[PostGIS] #2627: st_linetocurve() pta_desegmentize needs implementation for npoints < 4
trac at osgeo.org
Mon Jun 22 01:39:09 PDT 2026
Reporter: mjurce | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 2.0.x
Resolution: wontfix | Keywords: curves
Changes (by komzpa):
* resolution: => wontfix
* status: new => closed
Comment:
The option I see is to perform either
https://postgis.net/docs/ST_ChaikinSmoothing.html or
https://postgis.net/docs/manual-dev/ST_CatmullRomSmoothing.html to give
the line more points so that interpretation of curvature is less
surprising. Additionally look at hot new https://postgis.net/docs/manual-
dev/ST_MakeNurbsCurve.html. Otherwise it is not clear how to implement
this, if you wish to contribute a patch you're welcome to do it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2627#comment:13>
