[PostGIS] #6089: wrong node used when adding a new long line
trac at osgeo.org
Sun Jun 28 06:53:06 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
In picture
[[Image(https://trac.osgeo.org/postgis/attachment/ticket/6089/p1.png)]] we
start case then we
Then we add the line that that should snap to the upper line
[[Image(https://trac.osgeo.org/postgis/attachment/ticket/6089/p2.png)]]
SELECT ARRAY(SELECT abs(add_case05) FROM
topology.TopoGeo_addLinestring('test_34_2_bug','0102000020A210000002000000C01856A5171528406C5803DF1D71504064BFAEFB153728406C5803DF1D715040',1e-07)
add_case05) ; -- log_add_to test_34_2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6089#comment:1>
