[SCM] PostGIS branch stable-3.3 updated. 3.3.10-14-gebb7fa94d
git at osgeo.org
git at osgeo.org
Tue Jun 23 10:36:56 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via ebb7fa94d8566759a7d17788203d2d4c51af9251 (commit)
via 042033350e03984901fa39514a18e4db945cb4cc (commit)
from 5964d6f1ae4d2ea69f2a8a76f260674bab2e93b4 (commit)
revisions in full, below.
commit ebb7fa94d8566759a7d17788203d2d4c51af9251
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 23 10:36:30 2026 -0700
News entry for OSSFuzz 525554772
diff --git a/NEWS b/NEWS
index bea7bd871..990128c02 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ PostGIS 3.3.11
- #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
- #5916, ST_Split hang with very large ordinates (Paul Ramsey)
- #5989, CurvePolygon distance corner case (Paul Ramsey)
+ - OSSFuzz 525554772, avoid signed integer overflow (Even Rouault)
PostGIS 3.3.10
commit 042033350e03984901fa39514a18e4db945cb4cc
Date: Tue Jun 23 10:23:43 2026 -0700
Fix to OSSFuzz https://issues.oss-fuzz.com/issues/525554772
ptarray_from_twkb_state(): avoid signed integer overflow
From Even Rouault, @rouault
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 6dcc39a96..d8f24c9d8 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -224,6 +224,42 @@ static void test_twkb_in_precision(void)
+static void
+test_twkb_in_coordinate_delta_overflow(void)
+ const uint8_t twkb[] = {0x02, /* LINESTRING with default precision. */
+ 0x00,
+ 0x02, /* Two points. */
+ 0xfe,
+ 0xff,
+ 0xff,
+ 0xff,
+ 0xff,
+ 0xff, /* X = INT64_MAX. */
+ 0xff,
+ 0xff,
+ 0xff,
+ 0x01,
+ 0x00, /* Y = 0. */
+ 0x02, /* X delta = 1. */
+ 0x00};
+ LWGEOM *geom;
+ cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, sizeof(twkb), LW_PARSER_CHECK_NONE);
+ /* TWKB stores coordinate deltas as signed integers. Malformed or fuzzed
+ * inputs can wrap the accumulated delta; the parser must make that wrap
+ * explicit instead of relying on undefined signed-overflow behaviour.
+ ASSERT_STRING_EQUAL(cu_error_msg, "");
+ CU_ASSERT_PTR_NOT_NULL(geom);
+ if (geom != NULL)
+ lwgeom_free(geom);
** Used by test harness to register the tests in this file.
@@ -239,4 +275,5 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_multipolygon);
PG_ADD_TEST(suite, test_twkb_in_collection);
PG_ADD_TEST(suite, test_twkb_in_precision);
+ PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_overflow);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 445b4a9b0..069a70609 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -164,6 +164,19 @@ static uint8_t byte_from_twkb_state(twkb_parse_state *s)
return val;
+/** Implements *pa += b in a sanitizer friendly way, using wrap around
+ * logic in case of overflow
+#if __clang_major__ >= 4
+__attribute__((no_sanitize("unsigned-integer-overflow")))
+#endif
+static inline void safe_add_int64(int64_t* pa, int64_t b)
+ uint64_t u_a = (uint64_t)*pa;
+ uint64_t u_b = (uint64_t)b;
+ u_a += u_b;
+ memcpy(pa, &u_a, sizeof(int64_t));
* POINTARRAY
@@ -189,24 +202,24 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
int j = 0;
/* X */
- s->coords[j] += twkb_parse_state_varint(s);
+ safe_add_int64(&(s->coords[j]), twkb_parse_state_varint(s));
dlist[ndims*i + j] = s->coords[j] / s->factor;
j++;
/* Y */
j++;
/* Z */
if ( s->has_z )
dlist[ndims*i + j] = s->coords[j] / s->factor_z;
j++;
/* M */
if ( s->has_m )
dlist[ndims*i + j] = s->coords[j] / s->factor_m;
j++;
Summary of changes:
NEWS | 1 +
liblwgeom/cunit/cu_in_twkb.c | 37 +++++++++++++++++++++++++++++++++++++
liblwgeom/lwin_twkb.c | 21 +++++++++++++++++----
3 files changed, 55 insertions(+), 4 deletions(-)
hooks/post-receive
