[SCM] PostGIS branch master updated. 3.6.0rc2-667-g8d5beebec
Wed Jun 24 12:09:47 PDT 2026
the project "PostGIS".
       via  8d5beebec253506a5999ca8cb833d3b3afe31cc5 (commit)
      from  c444ca85e9b97bbd020d45ce12b0ac04b7602c4d (commit)
revisions in full, below.
commit 8d5beebec253506a5999ca8cb833d3b3afe31cc5
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Jun 24 23:07:20 2026 +0400
    Add standard_conforming_strings_off CI job
    Run the GitHub CI test suite under stable PG18 with the standard-conforming-strings-off hook. This covers string-literal compatibility in the GitHub Actions matrix without relying on the Woodie-only pgextwlist setup hook.
    Closes https://github.com/postgis/postgis/pull/1119
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index d8bee82ae..4ae0ea35b 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -33,6 +33,7 @@ jobs:
         #- { tag: pg14-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
         - { tag: latest, mode: tests }
+        - { tag: pg18-geosmain-gdal311-proj96, mode: standard_conforming_strings_off }
         - { tag: latest, mode: garden }
     runs-on: ubuntu-latest
@@ -66,5 +67,3 @@ jobs:
       if: ${{ success() }}
       run: |
         docker rm pgtest-${GITHUB_RUN_NUMBER}
diff --git a/ci/github/run_standard_conforming_strings_off.sh b/ci/github/run_standard_conforming_strings_off.sh
new file mode 100644
index 000000000..ef3e3e4d5
--- /dev/null
+++ b/ci/github/run_standard_conforming_strings_off.sh
@@ -0,0 +1,14 @@
+#!/usr/bin/env bash
+set -e
+WARNINGS="-Werror -Wall -Wextra -Wformat -Werror=format-security"
+WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-cast-function-type"
+CFLAGS_STD="-g -O2 -mtune=generic -fno-omit-frame-pointer ${WARNINGS} ${WARNINGS_DISABLED}"
+LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
+/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile -o '-F' start
+./autogen.sh
+./configure CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
+make -j
+make check RUNTESTFLAGS="--verbose --after-create-db-script ${PWD}/regress/hooks/standard-conforming-strings-off.sql"
Summary of changes:
 .github/workflows/ci.yml                                       |  3 +--
 .../{run_tests.sh => run_standard_conforming_strings_off.sh}   | 10 +---------
 2 files changed, 2 insertions(+), 11 deletions(-)
 copy ci/github/{run_tests.sh => run_standard_conforming_strings_off.sh} (64%)
hooks/post-receive
