[PostGIS] #5176: no data check in raster2pgsql and also ST_BandIsNoData are slow
PostGIS trac at osgeo.org
Wed Jun 24 12:54:27 PDT 2026
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS Fund Me
 Component:  raster  |    Version:  master
Resolution:          |   Keywords:
Comment (by Darafei Praliaskouski <me@…>):
 In [changeset:"a4ecc46176c3fc0ab3fa69cf117d408bc622e592/git"
 a4ecc461/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a4ecc46176c3fc0ab3fa69cf117d408bc622e592"
 doc: correct ST_BandIsNoData forceChecking default
 The SQL signature defaults forceChecking to false, and the function
 description already says the default is false. Align the synopsis so users
 looking for the cheap metadata path do not see the expensive forced scan
 advertised as the default.
 References #5176
 Closes https://github.com/postgis/postgis/pull/977
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5176#comment:3>
