[PostGIS] #6087: Add repository-owned CI status checker and static dashboard generator
PostGIS trac at osgeo.org
Sat Jun 27 11:38:31 PDT 2026
  Reporter:  komzpa        |      Owner:  komzpa
      Type:  enhancement   |     Status:  closed
  Priority:  medium        |  Milestone:  PostGIS 3.6.5
 Component:  QA/buildbots  |    Version:  3.6.x
Resolution:  fixed         |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"09f06cab2e12cc71c84e082588d903ef47f81e46/git" 09f06ca/git]:
 {{{#!CommitTicketReference repository="git"
 revision="09f06cab2e12cc71c84e082588d903ef47f81e46"
 Add CI status dashboard generator
 Add a repository-owned CI inventory and Python status checker for GitHub
 Actions, Woodpecker, and Jenkins. The helper prints compact terminal
 output by default and can generate static HTML and JSON output for
 publishing.
 Closes #6087
 Closes https://github.com/postgis/postgis/pull/1122
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6087#comment:3>
