[SCM] PostGIS branch master updated. 3.6.0rc2-634-g47224001d
git at osgeo.org
git at osgeo.org
Sat Jun 20 12:33:56 PDT 2026
the project "PostGIS".
via 47224001d6fdd5e6443a6db1114419fd5b7d5d81 (commit)
from 6ce331f4e2bfd2054f56ba09c43907621259bffc (commit)
revisions in full, below.
commit 47224001d6fdd5e6443a6db1114419fd5b7d5d81
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 20 22:45:48 2026 +0400
Add ST_Value boundary resample modes
Add nearest-neighbor boundary resample modes for ST_Value so callers can choose upper-left, upper-right, lower-left, or lower-right pixels when a point lies on a pixel edge or corner.
Snap near-integer raster coordinates before applying boundary rounding, and reject non-exact resample names instead of accepting prefixes.
Closes #2116
Closes https://github.com/postgis/postgis/pull/1039
diff --git a/NEWS b/NEWS
index e668c7a62..395493674 100644
--- a/NEWS
+++ b/NEWS
@@ -54,6 +54,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Enhancements *
+ - #2116, [raster] Add ST_Value nearest-neighbor boundary options
+ (Darafei Praliaskouski)
- #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
and pass callback call data as actual arguments (Darafei Praliaskouski)
- #2898, Document SQL function cost tiers for contributors
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 04d059ffc..00206e352 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -4815,8 +4815,9 @@ SELECT x, y, val, ST_AsText(geom)
<para>Returns the value of a given band in a given columnx, rowy pixel or at a given geometry point. Band numbers start at 1 and band is assumed to be 1 if not specified.</para>
<para>If <varname>exclude_nodata_value</varname> is set to true, then only non <varname>nodata</varname> pixels are considered. If <varname>exclude_nodata_value</varname> is set to false, then all pixels are considered.</para>
- <para>The allowed values of the <varname>resample</varname> parameter are "nearest" which performs the default nearest-neighbor resampling, and "bilinear" which performs a <link xlink:href="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</link> to estimate the value between pixel centers.</para>
+ <para>The allowed values of the <varname>resample</varname> parameter are "nearest" which performs the default nearest-neighbor resampling, "bilinear" which performs a <link xlink:href="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</link> to estimate the value between pixel centers, and the nearest-neighbor boundary options "nearest-UL", "nearest-UR", "nearest-LL", and "nearest-LR". Boundary options choose which pixel is returned when the point lies on a horizontal or vertical pixel boundary, including corner intersections.</para>
+ <para role="enhanced" conformance="3.7.0">Enhanced: 3.7.0 resample accepts nearest-neighbor boundary options "nearest-UL", "nearest-UR", "nearest-LL", and "nearest-LR".</para>
<para role="enhanced" conformance="3.2.0">Enhanced: 3.2.0 resample optional argument was added.</para>
<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 exclude_nodata_value optional argument was added.</para>
</refsection>
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index 618d1292d..97cc83bff 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -1475,8 +1475,13 @@ rt_errorstate rt_band_get_pixel_bilinear(
double *r_value, int *r_nodata
-typedef enum {
+typedef enum
RT_NEAREST,
+ RT_NEAREST_UL,
+ RT_NEAREST_UR,
+ RT_NEAREST_LL,
+ RT_NEAREST_LR,
RT_BILINEAR
} rt_resample_type;
@@ -1487,7 +1492,7 @@ typedef enum {
* @param band : the band to read for values
* @param xr : x unrounded raster coordinate
* @param yr : y unrounded raster coordinate
- * @param resample : algorithm for reading raster (nearest or bilinear)
+ * @param resample : algorithm for reading raster
* @param r_value : return pointer for point value
* @param r_nodata : return pointer for if this is a nodata
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index 0fb95d1f8..cace34bfc 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -1386,6 +1386,18 @@ rt_errorstate rt_band_get_pixel_line(
return ES_NONE;
+static double
+rt_band_snap_pixel_coordinate(double coordinate)
+ double nearest = round(coordinate);
+ double tolerance = DBL_EPSILON * fmax(fabs(coordinate), 1.0) * 16.0;
+ if (fabs(coordinate - nearest) <= tolerance)
+ return nearest;
+ return coordinate;
* Retrieve a point value from the raster using a world coordinate
* and selected interpolation.
@@ -1411,11 +1423,25 @@ rt_band_get_pixel_resample(
band, xr, yr, r_value, r_nodata
- else if (resample == RT_NEAREST) {
- return rt_band_get_pixel(
- band, floor(xr), floor(yr),
- r_value, r_nodata
+ else if (resample == RT_NEAREST || resample == RT_NEAREST_UL || resample == RT_NEAREST_UR ||
+ resample == RT_NEAREST_LL || resample == RT_NEAREST_LR)
+ int x, y;
+ xr = rt_band_snap_pixel_coordinate(xr);
+ yr = rt_band_snap_pixel_coordinate(yr);
+ if (resample == RT_NEAREST_UL || resample == RT_NEAREST_LL)
+ x = ceil(xr) - 1;
+ else
+ x = floor(xr);
+ if (resample == RT_NEAREST_UL || resample == RT_NEAREST_UR)
+ y = ceil(yr) - 1;
+ else
+ y = floor(yr);
+ return rt_band_get_pixel(band, x, y, r_value, r_nodata);
else {
rtwarn("Invalid resample type requested %d", resample);
diff --git a/raster/rt_pg/rtpg_pixel.c b/raster/rt_pg/rtpg_pixel.c
index 9aa65ebea..3791353f3 100644
--- a/raster/rt_pg/rtpg_pixel.c
+++ b/raster/rt_pg/rtpg_pixel.c
@@ -141,16 +141,27 @@ Datum RASTER_getPixelValue(PG_FUNCTION_ARGS)
static rt_resample_type resample_text_to_type(text *txt)
+ rt_resample_type resample_type = RT_NEAREST;
char *resample = asc_tolower(VARDATA(txt), VARSIZE_ANY_EXHDR(txt));
- if (strncmp(resample, "bilinear", 8) == 0)
- return RT_BILINEAR;
- else if (strncmp(resample, "nearest", 7) == 0)
- return RT_NEAREST;
+ if (strcmp(resample, "bilinear") == 0)
+ resample_type = RT_BILINEAR;
+ else if (strcmp(resample, "nearest-ul") == 0)
+ resample_type = RT_NEAREST_UL;
+ else if (strcmp(resample, "nearest-ur") == 0)
+ resample_type = RT_NEAREST_UR;
+ else if (strcmp(resample, "nearest-ll") == 0)
+ resample_type = RT_NEAREST_LL;
+ else if (strcmp(resample, "nearest-lr") == 0)
+ resample_type = RT_NEAREST_LR;
+ else if (strcmp(resample, "nearest") == 0)
+ resample_type = RT_NEAREST;
else {
elog(ERROR, "Unknown resample type '%s' requested", resample);
pfree(resample);
+ return resample_type;
@@ -2506,4 +2517,3 @@ Datum RASTER_neighborhood(PG_FUNCTION_ARGS)
PG_RETURN_ARRAYTYPE_P(mdArray);
diff --git a/raster/test/regress/rt_pixelvalue.sql b/raster/test/regress/rt_pixelvalue.sql
index 2842e47d4..00071db9a 100644
--- a/raster/test/regress/rt_pixelvalue.sql
+++ b/raster/test/regress/rt_pixelvalue.sql
@@ -367,6 +367,57 @@ round(ST_Value(rast, 1, 'SRID=4326;POINT(0.5 0.5)'::geometry, resample => 'neare
round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'bilinear')) as nearest_10_10,
round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 0.1)'::geometry, resample => 'bilinear')) as nearest_10_00,
round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.9)'::geometry, resample => 'bilinear')) as nearest_10_20
-FROM r
+FROM r;
+WITH r AS (
+SELECT
+ST_SetValues(
+ ST_AddBand(
+ ST_MakeEmptyRaster(width => 2, height => 2,
+ upperleftx => 0, upperlefty => 2,
+ scalex => 1.0, scaley => -1.0,
+ skewx => 0, skewy => 0, srid => 4326),
+ index => 1, pixeltype => '16BSI',
+ initialvalue => 0,
+ nodataval => -999),
+ 1,1,1,
+ newvalueset =>ARRAY[ARRAY[10.0::float8, 50.0::float8], ARRAY[40.0::float8, 20.0::float8]]) AS rast
+SELECT
+'#2116',
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'nearest-ul')) as nearest_ul,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'nearest-ur')) as nearest_ur,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'nearest-ll')) as nearest_ll,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'nearest-lr')) as nearest_lr,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'nearest')) as nearest_default
+FROM r;
+WITH r AS (
+SELECT
+ST_SetValues(
+ ST_AddBand(
+ 1,1,1,
+SELECT
+'#2116.snap',
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0000000000000004 0.9999999999999996)'::geometry, resample => 'nearest-ul')) as nearest_ul,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(0.9999999999999997 1.0000000000000002)'::geometry, resample => 'nearest-lr')) as nearest_lr
+FROM r;
+WITH r AS (
+SELECT ST_AddBand(ST_MakeEmptyRaster(1, 1, 0, 1, 1, -1, 0, 0, 4326), '16BSI'::text, 1, -999) AS rast
+SELECT ST_Value(rast, 1, 'SRID=4326;POINT(0.5 0.5)'::geometry, resample => 'nearest-foo') FROM r;
+WITH r AS (
+SELECT ST_Value(rast, 1, 'SRID=4326;POINT(0.5 0.5)'::geometry, resample => 'bilinearXYZ') FROM r;
diff --git a/raster/test/regress/rt_pixelvalue_expected b/raster/test/regress/rt_pixelvalue_expected
index 7576caaff..989a306b4 100644
--- a/raster/test/regress/rt_pixelvalue_expected
+++ b/raster/test/regress/rt_pixelvalue_expected
@@ -11,3 +11,7 @@ NOTICE: Raster do not have a nodata value defined. Set band nodata value first.
NOTICE: Raster do not have a nodata value defined. Set band nodata value first. Nodata value not set. Returning original raster
Test 5|50|40|30|26|38
+#2116|10|50|40|20|20
+#2116.snap|10|20
+ERROR: Unknown resample type 'nearest-foo' requested
+ERROR: Unknown resample type 'bilinearxyz' requested
Summary of changes:
NEWS | 2 ++
doc/reference_raster.xml | 3 +-
raster/rt_core/librtcore.h | 9 +++--
raster/rt_core/rt_band.c | 36 +++++++++++++++++---
raster/rt_pg/rtpg_pixel.c | 22 +++++++++----
raster/test/regress/rt_pixelvalue.sql | 53 +++++++++++++++++++++++++++++-
raster/test/regress/rt_pixelvalue_expected | 4 +++
7 files changed, 114 insertions(+), 15 deletions(-)
hooks/post-receive
