[PostGIS] #110: shp2pgsql new option to not batch commit
trac at osgeo.org
Mon Jun 22 12:40:34 PDT 2026
Reporter: robe | Owner: mcayland
Type: enhancement | Status: closed
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: master
Resolution: fixed | Keywords:
Changes (by komzpa):
* milestone: PostGIS Fund Me => PostGIS 2.0.0
Old description:
> '''What steps will reproduce the problem?'''
> 1. If you have some geometries that fail insert such as polygons without
> closed rings, it kills the current batch and gives a more or less
> meaningless message
> 2. This has happened to me a lot and a lot of users we train. A lot of
> the
> time the data should just rightfully not be added.
> 3. Write now to overcome this I generate a .sql file and use sed to
> remove
> the begin commits which means I can't use the normal | to directly load
> I think the simplest option is to allow users with a flag to have the
> option to not have begin commits so that everything is in its own
> transaction. That way at least a whole batch of good records aren't lost
> because of one bad apple.
> I know we have talked about other options such as allowing these beasts
> into the database or nulling the geometry if invalid etc -- though those
> options are trickier to implement and may not handle all cases.
New description:
meaningless message
the
3. Write now to overcome this I generate a .sql file and use sed to remove
Ticket URL: <https://trac.osgeo.org/postgis/ticket/110#comment:18>
