[SCM] PostGIS branch master updated. 3.6.0rc2-651-g92903a731
git at osgeo.org
git at osgeo.org
Sun Jun 21 12:09:29 PDT 2026
the project "PostGIS".
via 92903a731a5dc918318e57c0746ba407d84eccdc (commit)
from a401974f93be7586b3c7dbe9f7d686f3cad16061 (commit)
revisions in full, below.
commit 92903a731a5dc918318e57c0746ba407d84eccdc
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jun 21 23:01:47 2026 +0400
loader: preserve numeric DBF metadata in pgsql2shp
Decode numeric typmod precision and scale when selecting DBF field metadata so pgsql2shp preserves fixed numeric declarations that fit in the DBF field-width limit. Keep legacy 32,10 metadata for untyped numeric values.
Add pgsql2shp dumper coverage for portable numeric typmods, and gate PostgreSQL 15+ negative-scale numeric coverage behind the configured PostgreSQL version.
Closes #2850
Closes https://github.com/postgis/postgis/pull/1020
diff --git a/.gitignore b/.gitignore
index 9b374cdea..57649dd75 100644
--- a/.gitignore
+++ b/.gitignore
@@ -31,6 +31,7 @@ doc/html/images/Makefile
regression.out
raster/test/regress/tests.mk
regress/core/tests.mk
+regress/dumper/tests.mk
sfcgal/regress/tests.mk
@@ -177,6 +178,7 @@ regress/Makefile
regress/core/Makefile
regress/dumper/Makefile
regress/loader/Makefile
regress/real/download_data
regress/real/Makefile
diff --git a/GNUmakefile.in b/GNUmakefile.in
index e65fd23e4..961f53c9b 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -288,7 +288,7 @@ postgis_revision.h:
include $(top_builddir)/regress/core/tests.mk
include $(top_srcdir)/regress/loader/tests.mk
-include $(top_srcdir)/regress/dumper/tests.mk
+include $(top_builddir)/regress/dumper/tests.mk
ifeq ($(HAVE_SFCGAL),yes)
override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
include $(top_builddir)/sfcgal/regress/tests.mk
diff --git a/NEWS b/NEWS
index 0f1dba4e5..117a044bc 100644
--- a/NEWS
+++ b/NEWS
@@ -94,6 +94,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
shapefiles (Darafei Praliaskouski)
- Fix WKB and TWKB parser resource exhaustion on malformed input
+ - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
+ (Darafei Praliaskouski)
- #6083, Pass configured dependency include paths to fuzzer smoke builds
- #3103, Add regression coverage for exact-schema find_srid and
diff --git a/configure.ac b/configure.ac
index 57157d133..9324966ee 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1902,6 +1902,7 @@ AC_CONFIG_FILES([GNUmakefile
+ regress/dumper/tests.mk
doc/Makefile
doc/Makefile.comments
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 14da7a716..334b2b7c2 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -59,6 +59,8 @@ static char *nullDBFValue(char fieldType);
static int getMaxFieldSize(PGconn *conn, char *schema, char *table, char *fname);
static int getTableInfo(SHPDUMPERSTATE *state);
static int projFileCreate(SHPDUMPERSTATE *state);
+static int numeric_typmod_precision(int typmod);
+static int numeric_typmod_scale(int typmod);
* @brief Make appropriate formatting of a DBF value based on type.
@@ -87,6 +89,24 @@ core_asprintf(const char* format, ...)
return value;
+static int
+numeric_typmod_precision(int typmod)
+ return ((typmod - 4) >> 16) & 0xffff;
+static int
+numeric_typmod_scale(int typmod)
+ int scale = (typmod - 4) & 0x7ff;
+ /* PostgreSQL stores numeric scale as an 11-bit signed value. */
+ if (scale & 0x400)
+ scale |= ~0x7ff;
+ return scale;
static SHPObject *
create_point_empty(SHPDUMPERSTATE *state, LWPOINT *lwpoint)
@@ -1613,21 +1633,52 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
- * double or numeric types:
+ * double types:
* 700: float4
* 701: float8
- * 1700: numeric
- * TODO: stricter handling of sizes
- else if (pgfieldtype == 700 || pgfieldtype == 701 || pgfieldtype == 1700)
+ else if (pgfieldtype == 700 || pgfieldtype == 701)
dbffieldtype = FTDouble;
dbffieldsize = 32;
dbffielddecs = 10;
+ * Numeric type (1700). Preserve declared precision and scale
+ * when PostgreSQL exposes a typmod and DBF can represent it.
+ else if (pgfieldtype == 1700)
+ dbffieldtype = FTDouble;
+ dbffieldsize = 32;
+ dbffielddecs = 10;
+ if (pgtypmod >= 0)
+ int precision = numeric_typmod_precision(pgtypmod);
+ int scale = numeric_typmod_scale(pgtypmod);
+ int integral_digits = precision - scale;
+ int dbfsize;
+ if (integral_digits < 1)
+ integral_digits = 1;
+ if (scale > 0)
+ dbfsize = 1 + integral_digits + 1 + scale;
+ else
+ dbfsize = 1 + precision - scale;
+ if (dbfsize <= MAX_DBF_FIELD_SIZE)
+ dbffieldsize = dbfsize;
+ dbffielddecs = (scale > 0) ? scale : 0;
+ if (dbffielddecs == 0)
+ dbffieldtype = FTInteger;
* Boolean field, we use FTLogical
diff --git a/regress/Makefile.in b/regress/Makefile.in
index cc4b8dfff..32f6d41c2 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -57,7 +57,7 @@ check-unit:
include $(builddir)/core/tests.mk
include $(srcdir)/loader/tests.mk
-include $(srcdir)/dumper/tests.mk
+include $(builddir)/dumper/tests.mk
include $(srcdir)/runtest.mk
@@ -71,6 +71,7 @@ distclean: clean
rm -f core/tests.mk
rm -f loader/Makefile
rm -f dumper/Makefile
+ rm -f dumper/tests.mk
staged-install-sfcgal:
@if test x"@SFCGAL@" != "x"; then \
diff --git a/regress/dumper/numeric.dmp b/regress/dumper/numeric.dmp
new file mode 100644
index 000000000..0614d2e2c
--- /dev/null
+++ b/regress/dumper/numeric.dmp
@@ -0,0 +1 @@
+SELECT 1.23::numeric(3,2) AS n32, 0.123456789012::numeric(12,12) AS n1212, 123::numeric(3,0) AS n30, (-123)::numeric(3,0) AS n30neg, 123.45::numeric(5,2) AS n52, 1.2345678901234::numeric AS nuntyped, ST_Point(0, 0) AS geom;
diff --git a/regress/dumper/numeric_expected.dbf b/regress/dumper/numeric_expected.dbf
index 000000000..fed815fc7
Binary files /dev/null and b/regress/dumper/numeric_expected.dbf differ
diff --git a/regress/dumper/numeric_expected.shp b/regress/dumper/numeric_expected.shp
index 000000000..0112cd743
Binary files /dev/null and b/regress/dumper/numeric_expected.shp differ
diff --git a/regress/dumper/numeric_expected.shx b/regress/dumper/numeric_expected.shx
index 000000000..cc0b42ae7
Binary files /dev/null and b/regress/dumper/numeric_expected.shx differ
diff --git a/regress/dumper/numeric_negative_scale.dmp b/regress/dumper/numeric_negative_scale.dmp
index 000000000..9820a6b38
--- /dev/null
+++ b/regress/dumper/numeric_negative_scale.dmp
@@ -0,0 +1 @@
+SELECT 1200::numeric(4,-2) AS n4m2, ST_Point(0, 0) AS geom;
diff --git a/regress/dumper/numeric_negative_scale_expected.dbf b/regress/dumper/numeric_negative_scale_expected.dbf
index 000000000..b3377c107
Binary files /dev/null and b/regress/dumper/numeric_negative_scale_expected.dbf differ
diff --git a/regress/dumper/numeric_negative_scale_expected.shp b/regress/dumper/numeric_negative_scale_expected.shp
Binary files /dev/null and b/regress/dumper/numeric_negative_scale_expected.shp differ
diff --git a/regress/dumper/numeric_negative_scale_expected.shx b/regress/dumper/numeric_negative_scale_expected.shx
Binary files /dev/null and b/regress/dumper/numeric_negative_scale_expected.shx differ
diff --git a/regress/dumper/tests.mk b/regress/dumper/tests.mk.in
similarity index 71%
rename from regress/dumper/tests.mk
rename to regress/dumper/tests.mk.in
index d3417dc8f..5d82f2ddf 100644
--- a/regress/dumper/tests.mk
+++ b/regress/dumper/tests.mk.in
@@ -4,16 +4,25 @@
# * http://postgis.net
# * Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
+# * Copyright (C) 2026 Darafei Praliaskouski <me at komzpa.net>
# * This is free software; you can redistribute and/or modify it under
# * the terms of the GNU General Public Licence. See the COPYING file.
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
TESTS += \
$(top_srcdir)/regress/dumper/mfiledmp \
$(top_srcdir)/regress/dumper/literalsrid \
$(top_srcdir)/regress/dumper/realtable \
$(top_srcdir)/regress/dumper/nullsintable \
$(top_srcdir)/regress/dumper/null3d \
+ $(top_srcdir)/regress/dumper/numeric \
$(top_srcdir)/regress/dumper/withclause
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 150),1)
+ TESTS += \
+ $(top_srcdir)/regress/dumper/numeric_negative_scale
+endif
Summary of changes:
.gitignore | 2 +
GNUmakefile.in | 2 +-
NEWS | 2 +
configure.ac | 1 +
loader/pgsql2shp-core.c | 63 +++++++++++++++++++--
regress/Makefile.in | 3 +-
regress/dumper/numeric.dmp | 1 +
regress/dumper/numeric_expected.dbf | Bin 0 -> 293 bytes
...teralsrid_expected.shp => numeric_expected.shp} | Bin
...teralsrid_expected.shx => numeric_expected.shx} | Bin
regress/dumper/numeric_negative_scale.dmp | 1 +
regress/dumper/numeric_negative_scale_expected.dbf | Bin 0 -> 73 bytes
...ted.shp => numeric_negative_scale_expected.shp} | Bin
...ted.shx => numeric_negative_scale_expected.shx} | Bin
regress/dumper/{tests.mk => tests.mk.in} | 9 +++
15 files changed, 76 insertions(+), 8 deletions(-)
create mode 100644 regress/dumper/numeric.dmp
create mode 100644 regress/dumper/numeric_expected.dbf
copy regress/dumper/{literalsrid_expected.shp => numeric_expected.shp} (100%)
copy regress/dumper/{literalsrid_expected.shx => numeric_expected.shx} (100%)
create mode 100644 regress/dumper/numeric_negative_scale.dmp
create mode 100644 regress/dumper/numeric_negative_scale_expected.dbf
copy regress/dumper/{literalsrid_expected.shp => numeric_negative_scale_expected.shp} (100%)
copy regress/dumper/{literalsrid_expected.shx => numeric_negative_scale_expected.shx} (100%)
rename regress/dumper/{tests.mk => tests.mk.in} (71%)
hooks/post-receive
