[SCM] PostGIS branch master updated. 3.6.0rc2-643-g45c26068e
git at osgeo.org
git at osgeo.org
Sun Jun 21 07:13:12 PDT 2026
the project "PostGIS".
via 45c26068ef27de003a39e69c01532340063ecc13 (commit)
from 6884c2be41810eb4d02a1d0f88ca61439024f827 (commit)
revisions in full, below.
commit 45c26068ef27de003a39e69c01532340063ecc13
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jun 21 18:12:09 2026 +0400
Clarify shp2pgsql zip archive input
Report .zip archive input before the loader tries to open shapefile sidecar files, and document that shapefiles must be unpacked before loading.
References #1577
Closes https://github.com/postgis/postgis/pull/1109
diff --git a/NEWS b/NEWS
index c67f2b50f..20209cb38 100644
--- a/NEWS
+++ b/NEWS
@@ -57,6 +57,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Enhancements *
+ - #1577, [loader] Report unsupported .zip archive input before trying
+ to open shapefile sidecar files (Darafei Praliaskouski)
- #3158, Move geometry and geography typmod bit helpers out of the
public liblwgeom header (Darafei Praliaskouski)
- #2116, [raster] Add ST_Value nearest-neighbor boundary options
diff --git a/doc/man/shp2pgsql.1 b/doc/man/shp2pgsql.1
index c840c60f9..2cd3b9720 100644
--- a/doc/man/shp2pgsql.1
+++ b/doc/man/shp2pgsql.1
@@ -19,6 +19,8 @@ Version: 1.1.5 (2006/10/06)
The <shapefile> is the name of the shape file, without any extension
information. For example, 'roads' would be the name of the shapefile
comprising the 'roads.shp', 'roads.shx', and 'roads.dbf' files.
+Compressed archives are not read directly; unpack .zip packages before
+loading the shapefile components.
The <tablename> is the (optionally schema-qualified) name of the database
table you want the data stored in in the database. Within that table,
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 8f840a5ce..be8c75391 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1877,6 +1877,11 @@ COMMIT;</programlisting>
insertion into a PostGIS/PostgreSQL database either in geometry or geography format.
The loader has several operating modes selected by command line flags.
</para>
+ <para>
+ The input must be an unpacked shapefile path. The loader does not read
+ <filename>.zip</filename> archives directly; unpack the <filename>.shp</filename>,
+ <filename>.shx</filename>, and <filename>.dbf</filename> files before loading.
+ </para>
<para>There is also a <filename>shp2pgsql-gui</filename> graphical interface with most
of the options as the command-line loader.
This may be easier to use for one-off non-scripted loading or if you are new to PostGIS.
diff --git a/loader/cunit/cu_shp2pgsql.c b/loader/cunit/cu_shp2pgsql.c
index 01be2be03..c43f5ac55 100644
--- a/loader/cunit/cu_shp2pgsql.c
+++ b/loader/cunit/cu_shp2pgsql.c
@@ -20,6 +20,7 @@ void test_ShpLoaderDestroy(void);
void test_ShpLoaderGetSQLHeader_drop_prepare(void);
void test_ShpLoaderGetSQLHeader_if_not_exists_table_modifier(void);
void test_ShpLoaderGetSQLFooter_if_not_exists_index_modifier(void);
+void test_ShpLoaderOpenShapeRejectsZip(void);
SHPLOADERCONFIG *loader_config;
SHPLOADERSTATE *loader_state;
@@ -47,7 +48,8 @@ CU_pSuite register_shp2pgsql_suite(void)
test_ShpLoaderGetSQLHeader_if_not_exists_table_modifier)) ||
(NULL == CU_add_test(pSuite,
"test_ShpLoaderGetSQLFooter_if_not_exists_index_modifier()",
- test_ShpLoaderGetSQLFooter_if_not_exists_index_modifier)))
+ test_ShpLoaderGetSQLFooter_if_not_exists_index_modifier)) ||
+ (NULL == CU_add_test(pSuite, "test_ShpLoaderOpenShapeRejectsZip()", test_ShpLoaderOpenShapeRejectsZip)))
CU_cleanup_registry();
return NULL;
@@ -175,3 +177,28 @@ test_ShpLoaderGetSQLFooter_if_not_exists_index_modifier(void)
free(footer);
ShpLoaderDestroy(loader_state);
+void
+test_ShpLoaderOpenShapeRejectsZip(void)
+ int ret;
+ loader_config = (SHPLOADERCONFIG *)calloc(1, sizeof(SHPLOADERCONFIG));
+ set_loader_config_defaults(loader_config);
+ loader_config->shp_file = "fixtures/parcel.ZIP";
+ loader_state = ShpLoaderCreate(loader_config);
+ ret = ShpLoaderOpenShape(loader_state);
+ CU_ASSERT_EQUAL(ret, SHPLOADERERR);
+ CU_ASSERT_PTR_NOT_NULL(strstr(loader_state->message, "does not read .zip archives"));
+ ShpLoaderDestroy(loader_state);
+ loader_config->shp_file = "fixtures.zip/parcel";
+ loader_config->readshape = 0;
+ CU_ASSERT_PTR_NULL(strstr(loader_state->message, "does not read .zip archives"));
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 52226802a..394d5dd66 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -16,6 +16,7 @@
#include "../postgis_config.h"
#include <math.h> /* for isnan */
+#include <strings.h>
#include "shp2pgsql-core.h"
#include "../liblwgeom/liblwgeom.h"
@@ -55,7 +56,25 @@ int PIP(Point P, Point *V, int n);
int FindPolygons(SHPObject *obj, Ring ***Out);
void ReleasePolygons(Ring **polys, int npolys);
int GeneratePolygonGeometry(SHPLOADERSTATE *state, SHPObject *obj, char **geometry);
+static int shp_loader_is_zip_archive(const char *filename);
+static int
+shp_loader_is_zip_archive(const char *filename)
+ const char *basename;
+ const char *ext;
+ if (!filename)
+ return 0;
+ basename = strrchr(filename, '/');
+ if (!basename)
+ basename = strrchr(filename, '\\');
+ basename = basename ? basename + 1 : filename;
+ ext = strrchr(basename, '.');
+ return ext && strcasecmp(ext, ".zip") == 0;
/* Return allocated string containing UTF8 string converted from encoding fromcode */
static int
@@ -966,6 +985,15 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
DBFFieldType type = FTInvalid;
char *utf8str;
+ if (shp_loader_is_zip_archive(state->config->shp_file))
+ snprintf(state->message,
+ SHPLOADERMSGLEN,
+ _("%s: shp2pgsql does not read .zip archives; unpack the .shp, .shx, and .dbf files first."),
+ state->config->shp_file);
+ return SHPLOADERERR;
/* If we are reading the entire shapefile, open it */
if (state->config->readshape == 1)
Summary of changes:
NEWS | 2 ++
doc/man/shp2pgsql.1 | 2 ++
doc/using_postgis_dataman.xml | 5 +++++
loader/cunit/cu_shp2pgsql.c | 29 ++++++++++++++++++++++++++++-
loader/shp2pgsql-core.c | 28 ++++++++++++++++++++++++++++
5 files changed, 65 insertions(+), 1 deletion(-)
hooks/post-receive
