[SCM] PostGIS branch master updated. 3.6.0rc2-650-ga401974f9
Sun Jun 21 11:53:22 PDT 2026
the project "PostGIS".
       via  a401974f93be7586b3c7dbe9f7d686f3cad16061 (commit)
      from  1b74f201374035483b1d9e53f0fa4d981349f78b (commit)
revisions in full, below.
commit a401974f93be7586b3c7dbe9f7d686f3cad16061
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jun 21 22:40:45 2026 +0400
    Move raster st_sum4ma callback to C
    Replace the PL/pgSQL two-dimensional st_sum4ma callback with a C implementation while preserving nodata handling, including lazy replacement-value casting for wrapper-provided modes.
    Closes #4678
    Closes https://github.com/postgis/postgis/pull/1098
diff --git a/NEWS b/NEWS
index 2f67dfa1e..0f1dba4e5 100644
--- a/NEWS
+++ b/NEWS
@@ -63,6 +63,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           to open shapefile sidecar files (Darafei Praliaskouski)
  - #3158, Move geometry and geography typmod bit helpers out of the
           public liblwgeom header (Darafei Praliaskouski)
+ - #4678, [raster] Move st_sum4ma neighborhood callback to C
+          (Darafei Praliaskouski)
  - #2116, [raster] Add ST_Value nearest-neighbor boundary options
  - #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 36aad8f02..601c795e6 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -38,6 +38,7 @@
 #include <utils/lsyscache.h> /* for get_typlenbyvalalign */
 #include <utils/array.h> /* for ArrayType */
 #include <utils/builtins.h> /* for cstring_to_text */
+#include <utils/float.h>    /* for float8in */
 #include <catalog/pg_type.h> /* for INT2OID, INT4OID, FLOAT4OID, FLOAT8OID and TEXTOID */
 #include <executor/executor.h> /* for GetAttributeByName */
@@ -71,6 +72,7 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS);
 /* one-raster neighborhood MapAlgebra */
 Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS);
+Datum RASTER_sum4ma(PG_FUNCTION_ARGS);
 /* two-raster MapAlgebra */
 Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS);
@@ -79,6 +81,89 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS);
 /*  n-raster MapAlgebra                                             */
+ * Neighborhood callback for one-raster map algebra that implements ST_Sum4ma.
+ * The callback receives the moving-window values as a PostgreSQL float8 array
+ * and returns their sum.  NULL cells follow the historical PL/pgSQL contract:
+ * a NULL nodata mode makes the result NULL, "ignore" skips NULL cells, and any
+ * other mode is interpreted as the numeric replacement value.  The replacement
+ * mode is cast only when a NULL cell is actually encountered so wrapper-provided
+ * modes such as "NULL" and "value" remain valid for all-non-NULL windows.
+PG_FUNCTION_INFO_V1(RASTER_sum4ma);
+Datum
+RASTER_sum4ma(PG_FUNCTION_ARGS)
+	ArrayType *matrix;
+	Datum *values;
+	bool *nulls;
+	int nitems;
+	int i;
+	double sum = 0;
+	char *nodatamode = NULL;
+	bool ignore_nodata = false;
+	bool has_nodata_replacement = false;
+	double nodata_replacement = 0;
+	if (PG_ARGISNULL(0))
+		ereport(
+		    ERROR,
+		    (errcode(ERRCODE_NULL_VALUE_NOT_ALLOWED), errmsg("st_sum4ma: matrix argument must not be NULL")));
+	if (!PG_ARGISNULL(1))
+		nodatamode = text_to_cstring(PG_GETARG_TEXT_PP(1));
+		if (strcmp(nodatamode, "ignore") == 0)
+			ignore_nodata = true;
+	matrix = PG_GETARG_ARRAYTYPE_P(0);
+	if (ARR_NDIM(matrix) < 2)
+		ereport(ERROR,
+			(errcode(ERRCODE_ARRAY_SUBSCRIPT_ERROR),
+			 errmsg("st_sum4ma: matrix argument must have at least 2 dimensions")));
+	deconstruct_array(matrix, FLOAT8OID, sizeof(float8), FLOAT8PASSBYVAL, 'd', &values, &nulls, &nitems);
+	for (i = 0; i < nitems; i++)
+		if (nulls[i])
+			if (ignore_nodata)
+				continue;
+			if (!nodatamode)
+				pfree(nulls);
+				pfree(values);
+				PG_FREE_IF_COPY(matrix, 0);
+				PG_RETURN_NULL();
+			 * Match the PL/pgSQL callback: wrapper-provided modes such as
+			 * "NULL" and "value" are only cast when a NULL cell is present.
+			if (!has_nodata_replacement)
+				nodata_replacement =
+				    DatumGetFloat8(DirectFunctionCall1(float8in, CStringGetDatum(nodatamode)));
+				has_nodata_replacement = true;
+			sum += nodata_replacement;
+		else
+			sum += DatumGetFloat8(values[i]);
+	if (nodatamode)
+		pfree(nodatamode);
+	pfree(nulls);
+	pfree(values);
+	PG_RETURN_FLOAT8(sum);
 #if defined(__clang__)
 # pragma clang diagnostic push
 # pragma clang diagnostic ignored "-Wgnu-variable-sized-type-not-at-end"
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 96bb55ed8..aa09a7357 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -2541,30 +2541,9 @@ CREATE OR REPLACE FUNCTION st_min4ma(matrix float[][], nodatamode text, variadic
     LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION st_sum4ma(matrix float[][], nodatamode text, variadic args text[])
-    RETURNS float AS
-    DECLARE
-        _matrix float[][];
-        sum float;
-    BEGIN
-        _matrix := matrix;
-        sum := 0;
-        FOR x in array_lower(matrix, 1)..array_upper(matrix, 1) LOOP
-            FOR y in array_lower(matrix, 2)..array_upper(matrix, 2) LOOP
-                IF _matrix[x][y] IS NULL THEN
-                    IF nodatamode = 'ignore' THEN
-                        _matrix[x][y] := 0;
-                    ELSE
-                        _matrix[x][y] := nodatamode::float;
-                    END IF;
-                END IF;
-                sum := sum + _matrix[x][y];
-            END LOOP;
-        END LOOP;
-        RETURN sum;
-    END;
-    LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
+    RETURNS float
+    AS 'MODULE_PATHNAME', 'RASTER_sum4ma'
+    LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION st_mean4ma(matrix float[][], nodatamode text, variadic args text[])
     RETURNS float AS
diff --git a/raster/test/regress/rt_4ma.sql b/raster/test/regress/rt_4ma.sql
index 1a3b214f3..57798b735 100644
--- a/raster/test/regress/rt_4ma.sql
+++ b/raster/test/regress/rt_4ma.sql
@@ -78,5 +78,20 @@ SELECT
 FROM raster_value_arrays
 ORDER BY id;
+SELECT
+	'sum4ma.nodata',
+	st_sum4ma(ARRAY[[1::double precision, NULL, 3]], NULL, VARIADIC NULL::text[]) IS NULL,
+	st_sum4ma(ARRAY[[1::double precision, NULL, 3]], 'ignore', VARIADIC NULL::text[]),
+	st_sum4ma(ARRAY[[1::double precision, NULL, 3]], '-8', VARIADIC NULL::text[]);
+SELECT
+	'sum4ma.mode.no-null',
+	st_sum4ma(ARRAY[[1::double precision, 2, 3]], 'NULL', VARIADIC NULL::text[]),
+	st_sum4ma(ARRAY[[1::double precision, 2, 3]], 'value', VARIADIC NULL::text[]);
+SELECT
+	'sum4ma.runtime-3d',
+	st_sum4ma('{{{1,2,3},{4,5,6}}}'::double precision[][], NULL, VARIADIC NULL::text[]);
 DROP TABLE IF EXISTS raster_value_arrays;
 DROP FUNCTION IF EXISTS make_value_array(integer, integer, double precision, double precision, text);
diff --git a/raster/test/regress/rt_4ma_expected b/raster/test/regress/rt_4ma_expected
index d6ec1c2b2..c91079c10 100644
--- a/raster/test/regress/rt_4ma_expected
+++ b/raster/test/regress/rt_4ma_expected
@@ -15,3 +15,6 @@ NOTICE:  table "raster_value_arrays" does not exist, skipping
 16|{{{1,3.1,5.2},{NULL,NULL,11.5},{13.6,NULL,NULL}}}|5.000000|13.600000|6.880000|1.000000|12.600000|5.435715|34.400000
 17|{{{NULL,3.14,NULL},{NULL,12.56,NULL},{NULL,NULL,25.12}}}|3.000000|25.120000|13.606667|3.140000|21.980000|11.027318|40.820000
 18|{{{NULL,NULL,NULL},{NULL,NULL,NULL},{NULL,NULL,9}}}|1.000000|9.000000|9.000000|9.000000|0.000000||9.000000
+sum4ma.nodata|t|4|-4
+sum4ma.mode.no-null|6|6
+sum4ma.runtime-3d|21
Summary of changes:
 NEWS                                |  2 +
 raster/rt_pg/rtpg_mapalgebra.c      | 85 +++++++++++++++++++++++++++++++++++++
 raster/rt_pg/rtpostgis.sql.in       | 27 ++----------
 raster/test/regress/rt_4ma.sql      | 15 +++++++
 raster/test/regress/rt_4ma_expected |  3 ++
 5 files changed, 108 insertions(+), 24 deletions(-)
hooks/post-receive
