the project "PostGIS".
via 322177e5376d9e38e0694b72403770755c80adb6 (commit)
via b7b0441412680f043caa0f8ef776232c63bc5df0 (commit)
from 98bf6ad503163840afa6422b99dad6f4c5b658ce (commit)
revisions in full, below.
commit 322177e5376d9e38e0694b72403770755c80adb6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jun 24 17:49:27 2026 +0000
Restrict number of added edges to 100 in catmull smoothing
diff --git a/liblwgeom/cunit/cu_catmullrom.c b/liblwgeom/cunit/cu_catmullrom.c
index 1d9ff4e0c..775394fb3 100644
--- a/liblwgeom/cunit/cu_catmullrom.c
+++ b/liblwgeom/cunit/cu_catmullrom.c
@@ -3,7 +3,7 @@
* PostGIS - Spatial Types for PostgreSQL
* http://postgis.net
- * Copyright 2026 PostGIS contributors
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU General Public Licence. See the COPYING file.
@@ -188,6 +188,22 @@ do_test_catmull_rom_points(void)
do_test_catmull_rom("MULTIPOINT((1 2),(3 4))", "MULTIPOINT(1 2,3 4)", 5);
+static void
+do_test_catmull_rom_nsegments_cap(void)
+ LWGEOM *geom_in, *geom_out;
+ cu_error_msg_reset();
+ geom_in = lwgeom_from_wkt("LINESTRING(0 0,1 0,2 0,3 0)", LW_PARSER_CHECK_NONE);
+ geom_out = lwgeom_catmull_rom(geom_in, 101);
+ ASSERT_STRING_EQUAL(cu_error_msg, "lwgeom_catmull_rom: nSegments must be <= 100");
+ lwgeom_free(geom_in);
+ if (geom_out)
+ lwgeom_free(geom_out);
void catmullrom_suite_setup(void);
@@ -198,4 +214,5 @@ void catmullrom_suite_setup(void)
PG_ADD_TEST(suite, do_test_catmull_rom_polygons);
PG_ADD_TEST(suite, do_test_catmull_rom_zm);
PG_ADD_TEST(suite, do_test_catmull_rom_points);
+ PG_ADD_TEST(suite, do_test_catmull_rom_nsegments_cap);
diff --git a/liblwgeom/lwsmoothing.c b/liblwgeom/lwsmoothing.c
index 8d7e256f5..4b98ae9dc 100644
--- a/liblwgeom/lwsmoothing.c
+++ b/liblwgeom/lwsmoothing.c
@@ -412,6 +412,11 @@ lwcollection_catmull_rom(const LWCOLLECTION *igeom, int n_segments)
LWGEOM *
lwgeom_catmull_rom(const LWGEOM *igeom, int n_segments)
+ if (n_segments > 100)
+ lwerror("lwgeom_catmull_rom: nSegments must be <= 100");
+ return NULL;
switch (igeom->type)
case POINTTYPE:
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index 6d6ca9e55..c424ba177 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -178,8 +178,8 @@ Datum LWGEOM_CatmullRomSmoothing(PG_FUNCTION_ARGS)
if ((PG_NARGS() > 1) && (!PG_ARGISNULL(1)))
n_segments = PG_GETARG_INT32(1);
- if (n_segments < 2)
- elog(ERROR, "nSegments must be >= 2: %s", __func__);
+ if (n_segments < 2 || n_segments > 100)
+ elog(ERROR, "nSegments must be between 2 and 100: %s", __func__);
in = lwgeom_from_gserialized(geom);
out = lwgeom_catmull_rom(in, n_segments);
diff --git a/regress/core/catmullrom.sql b/regress/core/catmullrom.sql
index fe4d9d533..e88cff3f2 100644
--- a/regress/core/catmullrom.sql
+++ b/regress/core/catmullrom.sql
@@ -37,3 +37,6 @@ SELECT '10', postgis_getbbox(g) AS box FROM geom;
-- Triangle polygon ring has npoints-1=3 unique pts (<4), return original
SELECT '11', ST_AsText(ST_CatmullRomSmoothing('POLYGON((0 0, 4 0, 2 4, 0 0))', 5));
+-- Maximum nSegments of 100 is accepted
+SELECT '12', ST_NPoints(ST_CatmullRomSmoothing('LINESTRING(0 0, 1 0, 2 0, 3 0)', 100));
diff --git a/regress/core/catmullrom_expected b/regress/core/catmullrom_expected
index ef9dcc837..c972e5153 100644
--- a/regress/core/catmullrom_expected
+++ b/regress/core/catmullrom_expected
@@ -9,3 +9,4 @@
9|LINESTRING Z (0 0 0,0.5 0 5,1 0 10,1.5 0 15,2 0 20,2.5 0 25,3 0 30)
10|BOX(0 0,3 0)
11|POLYGON((0 0,4 0,2 4,0 0))
+12|301
commit b7b0441412680f043caa0f8ef776232c63bc5df0
Date: Wed Jun 24 17:48:56 2026 +0000
Ignore postgis/cunit/cu_tester
diff --git a/.gitignore b/.gitignore
index 57649dd75..b7343eb5a 100644
--- a/.gitignore
+++ b/.gitignore
@@ -129,6 +129,7 @@ macros/ltversion.m4
*.o
postgis_config.h
postgis/Makefile
+postgis/cunit/cu_tester
postgis/geobuf.pb-c.c
postgis/geobuf.pb-c.h
postgis/legacy_gist.sql
Summary of changes:
.gitignore | 1 +
liblwgeom/cunit/cu_catmullrom.c | 19 ++++++++++++++++++-
liblwgeom/lwsmoothing.c | 5 +++++
postgis/lwgeom_functions_analytic.c | 4 ++--
regress/core/catmullrom.sql | 3 +++
regress/core/catmullrom_expected | 1 +
6 files changed, 30 insertions(+), 3 deletions(-)
hooks/post-receive
