[SCM] PostGIS branch stable-3.5 updated. 3.5.7-5-ge496c9b39
git at osgeo.org
git at osgeo.org
Tue Jun 23 10:36:52 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via e496c9b399740e66aa77c623693a6799394311b6 (commit)
via bd62edda08c9090135f5e7d1f90353e374d31fba (commit)
via 7edd266fd42a8f42b4de59411599899fbc749c65 (commit)
from af18826ce1375c9bd518a7bf6e71e9bc4b4bfdff (commit)
revisions in full, below.
commit e496c9b399740e66aa77c623693a6799394311b6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 23 10:36:25 2026 -0700
News entry for OSSFuzz 525554772
diff --git a/NEWS b/NEWS
index 4fd2190ae..506a1c565 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.5.7
- #5916, ST_Split hang with very large ordinates (Paul Ramsey)
- #5989, CurvePolygon distance corner case (Paul Ramsey)
- #5357, ST_LineFromEncodedPolyline dropping close points (Paul Ramsey)
+ - OSSFuzz 525554772, avoid signed integer overflow (Even Rouault)
PostGIS 3.5.6
commit bd62edda08c9090135f5e7d1f90353e374d31fba
Date: Tue Jun 23 10:32:25 2026 -0700
checkout v6
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 120c7f25d..c2c7797a2 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -44,7 +44,7 @@ jobs:
# sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
- name: 'Check Out'
- uses: actions/checkout at v3
+ uses: actions/checkout at v6
- name: 'Prepare Image'
run: |
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index e6e1ae234..eb6420645 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -37,7 +37,7 @@ jobs:
steps:
- name: Checkout repository
- uses: actions/checkout at v4
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 602f177c2..5a68ee1be 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -22,7 +22,7 @@ jobs:
steps:
# see https://github.com/msys2/setup-msys2
- name: checkout
- name: '${{ matrix.icon }} Setup MSYS2'
uses: msys2/setup-msys2 at v2
with:
commit 7edd266fd42a8f42b4de59411599899fbc749c65
Date: Tue Jun 23 10:23:43 2026 -0700
Fix to OSSFuzz https://issues.oss-fuzz.com/issues/525554772
ptarray_from_twkb_state(): avoid signed integer overflow
From Even Rouault, @rouault
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 5e0f0cfd0..11acecd4d 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -224,6 +224,42 @@ static void test_twkb_in_precision(void)
+static void
+test_twkb_in_coordinate_delta_overflow(void)
+ const uint8_t twkb[] = {0x02, /* LINESTRING with default precision. */
+ 0x00,
+ 0x02, /* Two points. */
+ 0xfe,
+ 0xff,
+ 0xff,
+ 0xff,
+ 0xff,
+ 0xff, /* X = INT64_MAX. */
+ 0xff,
+ 0xff,
+ 0xff,
+ 0x01,
+ 0x00, /* Y = 0. */
+ 0x02, /* X delta = 1. */
+ 0x00};
+ LWGEOM *geom;
+ cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, sizeof(twkb), LW_PARSER_CHECK_NONE);
+ /* TWKB stores coordinate deltas as signed integers. Malformed or fuzzed
+ * inputs can wrap the accumulated delta; the parser must make that wrap
+ * explicit instead of relying on undefined signed-overflow behaviour.
+ ASSERT_STRING_EQUAL(cu_error_msg, "");
+ CU_ASSERT_PTR_NOT_NULL(geom);
+ if (geom != NULL)
+ lwgeom_free(geom);
** Used by test harness to register the tests in this file.
@@ -239,4 +275,5 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_multipolygon);
PG_ADD_TEST(suite, test_twkb_in_collection);
PG_ADD_TEST(suite, test_twkb_in_precision);
+ PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_overflow);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 72fc53306..5066f613d 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -164,6 +164,19 @@ static uint8_t byte_from_twkb_state(twkb_parse_state *s)
return val;
+/** Implements *pa += b in a sanitizer friendly way, using wrap around
+ * logic in case of overflow
+#if __clang_major__ >= 4
+__attribute__((no_sanitize("unsigned-integer-overflow")))
+#endif
+static inline void safe_add_int64(int64_t* pa, int64_t b)
+ uint64_t u_a = (uint64_t)*pa;
+ uint64_t u_b = (uint64_t)b;
+ u_a += u_b;
+ memcpy(pa, &u_a, sizeof(int64_t));
* POINTARRAY
@@ -189,24 +202,24 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
int j = 0;
/* X */
- s->coords[j] += twkb_parse_state_varint(s);
+ safe_add_int64(&(s->coords[j]), twkb_parse_state_varint(s));
dlist[ndims*i + j] = s->coords[j] / s->factor;
j++;
/* Y */
j++;
/* Z */
if ( s->has_z )
dlist[ndims*i + j] = s->coords[j] / s->factor_z;
j++;
/* M */
if ( s->has_m )
dlist[ndims*i + j] = s->coords[j] / s->factor_m;
j++;
Summary of changes:
.github/workflows/ci.yml | 2 +-
.github/workflows/codeql.yml | 2 +-
.github/workflows/msys.yml | 2 +-
NEWS | 1 +
liblwgeom/cunit/cu_in_twkb.c | 37 +++++++++++++++++++++++++++++++++++++
liblwgeom/lwin_twkb.c | 21 +++++++++++++++++----
6 files changed, 58 insertions(+), 7 deletions(-)
hooks/post-receive
