[SCM] PostGIS branch stable-3.4 updated. 3.4.6-14-g24ea85852
Mon Jun 22 14:34:56 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  24ea85852f981ae830f145b31f552932d3a1b698 (commit)
      from  4201384f1cf1518cecb9008b394f9d3478386033 (commit)
revisions in full, below.
commit 24ea85852f981ae830f145b31f552932d3a1b698
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jun 22 14:34:08 2026 -0700
    Avoid out-of-bounds write, uninitialized memory.
diff --git a/extensions/address_standardizer/gamma.c b/extensions/address_standardizer/gamma.c
index 0824c6535..d802e86fb 100644
--- a/extensions/address_standardizer/gamma.c
+++ b/extensions/address_standardizer/gamma.c
@@ -122,7 +122,7 @@ RULES *rules_init( ERR_PARAM *err_p ) {
     rules->rule_number = 0;
     rules->last_node = EPSILON;
-    PAGC_ALLOC_STRUC(r_p,RULE_PARAM,err_p,NULL) ;
+    PAGC_CALLOC_STRUC(r_p,RULE_PARAM,1,err_p,NULL) ;
     rules->r_p = r_p;
     /* -- initialize the statistics record -- */
diff --git a/extensions/address_standardizer/std_pg_hash.c b/extensions/address_standardizer/std_pg_hash.c
index 9b6d6af1c..100d35838 100644
--- a/extensions/address_standardizer/std_pg_hash.c
+++ b/extensions/address_standardizer/std_pg_hash.c
@@ -534,12 +534,12 @@ static int parse_rule(char *buf, int *rule)
     while (1) {
+        if (nr >= MAX_RULE_LENGTH) return -1;
         *r = strtol( p, &q, 10 );
         if (p == q) break;
         p = q;
         nr++;
         r++;
-        if (nr > MAX_RULE_LENGTH) return -1;
     return nr;
Summary of changes:
 extensions/address_standardizer/gamma.c       | 2 +-
 extensions/address_standardizer/std_pg_hash.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
