress/loader/TestANALYZE.select.expected | 1 +
regress/loader/TestANALYZE.select.sql | 5 +++++
regress/loader/TestANALYZE.sql.expected | 12 ++++++++++++
7 files changed, 27 insertions(+), 3 deletions(-)
create mode 100644 regress/loader/TestANALYZE.sql.expected
hooks/post-receive
